Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 4315164 times)
BU508A, sbrune, Kosmic, Zucca, bd139, tonyalbus, nfmax, URI, AlgisLt, 25 CPS, jh15, kleiner Rainer, med6753 and 30 Guests are viewing this topic.
  • *Escaping The Suck*
« Reply #33375 on: June 18, 2019, 05:29:14 pm »
Jeebus... that's a lot of effort to replace a device you can literally solder-snake inside a bit of heat-shrink tubing on a 99¢ XFMR. :-DD   Hats off to you for the courage of your convictions and following through on it, though.  :-+
Offline GregDunn
« Reply #33376 on: June 18, 2019, 05:31:01 pm »
*Hissssssses Python-like in tggzzz's general direction...*
 >:D
I remember makefiles, where there is a semantic difference between tabs and spaces. You can't see the difference on the screen, but the program does execute very differently.
Python does something very similar: cut and paste a bit of code, and if you don't get the right number of spaces then your code's meaning has changed. It also defeats attempts at cleaning up formatting by using an IDE's autoformat functions.
But I suppose omitting braces/brackets/parentheses is better for one-handed typists.
Python really works best if you have a "smart" IDE to sort those spaces for you; but it's very nice to have an unambiguous visual cue as to the control flow.  It is a problem when transferring the code to another platform.  I always hated that there were multiple ways to indent C/Java code, and none of them made any difference to the control flow despite looking vastly different - if you weren't careful you could completely miscommunicate the structure of the program and still miss syntax errors.  They were less prone to hackers writing indecipherable gibberish than Perl is, but still abused at times.
That said, while Python was a nice thing to have when we were building a complex inventory creation program, it has been infested with object-oriented thinking lately, a similar path taken by C++ or Java - and that's not a good thing (16 years of Java programming taught me that OO is not better than procedural programming, just different).  Though I haven't written any comprehensive programs in it, Go seems to be a step away from OO and back toward C with useful improvements to the base syntax.  You still have to be mindful of formatting it for readability, though no more so than C.
Online bd139
« Reply #33377 on: June 18, 2019, 05:48:02 pm »
Kicad?
Yep
It is indeed overkill :) ... This is a "two birds one stone" thing though. It'll fix the alarm and solve another problem I have. At the moment I'm running my radio off a 7Ah SLA pack which I am topping off with a TTi PL154 bench supply occasionally. This isn't ideal as it needs to be futzed around with too often. So the plan is to take the two NEW Yuasa 17Ah batteries I managed to filch the other week and use them in parallel as both a radio and bench lamp supply with this connected permanently for trickle charging and sling them under the bench. Thus the radio and lights will still work when the power is out which happens annoyingly regularly here due to the local substation being overloaded.
I want to make the most of the power outages as the noise floor goes down considerably!!!
« Last Edit: June 18, 2019, 05:49:33 pm by bd139 »
Offline worsthorse
  • aina varma, usein väärin
« Reply #33378 on: June 18, 2019, 06:28:33 pm »
Yes you're correct, I took another look at the pages and they have been scanned but at a very high DPI, my original posting saying that I doubted it had been scanned I had just deleted from the forum  |O so now everyone knows I was wrong  :-DD, hmm nothing new here, nothing to see, move along now  :-DD :-DD :-DD
Given that the archive.org PDFof the ECG cross reference is almost a gigabyte, I think that "scanned at very high DPI" is a pretty safe guess.  :-DD
I have a basic collection of data book scans in PDF rather than in paper format but only because (a) the DTVs of my favorite books are unobtanium or ridiculously expensive (the latter condition essentially creating the former for me) or (b) I know that having two cabinets full of musty smelling databooks from the 80s and 90s would result in a banishment order from SWMBO.
Offline worsthorse
« Reply #33379 on: June 18, 2019, 06:30:59 pm »
Actually KY jelly makes a great lubricator when it comes to trying to squeeze things into tight spots
I was going to offer a reply to this statement but, well, I think it stands on its own.   :-DD   :-DD
« Last Edit: June 18, 2019, 06:32:51 pm by wch »
« Reply #33380 on: June 18, 2019, 06:37:21 pm »
   If you were stateside, I'd just drop one of these in the post tooya. I have like 3 or 4... A single 1157 bulb in series and you're done.
Plus you get to feel smug in your understanding of how we whooped a battery's ass took tender loving care of our SLAs back in the old days. ;)
« Last Edit: June 18, 2019, 06:40:22 pm by mnementh »
« Reply #33381 on: June 18, 2019, 06:46:20 pm »
On my list of Suspect TEA purchases this is 2nd, the First was buying six tubes of KY Jelly at once for a Dopler shift flow meter.
For filling the wells on my Ice Point Calibrator 'allegedly'  :-DD
Actually KY jelly makes a great lubricator when it comes to trying to squeeze things into tight spots, eg, sliding long lengths of sleeving over anything, I've used other similar items originally designed for more personal usages, for that before today   :-DD
I try NOT to use water-based lubricants on anything that will see more than 5 volts or so; K-Y can stay wet for years inside heat-shrink tubing, and ooze out at the worst possible time.  :-/O
Food-grade spray silicone is much better and the carrier evaporates before you're done applying heat. The problem there is that it also encourages heat-shrink tubing to slide off while in service... there's always a gotcha when trying to "make things easier". |O
*tzzzzzt*
« Last Edit: June 18, 2019, 10:38:09 pm by mnementh »
« Reply #33382 on: June 18, 2019, 07:19:16 pm »
Indeed. There are very few reputable sellers shifting semiconductors. Usually best to get them from house clearance lots and mixed components lots now and sort and test.
Just spent the last 2 hours designing an SLA battery charger to replace a transformer/diode/capacitor and single resistor in my alarm which packed in yesterday. What a cheap arse hack. Very annoyed.
Replying to myself here. A veritable fuck you overkill charger for my alarm...
This one has CV/CC bulk and trickle charge, crowbar, reverse connection protection, some heatsinking, snubber caps on the bridge rectifier and can be scaled up somewhat for radio operation etc and fits in the cabinet I have already (hence the somewhat larger than necessary size).
Issue one so I expect fire and I put ZERO effort into the silkscreen. £9 for 5 boards from JLCPCB including delivery = win  :-+
Edit: To note I found out when I disconnected it by chance that the existing charger was causing my noise problems on 80m. Assume it was the diodes and the long cable runs! This one should be a little less unfriendly.
LM317, a 10t pot and some protection diodes fits on some Veroboard and smaller than a matchbox.
Let the 317 internal circuitry protect itself.........done !
Avid Rabid Hobbyist
Online bd139
« Reply #33383 on: June 18, 2019, 07:38:47 pm »
Need something with a bit more grunt and security than an LM317. This scales down to 100mA charge current and up to 5A and handles high mains voltages, overloads, shorts, reverse connection, source failure and most importantly protects the £1500 worth of kit connected to it if the regulator or battery fails and dumps more than 15V out. Also it handles CC initial charge, dropping to very precise CV mode once it is done. it can withstand a 95A fault current for ~2 seconds (enough to blow the fuse) and a persistent 15A fault current on all battery connected ports.
Incidentally even a nice TI LM317 doesn't last particularly long if you run it at the line eventually going in/out short hence why you tends to see fat 5W zeners across the output on anything worth more than about a quid.
« Last Edit: June 18, 2019, 07:42:03 pm by bd139 »
Online med6753
« Reply #33384 on: June 18, 2019, 07:58:14 pm »
Got the parts to convert the OL-1 tube filament to DCV and the results are "good enough" to consider this project as complete.
As I expected, the DC filament voltage is low under load because I'm rectifying the 6.3VAC filament from the power transformer. I'm getting 5.7VDC which is low but it works...just barely. Initially the waveform was extremely difficult to sync. I changed the sync tube (12AX7) and it's now stable. It's just a matter of selecting tubes which will operate a reduced filament voltage. I could fix this by installing a separate power transformer with regulation but I don't think it's worth the effort. So this guy is done and considering where it started from I can feel good that it's mission accomplished.  :-+
Here's the bridge and capacitor installed just behind the 6X4 rectifier.
And sample waveform at about 5KHz.
The following users thanked this post: xrunner, kj7e, mnementh, bd139, beanflying, Kosmic
Online beanflying
« Reply #33385 on: June 18, 2019, 08:07:15 pm »
And if it won't stand on it's own take the Blue pill .....  :-DD
I have a few different grades of food grade silicone lube for coffee machine work which works for all sorts of other odd elctro mechanical jobs.
« Reply #33386 on: June 18, 2019, 08:22:27 pm »
@Med, yes you can be justifiably proud of that one, it's come a million miles from where it started, well done sir  :-+, you can give a sigh of relief now the job is done.  :phew:
Brymen-Fluke-HP-Thurlby-Heathkit-Thander-Tek-Extech-Black Star-GW-Advance-Avo-Kyoritsu-Amprobe-ITT-Robin-TTi
Online bd139
« Reply #33387 on: June 18, 2019, 08:31:04 pm »
Totally. I am thoroughly surprised at the outcome after seeing the initial picture! Nice job!
Online nfmax
« Reply #33388 on: June 18, 2019, 09:05:59 pm »
Now you need to make sure that your alarm panel won't over-discharge the battery to destruction when (not if) the power stays out for too long, like mine did :(
I designed & fitted an over-discharge protection circuit which fits between the new battery & the panel.
Online bd139
« Reply #33389 on: June 18, 2019, 09:17:48 pm »
Dang didn't think of that  :-DD ... it does tend to go off if it goes flat though.
issue 2 will have a low voltage cutoff. Thanks for the heads up! I'll get issue 1 working first and thoroughly test it. Should be able to achieve that with a fat low Rds(on) MOSFET, comparator and TL431 off the top of my head.
Online Cerebus
« Reply #33390 on: June 18, 2019, 09:18:01 pm »
Food-grade pray silicone is much better and the carrier evaporates before you're done applying heat. The problem there is that it also encourages heat-shrink tubing to slide off while in service... there's always a gotcha when trying to "make things easier". |O
Try, if you can find it, Hellerine cable lubricant made by Hellerman-Tyton. I used to use a lot of it back in the days when I used to use Hellerman's neoprene sleeving for wire to board strain relief (audio stuff that was going on the road to be subjected to musicians, DJs, roadies and *shudder* producers). Stays slippy long enough that you can get your work done and when you come back to rework something a week or two later it seems to have all gone. Doesn't interfere with soldering either.
Offline xrunner
  • hp>Agilent>Keysight>?
« Reply #33391 on: June 18, 2019, 09:31:16 pm »
Yes very nice restoration!
I am a Test Equipment Addict (TEA) - by virtue of this forum signature, I have now faced my addiction
Offline GreyWoolfe
  • NW0LF
« Reply #33392 on: June 18, 2019, 09:54:29 pm »
Astroglide works much better. >:D
Online bd139
« Reply #33393 on: June 18, 2019, 10:36:04 pm »
Yep I bought some astroglide for a project manager I worked with back in ‘04 as he was a massive wanker  :-DD
That’s how you burn bridges  :-DD
« Reply #33394 on: June 18, 2019, 10:55:33 pm »
Got the parts to convert the OL-1 tube filament to DCV and the results are "good enough" to consider this project as complete...  (SNIP)
Looking good, buddy. Especially since I can't see that jank BNC connector in this shot...  :-DD
*Waiting for med to come back with a screen-filling pic of JUST that BNC now...*  :P
Offline VK5RC
« Reply #33395 on: June 18, 2019, 11:37:21 pm »
BNC are fine in my book, a pox on the bugger/s who keeps putting PL259\SO239 on equipment!
Online bd139
« Reply #33396 on: June 18, 2019, 11:39:25 pm »
I’m in complete agreement there. PL259 can go to hell. BNC or N and nothing else.
Offline VK5RC
« Reply #33397 on: June 18, 2019, 11:41:54 pm »
Maybe SMA for the weird stuff
Offline worsthorse
« Reply #33398 on: June 18, 2019, 11:44:34 pm »
That's a fine piece of work.
...and knowing when to say good enough!? Now, that is a skill worth cultivating!
Offline Neomys Sapiens
« Reply #33399 on: June 19, 2019, 12:01:08 am »
There is worse. RCA jacks for example. And that nameless one with the flat center contact (rather cheaply made). Here, instruments from that era tend to have 4/13 connectors. Those are 4mm Banana plugs with a 13mm outer contact. Most are well made, even jacks with switches have been seen.  And if none is at hand, one can still use any 4mm for the center contact and get ground from the (hopefully present) separate jack.
