Voltnuttery with a 3.75 digit handheld? Not even close. Hell, that's neither sufficient to use a saturated Weston standard cell as a thermometer, nor to have to worry about draughts!
Start with 7 digits, and work upwards.
Well I thought that the 87V was a 4.5 digit meter? while not quite a 7 digit granted but there are different grades of voltnuttery and if you have 7 digits or more that i'm certainly jealous, not that as I've said before, I need that level of accuracy, just love loads of digits I doubt that real voltnutters dived straight in at a minimum of 7 digits but gradually worked their way upwards as I'm doing, started with 3.5 and in the space of 18 months upto 5.5, who knows what I'll have another 18 months, a empty bank account I reckon
Well, it might depend on why one is buying a 87V multimeter.
It doesn't give you a high resolution because it has 3,5 digit in normal mode and 4,5 digits in high res mode.
What it does give you on that level is more accuracy than average handheld multimeters and therefore a higher level of confidence in what it displays.
If that is what one is buying it for, than it's likely that there's voltnuttery ahead..
In my part -started right away with 6,5 digit benchtop multimeters made by Philips (PM2534/PM3535). Having realised that they had the resolution but not the accuracy I wanted I went further down that rabbit hole ending up with three HP 3456A. Bought a 87V as a side effect in that time..
There are some LTZ1000 I bought over ebay from a guy in the USA that are still waiting to be checked and verified. And -if checked ok might pimp one of my 3456A.
Bid for a Prema 8017 7,5 digit bench multimeter yesterday but was outbid saved from going further down that rabbit hole.
For my part, the interest in an 87
x was did be to fill the void left when my first-run 87 was stolen during a move. I amended that desire to include one more digit, and thus zeroed in on the 189 as my target.
I am actually quite impressed with this meter; while it still only offers 2 DP in lowest resistance range, in Δ mode it can very repeatably tell the difference between 000, 1R0, three or four 1R0 in parallel, or one or two R200, to within .01-.02ohm. If I zero out with both probes jabbed in the the same solder fillet for each reading, it comes up dead on every time. Considering that it's a ruggedized meter intended for automation and process control, that is pretty effing amazing. Added to that the 1mS latching continuity tester that just does NOT miss, and it's an awesome useful piece of diag gear.
But here's something Fluke doesn't tell you in the manual: The junction test function has an open circuit voltage of 5.2V, current limited to exactly 1000uA. This higher open circuit voltage (most are right around 3.3v and varying current of ~1.5mA) makes it possible to turn on multiple LEDs in series and parallel (including high-wattage emitters that consist of 2 or 3 emitters in series or parallel), and it makes it useful as a handy current reference.
The only annoyance is that it only measures up to ~3.28V forward voltage (IRL); even though the scale says 5V, the specs say 3.1V full range.
Giggity.
