Major bollocks up here. My HF antenna has been rubbing on a wall for the last 4 months apparently. Alas it’s ground a hole through the coax and the braid now and the thing is full of water
. Sooo 15m of RG58 in the trash and longest bit I have left is 8m. Gonna buy a 100M drum this time.
Edit: nanovna sweep of wet coax would be interesting!
Found I need more short BNC and other connector cables for the bench, so made a few.
And why does this show up as comment to "broken coax"? Well, I've been very happy with SSB-Technik 5mm Aircell coax instead of RG58A/U. I assume the difference to "plain" RG58 (with solid center conductor) is less. I've got a bunch of Chinese N connectors for RG58 style cable, whose center pin needed drilling out to take the solid core of Aircell 5.
They were cheap, though. And I soldered the pin, for lack of a suitable crimper. A flux pen is your friend.
The other end of that particular cable has a NOS Amphenol milspec solder/clamp BNC. Wonderful connector, probably insanely expensive when new. They consist of no less than 10 parts (Shell, center pin, front insulator, rear insulator, o-ring, braid spreader, washer, gasket, washer, clamp screw) which is a lot compared to the usual pin, shell, crimp ferrule style plug, but go together really easy.
