Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 14938117 times)
Carl_Smith and 293 Guests are viewing this topic.
« Reply #41675 on: October 24, 2019, 06:26:26 pm »
« Reply #41676 on: October 24, 2019, 06:38:58 pm »
   He looks more :o to me...
From the "Chalk one up for Bambi" Dept...
https://www.msn.com/en-us/news/us/deer-fatally-attacks-hunter-who-shot-him/ar-AAJiNr4
"It's called Karma, bitch." ~Thumper
Offline worsthorse
  • aina varma, usein väärin
« Reply #41677 on: October 24, 2019, 06:46:52 pm »
https://www.youtube.com/channel/UCrYmLwfCjcCcIBPbJ0yGA3Q
I didn’t dare click on play... though I do appreciate the shout-out to Doctor Phibes.  :-+
 :popcorn:
just your standard issue death metal.  ;D
Offline worsthorse
« Reply #41678 on: October 24, 2019, 08:12:00 pm »
...as for the etymology of worsthorse? well that's another story...
 >:D
the basis for the nickname can be found here:  worsthorse
as for how i got it, well that is really not that hard to figure out.  ;D
« Reply #41679 on: October 24, 2019, 10:19:13 pm »
One for the UK sparkies; what's wrong with this picture?
That is made up unit from other bits and the problem there is that the breakers are being fed from a top mounted busbar which has Merlin Gerin isolock isolaters with the tabs hanging down with no safety shields in place.
Offline lowimpedance
  • Watts in an ohm?
« Reply #41680 on: October 24, 2019, 11:27:47 pm »
About a weeks worth of pics here...
So the Thurlby 1905a arrived today, and when I opened the case, I had my first 'hmmmm' moment
Then this caught my eye, that's the 200mA current measure fuseholder:
Am I going mad, or is that a MOV paralleled with the fuse? wtf?!?
The missing IC turns out to be quite important. It's one of the eproms, IC208, which holds 'Program E'  |O
Consequently, after taking it apart, saying "hmmm" a few times, then putting it back together and turning it on, I found it to be somewhat non-functional. I am currently deciding whether to try to get my money back (it was listed as used, none of the pics showed it powered up), or try to source an eprom...
  The MOV appears to be standard on the 1905a !!. see pic below from my unit.
Also attached is the binary dump from the ROM in my unit (plus picture of CPU PCB). The ROM used is a 27C64Q from national semi. ,
and notes a programming voltage of 12.5V. The other ROM position IC208 is not used.
 Not sure what revision yours is ?, as my unit appears to have a rather different PCB than the one in the only online manual I can find.
Good luck.
 PS does your unit have the TRMS module installed ?. If yes could you post a picture of it, thanks.
Offline Neomys Sapiens
« Reply #41681 on: October 25, 2019, 02:20:29 am »
I would have thought a 'Worsthorse' is when you have all defects on one horse, like:
The following users thanked this post: worsthorse
« Reply #41682 on: October 25, 2019, 03:42:06 am »
So... the three conductors of unknown state just hanging outside the box... not a problem...? :o
*tzzzt*
Offline tautech
« Reply #41683 on: October 25, 2019, 04:04:19 am »
*tzzzt*
No problem at all except for the totally wrong color coding for a single phase installation.  :scared:
Avid Rabid Hobbyist
The following users thanked this post: syau, AVGresponding
« Reply #41684 on: October 25, 2019, 07:42:17 am »
Probe Tips back in stock eBay auction: #171084548642 for anyone who missed out and wanted some.
And Also from the bay of evil eBay auction: #254395602790 Orlando area not sure about USA shipping but $0.01 with a few days to go.
« Last Edit: October 25, 2019, 07:59:37 am by beanflying »
Offline Terry01
  • Country: scotland
« Reply #41685 on: October 25, 2019, 08:45:10 am »
What are these used for  exactly? I take it there is a specific part or whatever that these were designed for to make probing easier?  :-//
Sparks and Smoke means i'm nearly there!
« Reply #41686 on: October 25, 2019, 09:05:43 am »
Use them anywhere you want to hook into a 2mm probe. Generally soldered to another connector/board/wire/pcb or whatever you need. For PCB use wire loops have been used as they are cheap like on the DMM Check plus or these would be a better connection as an example (new version seems to be just a single pin).
Just a well made adapter.
« Last Edit: October 25, 2019, 09:07:21 am by beanflying »
Offline Terry01
  • Country: scotland
« Reply #41687 on: October 25, 2019, 09:48:19 am »
Cool, thanks. I've never seen them before. Handy wee things.
« Reply #41688 on: October 25, 2019, 10:43:28 am »
Woohoo just hit the function generator jackpot!
Been after one of them for ages. Was pretty cheap and no knob damage or missing caps as well.
Edit: this is why. These things are top notch engineering even though they are plain on the outside.
« Last Edit: October 25, 2019, 10:48:19 am by bd139 »
The following users thanked this post: med6753, mnementh, worsthorse, Neomys Sapiens, Kosmic
Online PA0PBZ
« Reply #41689 on: October 25, 2019, 10:48:22 am »
Nice! A bit of soap and a soft brush and it should look as new! Any faults expected?
« Reply #41690 on: October 25, 2019, 10:49:04 am »
Power up tested only so unknown. I expect some ganky latching changeover switches and a bit of a clean and that's about it. Possibly toasted output resistors. Nothing unfixable.
« Reply #41691 on: October 25, 2019, 10:53:30 am »
The other option is that they recycled a tracking # so that somebody somewhere in Sweden actually got something. If you follow the other thread you noticed that this has happened to a few others.
I have asked PostMord (whose 1st line answered with a non-informative standard text) whether the package actually was destined to me. Let's see what happens.
PostMord replied and were very clear that this package had another destination than my mailbox.  :wtf: Looks like you're right.
Aliexpress dispute opened. Updates to follow.  :box:
« Reply #41692 on: October 25, 2019, 11:06:03 am »
Ham flea market (SK0QO) tomorrow. Am picking up a 100m roll of Messi & Paoloni 10,3mm coax. (Not, I hope, with rat feces on. ) Sharing it with a former coworker who also needs more for his antennas.   And, as usual, TE starts popping up on the in-country auction site just before (probably just to tease me :-[). Some of it is _really_ interesting  :-X, and I'm quite tempted to go on a bidding spree. It would be prudent to spend next weeks staycation building new TE shelves over the workbench, instead of creating an even bigger storage problem..
But swedish-built frequency counters are too tempting to resist!  :P
The 428b recommissioning is slowly progressing. Its meter is properly insensitive to AC, while carrying it to the output connector and further on to a scope.  :-+
« Reply #41693 on: October 25, 2019, 01:48:04 pm »
*tzzzt*
Tautech wins the prize   ;D
Interestingly, the numpty that installed it decided to use the red in a 3 core as the neutral, under that MC Hammer-esque baggy black sleeving, and what did they do with the yellow conductor? They cropped it at both ends of course, leaving a floating conductor in the cable.   :palm:
@Specmaster, all the parts are Merlin, none of that Schneider rubbish  ;)  and the reason there are nakey busbars showing is that it's in the process of being decommissioned. The only reason we livened the board back up was to get a temp supply to an area where we needed 240V for a tool tranny.
@mnem, the conductors in question are the temp I was putting in; don't worry, I DID sleeve them with the correct colours, and did NOT leave any floating conductors.   :-DD
@lowimpedance, thank you greatly for your post. The plot thickens!
Your processor board looks to be the same rev as mine; the one in the manual is (I believe) an earlier one, with 2x 2114 instead of 1x 6116 SRAM, and a 74LS155 instead of the 156 (although the parts list shows a 155 and not a 156, so maybe a typo? They're both multiplexers anyway).
This EEVBlog thread has a possible clue; post 3 leads me to believe that reseating the ICs is my next logical step, and not forgetting also the first commandment "Thou shalt measure voltages".
« Reply #41694 on: October 25, 2019, 04:11:58 pm »
I've watched some YouTube videos of British Sparkies and your mains wiring conventions totally confuse me with all the pretty colors.
Over here for typical residential wiring it's:
Black - hot
White - neutral
Red - additional hot conductor
Green or Green w/yellow stripe - ground.
The following users thanked this post: Carl_Smith
« Reply #41695 on: October 25, 2019, 05:12:43 pm »
Black - hot
White - neutral
Euro-continent _mostly_ is
Black, Brown, Grey = 3 phases, preferably in that order.
Blue = Neutral
Green/Yellow striped : Protective Earth.
Sweden had red for Protective Earth once; it IIRC ended in the very early seventies.  I think a few of the old cables in the garage are that. Our house is built 1971, and only a few of the cables are red PE.
« Reply #41696 on: October 25, 2019, 06:34:11 pm »
And DMM calibrations continue. Today the Tek 465B/DM44. This one was calibrated about 7 months ago after a repair so I expected it to be in spec. It was.
Next up tomorrow is Fluke 8600A. I expect that one to be troublesome. It's had numerous issues.
Offline tautech
« Reply #41697 on: October 25, 2019, 07:00:02 pm »
Black - hot
White - neutral
Blue = Neutral
Downunder in NZ
Single phase
Phase Red
Neutral Black
Earth Green/yellow
3 Phase
Phases Blue, White, Red,
Earth Green/yellow
However Flex cables can be different with Brown and Blue for phase and neutral in single phase leadout cables.
Avid Rabid Hobbyist
Offline factory
« Reply #41698 on: October 25, 2019, 07:00:49 pm »
*tzzzt*
Is it just me or are the Live/Neutral markings at the top the reverse of the connections at the bottom of the dual pole switch, i.e. they should be red/brown (live) and black/blue (neutral).  :-//
The other markings for the breakers aren't clear to me.
Offline factory
« Reply #41699 on: October 25, 2019, 07:08:10 pm »
Downunder in NZ
Single phase
Phase Red
Neutral Black
Earth Green/yellow
3 Phase
Earth Green/yellow
Much better 3-phase colours than the new dull colours (black/brown/grey) we were forced to change to (though we had yellow instead of white).  :-+
It makes you wonder how many mistakes are made (or will be in future) when cables end up dirty & illegible.
