Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 28699280 times)
wkb and 129 Guests are viewing this topic.
Offline m k
« Reply #136275 on: May 16, 2024, 06:13:40 pm »
Somewhere should be a collection of merger treeviews.
Offline factory
« Reply #136276 on: May 16, 2024, 07:35:31 pm »
Think I've got it fixed, multiple shorted tantalums across power rails again.  |O
The board seems to be for a 0 to 3000.00mV function, of the mystery device, I'm wondering if it's used in something else, as there are parts that were removed for use in this device.
I didn't have a 1.5uF tant beads in stock, a 0.47 & 1uF went in, the yellow STC 1uF promptly went tits up.  :-DD
It got cut out of circuit, +/- 15V rails were now working, but not for long, another blue tant expired quickly (without smoke), I'm thinking 35V tants across the unregulated 25V rails are maybe too low.
At this point I got fed up with the tants and fitted some 4.7uF 50V electrolytics in place of the lot, much better.  :-+
While I was in there I checked the rest of the capacitors and replaced a few tired ones on the other board, this board is part of the remote control for the 300V output.
« Last Edit: May 16, 2024, 07:43:13 pm by factory »
The following users thanked this post: Vince, Mortymore, ch_scr, duckduck, m k
« Reply #136277 on: May 16, 2024, 10:19:38 pm »
Hell yeah !
50V ratings for those and really all the old ones should be replaced with modern tants that are more reliable.
Offline factory
« Reply #136278 on: May 17, 2024, 07:43:00 pm »
Voltage de-rating is more important, modern tants are just as unreliable if you don't de-rate, YMMV.
In this case 50V tants were not available from my stock and I didn't know the expected voltages before replacing the first dead 1.5uF at 35V, which someone else smoked before I acquired it. The brown 0.47uF at 35V is still fine. The 4.7uF Nichicon caps were left over from the Tek 24xx series scope repairs. There are no more tants in this device.
« Last Edit: October 23, 2024, 02:07:52 pm by factory »
The following users thanked this post: Vince, ch_scr, duckduck
« Reply #136279 on: May 22, 2024, 06:59:45 pm »
TE incoming!
Bought a bench thermometer on ebay last night. Only £28 including shipping. Doesn't seem a great bargain until you know it's an ASL F25. Dual channel Platinum tesistance, 0.001 degree resolution and 0.025 degree accuracy. And it has two probes. Update when it arrives....
The following users thanked this post: Vince, factory, Kosmic, syau, duckduck
Online tggzzz
« Reply #136280 on: May 22, 2024, 07:12:05 pm »
... 0.001 degree resolution and 0.025 degree accuracy ...
Now you'll have to test that claim  >:D
Offline factory
« Reply #136281 on: May 22, 2024, 08:48:18 pm »
I've had a delivery from France yesterday, the HP 10525A logic probe from Vince.  :-+
Today I've had a closer look at it and opened it up, first thing I notice is the over-voltage protection Zeners are a bit cooked, thankfully they went short circuit and have prevented further damage.
For some unknown reason the two diodes fitted are different, one is a 1902-0049 (6.19V), but the other is a 1902-0025 (10V), the slightly older one in the pdf from a week ago has a pair of 1902-0056, the 1973/74 parts price list states this part is 23.7V  :o, must be a mistake somewhere.  :-//
I've put a pair of 1902-0049 in, next problem is the lamp being blown, it's smaller than the one I had to hand, but I was able to connect it in parallel and confirm the probe is functioning fine.  :D
« Last Edit: May 22, 2024, 08:52:27 pm by factory »
The following users thanked this post: Vince, ch_scr, TERRA Operative, syau, Zoli, m k, Peter_O
Offline abeyer
« Reply #136282 on: May 23, 2024, 12:51:44 am »
So I talked myself out of buying a Fluke 760A this afternoon, despite it being a good deal... Told myself it's just too big and heavy to keep around for something I don't really have any real need for. Now I'm having second thoughts. Convince me I did right!  ;D
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #136283 on: May 23, 2024, 01:17:57 am »
You should buy it. :-DD
Offline Peter_O
« Reply #136284 on: May 23, 2024, 05:16:30 am »
+1. Space consumption does not qualify as an argument.   ;D
« Reply #136285 on: May 23, 2024, 06:17:09 am »
What about structural collapse of the building?  :-\
Online wkb
  • PA1WBU
« Reply #136286 on: May 23, 2024, 09:40:58 am »
Bah humbug! Properly designed T&M equipment is a structurally sound substitute for a building!
Offline K0ELB
« Reply #136287 on: May 23, 2024, 12:12:46 pm »
Heartbreak:
2235598-0
This is from my “new to me” Tektronix 585. Worst part is, it’s P2 phosphor, one of my favorites.  :'(
Confirmed Tektronix Addict, currently have in use a 556, RM556, 532x2, 547x2, 545, 575 Mod122C curve tracers x4, Type 130 LC meters x2,75A Power Test Set, Engineering Power Supply, 561A, 564B, 565, 7904, 422, 435 RM503, RM504, RM181, Type 184, Type 114 x2, 067-0502-01, and a bunch of plugins
Offline m k
« Reply #136288 on: May 23, 2024, 01:09:25 pm »
Dang.
Luckily it's almost the summer and you have the roadtrip to come.
« Reply #136289 on: May 23, 2024, 03:22:15 pm »
I'll compare it to my Comark 3001 which is 0.010 degree accuracy and a couple of standard resistors ....
« Reply #136290 on: May 26, 2024, 09:21:19 am »
The F25 Thermometer arrived and all looks good. Need to do some detailed testing though.
It uses an AC (400Hz) bridge circuit with a Vishay 100 Ohm 0.01% hermetic (HC45/U crystal can) resistor as a 0 degree C reference.  8)
« Last Edit: May 26, 2024, 12:43:35 pm by Robert763 »
Offline factory
« Reply #136291 on: May 29, 2024, 07:19:12 pm »
Did you take any pictures of the insides? Can't imagine there are any others on the forum.
Mouser delivered a few parts yesterday, some capacitors for some Astec computer PSUs and the lamps for the HP 10525A logic probe.
Last week I didn't have the manual and was working from the circuit diagram in the patent, but I found out the power consumption was listed in the catalog at 75mA, without a working lamp it was drawing 12mA from 5V, nearest available lamp was a 5V 60mA, a bit more digging through the later probe manuals and there was a note of a type 2140-0016, this crossed to a CM683, a 5V 60mA lamp.
And here are the new lamps, first one out of the pack was a disappointment, as it was too big to fit down the tip assembly, but the next one was fine.  :phew:
Tonight I see the notice that KO4BB is back online after an outage, the 10525A manual can be found there and it confirmed I got the correct Zener diodes at 6.19V and the correct lamp.  :-+
Here it is back together, the missing tip was a standard part, I've borrowed one from the 3406A probe kit, will need to make a clear plastic sleeve to cover the lamp at some point in the future.
« Last Edit: May 29, 2024, 07:23:43 pm by factory »
The following users thanked this post: Vince, ch_scr, Zoli, duckduck, m k
Offline Vince
« Reply #136292 on: May 29, 2024, 08:25:06 pm »
Wow thanks for all the hard work you put into little guy, he must love you so much by now !  :D
Incredible for the probe tip ! I thought it missing would be a show stopper and condemn little guy to the trash... and in the end it was a standard part, who would have thought !!  :wtf:
The tolerance on anything with a glass envelope is rather..wild. Like that Nik-c tube on my Rochar DVM that just won't fit at all inside the tube bracket...... or like you here, light bulbs that won't !
Luckily small light bulbs you can buy lots of, for cheap... so you can just pick one that fits.
Thanks for your work ! :-+
Offline CalibrationGuy
« Reply #136293 on: May 29, 2024, 08:54:33 pm »
Could not help myself. Gotta stop doing this...
OK, drumroll please!
See pic.
TomG.
Offline shakalnokturn
« Reply #136294 on: May 29, 2024, 11:08:33 pm »
See pic.
TomG.
Volt nut alert!
I have frequency counters with less digits  :-\
If only I had the budget for that level of nuttery... Nothing has made it past the 6.5 digit limit here, the price curve is kinda exponential.
I'd have to flip 500 to 1k basic handhled DMM's to be able to afford even a used model of that dark matter meter, then they hardly show-up used anyway.
The following users thanked this post: CalibrationGuy
« Reply #136295 on: May 29, 2024, 11:21:57 pm »
See pic.
TomG.
Volt nut alert!
Yes, 10k used is a bit much, but I own a calibration lab, so I tell myself that we need another one!
TomG.
Offline McBryce
« Reply #136296 on: May 30, 2024, 10:08:14 am »
See pic.
TomG.
For a moment I thought I was having a heart attack, but it was actually just my wallet cramping up and hurting when I looked at that picture.
McBryce.
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #136297 on: May 30, 2024, 11:30:31 am »
Same sad story here:
https://electronicprojectsforfun.wordpress.com/finally-i-was-caught-in-a-tea-rabbit-hole/
But still, its the one and only :) Forget the Flukes ...
Offline factory
« Reply #136298 on: May 30, 2024, 01:29:25 pm »
I'm guessing a time machine was involved, to find those 20 year old Keysight DMMs.  :-DD
Keysight DMMs are really top class, in my opínion. I have never seen one fail, either, in about 20 years.
The following users thanked this post: m k
  • Country: jp
« Reply #136299 on: May 30, 2024, 02:18:24 pm »
So, it turns out modern silicon chip design is more software than hardware type work. Who would have thunk? (But it makes sense).
I'm way out of my depth here with my new job...... I am absolutely not a software person......  |O
