Hello !
Some action this morning, on my Tek 2465 scope.
I received Factory's envelope, containing that HV 3.3uF cap I needed to complete the PSU recap.
So I did that.
I also received my replacement / used brushless fan motor from QService i Greece, so I installed that as well.
Removing the old one was a bit scary given it's got no less than 13 pins, arranged in a circle, and I have no desoldering gun, and half the pins are soldered on the top side of the PCB, underneath the motor, so invisible and inaccessible, great.
Knowing that the motor was dead was a relief as I didn't have to care about it, but still.
Anyway, solder wick it was. I struggled a bit to pry the PCB off of the motor's butt, but not too much, and no damage, it went OK I would say.
Then I solder the replacement motor in place, then try to fit it in its plastic housing to make sure everything is fine and... no, everything was not fine. It would not fit 10% right... then realized the old motor was fitted with a plastic spacer over it's pins, which of course I didn't pay attention to and didn't swap.
So... the freshly replacement motor had to come off already !
Lucky me, desoldering it was a breeze, the hidden solder joint gave zero trouble and the PCB came right off, zero prying necessary. A miracle.
So fitter the spacer, soldered it back, then gave it's control board some power to see if that motor would work better than the old one... well, azt first it seemed so : the motor would be able to develop a lot more torque than the old one, for sure enough torque to spin the plastic fan. So I was relieved.... but not for long : after just a minute, the motor would "lock up" : motor had stopped, and if I try to turn it by hand, it actively resists being turn either direction. The windings are energized in such a way that it does so.. weird. I thought OK maybe one or more of the 4 transistors I put to drive the windings, gave up the ghost. I didn't have proper replacement for the original DIP package transistor array, remember, so I used TO-30 2N2222A instead.
So I test them... still good, strange. Put them back in place, power the motor again... it recovered, it turns again now...
So, I fit the motor assembly to the PSU, fit the PSU back into the scope, and fit the fan onto the motor shaft... the collet is broken in two, and I am missing the nut to tighten the collet as well, but somehow if I just shove the broken collet inside the fan, and fit that to the shaft... there is enough friction for the fan to grab the shaft, miracle.
So I power up the scope... and yes, miracle, the fan spins now, which it did not before !
... but again... 2 minutes later, same crap happens : motor "locks up" and fan can't spin anymore
Well, moving on, I checked all voltages and ripple as per the manual, adjusted the 10V ref voltage spot-on to 10.000V, which is not that easy as the trimmer they provide on the PSU is extremely touchy. Anyway, once the 10V ref was adjusted, all other rails were fine, and ripple next to zero, so much so that I had to double-check using a different DMM, but they agreed.
Result ? The PSU did not explode, and the scope still works, incredible !
However I notice the readout is still unstable/wavy at power up, and calms down after a few minutes. Bummer
But since the PSU is recapped and ripple is fine... at least we know this instability is not due to the PSU. So it must be due to some other electrolytic cap, somewhere else in the scope, wherever the signal path for the read-out is located. I guess it spans both the CPU board and the main analog board.
I am eager to figure it out because my 2467B suffer from exactly the same problem (it too has been recapped), so I could kill two birds with one stone.
So in conclusion :
- The recap is done and went well
- Fan collet still need fixing. I also need to source the missing 4-40 imperial nut that's used to tighten that collet. No, we don't have these nuts in Frogland
- Motor : Don't know whether it's bad and I lost lots of money (60 freaking Euros !), or if the problem is due to my inappropriate 2N2222's. So I first must identify and buy some better suited transistors, and see if that improved things. If it does not... the motor is probably defective and not only did I lose lots of money, but I am also back to square one. My gut feeling is that the motor is bad, but fitting new transistors is cheap and easy so I will do that first and see what happens. If the motor is indeed bad then I will try to get a refund and then I will have to start a whole new project / journey to replace this motor with a different one that's readily available brand new, cheap, and of course will have to design a whole new control board to go with it. Fun. Well not really. But one thing at a time.. first the transistors, with some luck...
Something else : the cap was also delivered with ... a foot I was missing for one of my two old HP ratio meters, thanks Dave !
However I failed to fit it... I not missing just the foot but also... the screw securing it to the chassis !
So I need to look up in the manual, hopefully there is a mechanical parts list that will tell me the diameter and pitch I need.
So I need an imperial nut for the scope, and an imperial screw for the HP foot. Pfff.....
So all in all, making progress, not complaining but... still a long way to go to get that freaking fan working
