Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 2021613 times)
Kosmic, BravoV, worsthorse, xrunner, Carl_Smith and 8 Guests are viewing this topic.
Online worsthorse
  • aina varma, usein väärin
« Reply #39275 on: September 20, 2019, 03:42:12 pm »
If it works in one range, there's most likely nothing wrong with the video amplifier, the chopper amp and the thermo couple. Your problem is most likely a dirty range switch—simply clean it. And: Please don't mess with the thermo couple!
Thomas - thanks, that's on the list.  And I am not going to mess with the thermocouples, I am going to experiment with them.  :-DD
Seriously, if cleaning the range dial doesn't fix it and there's no obvious problem with the attenuator deck, I will follow the service manual procedure for testing the thermocouples.  As for the fuse holder, I've decided to replace the back panel, as this one is seriously bent and impossible to make right. As noted below, there's a parts mule on ebay that may serve the purpose.
There is a parts mule here, it may even have one of those awful IEC connectors too. The previous owner EOLed the thermocouples and because they couldn't be arsed to fully screw it back together or pack it properly, the meter got busted on it's journey here.
David - thanks for checking your stock.  Last night, I found an ebay offering, as-is, two units for fifty usd shipped. They both have the "modern" AC socket, which I'd prefer. I am going to make an offer on them and see what happens. I will let you know if it doesn't work out.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #39276 on: September 20, 2019, 04:07:41 pm »
I'm retired. *   :popcorn: Normally I think about the day before what I'm going to do the next day. But today I got nothing.  :-// I think tomorrow I'm going to toss the two 485's on the bench and fix that trigger issue. But today...nada. So I guess I'll hang here and see what kind of chaos I can create.  :-DD
* I know I keep bringing this up and rubbing it in. But you know what, I got my first part time job in 1969 and basically from that point until January of this year I worked. 50 years.  :o I have to keep reminding myself that I don't have to do a freaking thing if I don't want to.  :-+
-Pat
« Reply #39277 on: September 20, 2019, 04:15:33 pm »
 :-+ :-DD
Online xrunner
  • hp>Agilent>Keysight>?
« Reply #39278 on: September 20, 2019, 04:34:17 pm »
A tribute to bitseeker -
I am a Test Equipment Addict (TEA) - by virtue of this forum signature, I have now faced my addiction
The following users thanked this post: Cubdriver, med6753, mnementh, bd139, Kosmic
Offline tggzzz
« Reply #39279 on: September 20, 2019, 05:21:57 pm »
I'm retired. I have to keep reminding myself that I don't have to do a freaking thing if I don't want to.  :-+
I'm retired.
I have too many things to do that I don't want to do, but have to do :(  -- for other people, which is both a positive and a negative.
Offline tggzzz
« Reply #39280 on: September 20, 2019, 05:27:34 pm »
   Oh....and just so my attitude today is clear. I present....   :-DD
It would be good to have a 3D model of that, suitable for 3D printing about 1" long. Just the kind of thing to keep in a briefcase/backpack for when it is needed.
« Reply #39281 on: September 20, 2019, 05:57:08 pm »
(Attachment Link)
(Attachment Link)
Just for giggles I went back and looked....
This thread was started January 15, 2017.
By Page 3, Post 56, dated January 20, 2017 I was here.  ;D
« Reply #39282 on: September 20, 2019, 06:01:56 pm »
I'm retired.
I try to keep a low profile which definitely helps. My circle of friends aren't the dependent type. My kids are very independent but Dad is always willing to help out if needed. GF lives 100 miles away and she's very independent anyway. And my Mother is in Colorado which unfortunately puts that burden on my younger brother. But I am going out there in late November for a few days and she's already mentioned some things she wants done around the house.
Offline Addicted2AnalogTek
« Reply #39283 on: September 20, 2019, 07:17:19 pm »
While using the Tek 284 pulse generator, It has become evident that there's some intermittent contact going on inside of the airline. I was able to get a pulse when tapping on the GR874 pulse output connector, which lead me to believe there was a bad connection somewhere at or near the tunnel diode.  I removed the airline and found the following:
The piece that makes contact with the tunnel diode has bent "fins" on the end that slide over the inner conductor of the GR874 connector. The manual doesn't show a spring in this part, but it seems like the inner conductor of the 874 connector is machined out for one...
I removed the set screw, spring, and ball bearing to clean to ensure good contact with R180.
I also removed the contact and spring on the other side of the tunnel diode and found that the spring has been stretched and twisted.
I also tested the tunnel diode on the 7CT1N, and it's fine.
The springs measure 0.125" OD and are closest to 0.500" length, so those are the ones I've selected. I ordered a pack of music wire type and stainless steel type.
I ordered some new springs from McMaster-Carr.
music wire springs PN: 9657K266
SS springs PN: 1986K45
Time to put this 284 back together so I don't lose anything..
« Reply #39284 on: September 20, 2019, 07:23:42 pm »
Avoiding buying a spectrum analyser with tracking generator (blasphemy!) because I'm a cheap arse part 1 ... getting a crystal filter sweep.
Managed to persuade the DG1022Z, DG1054Z and my power meter to work together and sweep a crystal filter with it. Hook up is:
(1) DG1022Z out -> 3db attenuator -> xtal filter -> W7ZOI power meter -> DS1054Z channel A
(2) DG1022Z sync -> DS1054Z channel D
Sweep mode on, trigger on channel D, marker on set to measure frequency. Bingo!
Vertical is 1dB/25mV. Horizontal as I don't care as I'm using the marker output!
Now to solder some caps around it and see if I can get rid of that bloody awful ripple in the middle  :--
The following users thanked this post: xrunner, worsthorse, Kosmic
Online xrunner
« Reply #39285 on: September 20, 2019, 07:30:42 pm »
That's pretty neat. Use what you have on hand.  :clap:
I guess I'll get me a NanoVNA - might as well. I was waiting to see if the v2 was going to be released that I heard mention of. Some of my ham friends have got the current model but they mostly don't know what all the "colored lines" are, especially the one that goes around and around the Smith chart as they sweep the thing from the lowest freq. it can do to ~900 MHz. I explained it but I'll get one and make some examples to try to "splain it betterer".  :P
Online worsthorse
« Reply #39286 on: September 20, 2019, 07:36:22 pm »
I just got one (the gen hu version) that I haven't had time to take out of the box other than to turn it on and see that it powers up.  Hopefully I will get it on my bench next week. Will look forward to your splaination.  ;D
Online xrunner
« Reply #39287 on: September 20, 2019, 07:47:26 pm »
gen hu version - OK, will look for it.
The explanation? Well, nobody in this thread needs an explanation and I wouldn't insult your intelligence by attempting that LOL.
Most of the hams I know get a "glazed over" look when I ask them if they know what a Smith Chart is for (which is of course is what they see on the screen sometimes with the circles) or what the S11 or S21 numbers mean.
They could just go to You Tube and look at a few short vids and get a pretty good idea, but that, it appears, would be too much trouble.  :-//
Edit: It's a new toy that costs so little they buy it just because everyone else has one.  :-DD
Online worsthorse
« Reply #39288 on: September 20, 2019, 07:50:50 pm »
smith charts are the bomb.  ;D
840292-0
and phil smith's book is still the best way to learn about them, though the W0QE simsmith videos are a pretty good place to start...
The following users thanked this post: xrunner, Mortymore
Offline daqq
  • Country: sk
    • My site
« Reply #39289 on: September 20, 2019, 07:53:38 pm »
Damn, I'm looking at a local ad site, they are selling this pretty for 250EUR... must resist, too much...
« Reply #39290 on: September 20, 2019, 08:08:29 pm »
Woot proper VNA. S-parameter models are fun. I was measuring S11 and S21 yesterday with my DG1022Z, RLB and the HP 400E. Again a cheap arse I be :)
Unfortunately only scalar but that's good enough for my needs at the moment. All I need to know is my input match and gain for what I'm building.
« Reply #39291 on: September 20, 2019, 08:09:54 pm »
Also another problem with USB is that USB plugs neatly fit into the ethernet hole too.
Edit: something I hate about new PCs these days. Some Dolby shit gets turned on and makes everything sound like farts in a coffee can until I've found it and neutralised it.
Holy shit balls, I've got 3 days worth of posts to catch up on.......
I think that the Dolby thingy is restricted to laptops, I've noticed a trend in making laptops with Dolby built in to try and add value to them and make them sound better with films in an attempt to make the small tinny speakers give a little bit more performance.
Offline Cubdriver
  • Nixie addict
« Reply #39292 on: September 20, 2019, 08:26:15 pm »
(Attachment Link)
Dammit you just cost me nearly $100!!   :rant:  You in cahoots with Amazon?!?
 :P
-Pat
« Reply #39293 on: September 20, 2019, 08:33:29 pm »
LMAO. Books are evil. There's probably a PDF of it in Library Genesis  :-DD
Win. Crystal filter needed different terminating impedances naively frigged with a series capacitor.
That saved me a few quid on a proper off the shelf filter  :-DD
I'm getting a hankering for another power supply. I've got three out on this project. Just feels like I may run short soon  :scared:
The following users thanked this post: worsthorse
« Reply #39294 on: September 20, 2019, 08:48:19 pm »
Never read much about them other than here and I think watching one of Alan's vids.
Still it doesn't take long to get the hang of them once you get an instrument that can do them.
I like best you can overlay all the important antenna data in a single screenshot:
Avid Rabid Hobbyist
Offline Cubdriver
  • Nixie addict
« Reply #39295 on: September 20, 2019, 08:48:47 pm »
Probably, but I still prefer books to PDFs and e-readers.
https://www.ebay.co.uk/sch/Adjustable-Power-Supplies/181993/i.html?_from=R40&_nkw=HP+Power+supply   >:D >:D >:D
-Pat
« Reply #39296 on: September 20, 2019, 08:53:07 pm »
Just spotted our resident dwagon seems to be back and busy catching up.
Been on a road trip mnem ?
Avid Rabid Hobbyist
Online worsthorse
« Reply #39297 on: September 20, 2019, 08:53:57 pm »
Gen Hu did a revision of the original NanoVNA, which you can find info on here:
https://github.com/hugen79/NanoVNA-H
As usual with this sort of device, there are a bunch of clones of varying quality, from poor to okay. He sells his version in only two venues, as explained in the github blurb. He's also set up a google drive folder with firmware and some limited documentation.
Since I rarely do anything above 100MHz, the price/performance (at 60USD shipped DHL, including SOL cal fixtues) is pretty darn good.  As a cheap way to learn how to use a VNA, it is even better.
And, it would be interesting to compare the NanoVNA to the DG8SAQ VNWA 3, too, but I am not that organized....  :-DD
Online worsthorse
« Reply #39298 on: September 20, 2019, 08:54:48 pm »
There you go showing off that fancy siglent stuff again...  ;D
Online worsthorse
« Reply #39299 on: September 20, 2019, 08:57:29 pm »
 :P
-Pat
Yikes! I found my copy, with the mylar charts intact, for $30 (though it took me nearly a year).  A library bookstore that apparently receive a bunch of pristine RF engineering books as a donation...
And yes BD, there are PDF copies out there, including one of the modestly revised edition. If you can't find, I have a copy, PM me.
The following users thanked this post: Mortymore
