The other item is another counter, because I just haven't got enough of them, this one is a Scaler counter, the first one I've found with a probe, need to find a bit more about both the ESI 237, the FHZ74V probe and see what I can find around here to check with it.
Interesting to see that the high voltage that feeds the 'FHZ74V' GM tube (50 Roentgen/h) is directly adjustable on the front panel.
Maybe the counter was sold with different GM tube models that needed different HV values.
Hmm, that counter and tube came through my hands at one time. I sold it on ebay around 2010. The probe has a "european" low voltage tube. It was a standard probe used on several cold war era west german counters, It's the high range (low sensitivity) variant. The FHZ-76 was 50 times more sensitive. Thay bothe used Philips tubes ZP 13xx series but I don't recall the exact numbers. They run atound 400-500V.
The counter is an educational model, nothing special. I only put the tube with it to prove it was working. I got the tubes as mixed bags of NOS from Helmut Singer. Should have bought more of them. I don't have many left....
I recognise the 431A too. You should just come by here and cut out the middle man :-)
Robert.
Well that is most unexpected, finding the one counter with tube you once owned, with a dealer at the nearest radio/ham sale to me.
Your right I should have gone direct to you, do you still have any of the more sensitive probes? Or anything older that might be usable with the ancient Advance scaler counters SC1 or SC3?
I must confess I recognised the 431A once I had seen a picture of it, I have a picture of it from 2013, back when I had no need for power meters. Should have realised sooner when you mentioned "431" previously, I just assumed it was a later C variant.
-group-therapy-thread/?action=dlattach;attach=2500533)
I've found a bit more about the ESI that made the educational scaler counter, the full name on the device is "ESI Nuclear", with ESI standing for Edwards Scientific International, they seemed to have at least two sites, one in Mirfield Yorkshire, haven't found much about that one, except some politics involving the closure of the site in 1975 & a possible mention of making calculators for Sinclair, no idea if that is true or not.
ESI Nuclear were based in Redhill Surrey and had a number of adverts in electronics magazines in 1973, a later article form 1979 shows a different probe (maybe what they sold with these).
-group-therapy-thread/?action=dlattach;attach=2500521)
Mine seems to be a little newer, suggesting part of ESI survived the 1975 closure, with date codes on the various parts of 1980/81. Inside is a fairly heavy transformer for the low & high voltages, with a multiplier circuit for the EHT, using some some ITT caps that would probably benefit from replacement.
-group-therapy-thread/?action=dlattach;attach=2500493)
Wonder what voltage is going through that ribbon cable, to the EHT pot on the front panel?
-group-therapy-thread/?action=dlattach;attach=2500529)
The counter side has a 555 based reference clock, no fancy quartz rubbish in sight
, the rest is the usual 7490 & other TTL ICs.
-group-therapy-thread/?action=dlattach;attach=2500501)
There is a coax cable going to the 10kHz socket that has fallen off the PCB, I think I know where it should go and will confirm with a scope over the weekend.
-group-therapy-thread/?action=dlattach;attach=2500513)
