TE downsizing new episode... today we have this Enertec-Schlumberger model 4795 ... 500MHz RF generator, AM/FM modulation, analogue, levelled output.
Got it 7 years ago or something, was told it's faulty, not much details. Never touched it until today.
Goal : see what state it's in, and if possible (read : cheap and quick repair, a few days tops), get it working so I can get more money out of it, or sell it at all really.
Did I mention it's big and VERY heavy......like....
VERY heavy !!!
Symptoms : looks like we have two problems (that I can see, there may be more hiding of course, who knows...)
1) Power supply ? When I flick the power switch, no life on the LED display, but the needle of the galvanometer goes full scale hard.
The weird part : the frequency range switch, if I put it in the "16/32MHz" position, instantly the instrument comes to life ! And if I immediately rotate that switch to any other position, it powers off again ! .. except if I leave it on for a few seconds, then in this case rotating the switch in any position, can't power it off. Isn't that funky as hell ?!
2) No output : I scoped the output, nothing but background noise comes out... except when I rotate the frequency range switch, for a split second while the switch transitions from one position to the next, I can see the start of a sine wave cycle, half of it maybe. Works every time, perfectly repeatable (but does it to better in some ranges than others). At first I thought it was read hearing, like the Sin(x)/x interpolation that was just drawing a sine wave in reaction to the transient, but no : I switched the acquisition mode to "linear" as well as "dots", and I get the exact same picture. So, there is indeed something sinusoidal that can manage to get to the output, which is god I guess.
I get the exact same behaviour by another means : there is push button to let your turn off and on the output, quickly. When I play with it, I get the same phenomenon. I guess that switch is, electrically, extremely close to the output connector, so that encouraging as well, means the signal might stopped very close to the output connector, meaning 99.9% of the instrument is probably working fine.
3) The LED display only ever displays : " 0000000000000000000000000 ".... but I guess it's normal. the instrument looks 100% analogue, it's not digital/synthetized, so it's not there to let you SET a desired frequency, but rather only display / measure the frequency of the output signal, then it's up to you to adjust it the way you want. So since we have no output, it makes sense that the display would read zero...
I scoped the rear of the instrument for the internal time base : I get the expected 5MHz reference, a beautifully clean and strong sine wave, so I am very happy with that, it's a good start for sure...
Needless to say I know squat about RF stuff and am completely incompetent and intimidated... have been watching Shahriar for years, he always somehow makes it look easy to fix that kind of stuff, but watching him on my computer, and having an actual such TE full of coax cables and shielded boxes, in the flesh on my bench, is quite something else. Oh my god....
I guess that's my chance to see if I actually learned anything from him ?!
Plan of attack :
I have tons of documentation for this thing, printed on paper, so that's a good start, it's not a black box.
I will try to see how hard it is to check the power rails. Hopefully I just have some dying filter cap in the PSU.
Hopefully that will make it power up, and stay up, reliably. Then I can move on to diagnosing the no-output issue.
Wish me luck...
