Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 2593523 times)
bitseeker, djadeski, alextwin007 and 12 Guests are viewing this topic.
Offline Kosmic
« Reply #44375 on: December 08, 2019, 05:10:06 am »
The next thing I'll do TEA-wise is giving the HP6114A a short lookover and abbreviated test - owing this to ERO-SHAN. As it was selected by him (and even scrubbed) I have high hopes for a functional instrument.
After that, a potential problem patient did come in and was bumped ahead of the HP6825A in the repair queue. A Tektronix PG502 (250MHz pulse generator for the TM500 system), which is very near the top of my 'items to get' list, as I need a faster PG and don't have much space.
I can't complain whatever the outcome, for 25.- it was a fair price even if it ends up as a empty module frame and handful of spares, and it was sold as not working. But I have to try because of the abovementioned need for one. The pictures suggested that it was mechanical damage to the controls mainly, which made me look forward to it. Now I have discovered that both fuses are gone, so there is more to it. Seals are still on, so hopefully I will not encounter any great ape actions.
While I have the original Tek extender, I now have to figure out a way to test it without endangering my mainframes.
250Mhz pulse is pretty cool. I hope you will be able to fix it.
Online beanflying
« Reply #44376 on: December 08, 2019, 05:23:25 am »
Getting close to Christmas so the white stuff is getting out again on a 31 degree day >:D Chilled Bean plenty of fat and I just don't care....
As you put that, it could be an excuse for anything...
By 'anything' you mean 'snow' right  ;)
Coffee, Food, R/C and electronics nerd in no particular order :)
Offline WastelandTek
« Reply #44377 on: December 08, 2019, 05:57:06 am »
easy now
I'm new here, but I tend to be pretty gregarious, so if I'm out of my lane please call me out.
Online beanflying
« Reply #44378 on: December 08, 2019, 06:28:04 am »
I blame the vinegar fumes for my possibly off comment above >:D
File renovation today. I have my own but this collection is my Dad's and Grandfathers that spent most of the existence next to the ocean. Chemical resharpening and final rust removal after removing the pins, scunge and miscellaneous detritus. Ready for the next few decades.
The collection is mainly Australian made Wiltshire but contains Canadian Nicholson, and a few from Sheffield
The following users thanked this post: mnementh, Neomys Sapiens
Offline tggzzz
« Reply #44379 on: December 08, 2019, 08:19:46 am »
How does chemical resharpening work? In my ignorance I assume chemicals would preferentially attack the thin pointy sharp bits.
Online beanflying
« Reply #44380 on: December 08, 2019, 08:51:56 am »
The theory is is takes metal from the top and front faces equally. Given I only left them in for about 10 hours on a hot day the sharpening effect is likely minimal. They are more sharp for the gunk and iron oxide removal than for metal removal I suspect.
That said quick test of even the very fine pitch ones feel much sharper to the touch and working really well.
Time well spent compared to buying quality replacements at $20-50 and the cheaper ones above a needle file just don't cut it  ::) (pun intended)
Offline Saskia
« Reply #44381 on: December 08, 2019, 08:56:53 am »
forgive my ignorance, but why not put them into an ultrasonic, add the rust removal and cleaning solution and turn up the heat ?
Offline VK5RC
« Reply #44382 on: December 08, 2019, 08:58:09 am »
Just vinegar or something else?
Online beanflying
« Reply #44383 on: December 08, 2019, 08:59:06 am »
Because I don't own an ultrasonic bath for a start ;)
Acid dipping because what I was shown a very very long time ago and a quick check of what people are now doing shows it is still valid and in use. Straight vinegar too @vk5rc then an alkali wash and clean rinse.
« Last Edit: December 08, 2019, 09:00:38 am by beanflying »
Offline VK5RC
« Reply #44384 on: December 08, 2019, 09:20:46 am »
Offline Saskia
« Reply #44385 on: December 08, 2019, 09:54:50 am »
ok, that explains it  ;) When repairing corrosion or repairing stuff I usually throw it into an ultrasonic after finding the fault to
- clean it
- remove corrosion
- remove flux
- remove baked in blurp
Depending on your cleaning solution and the ultrasonic settings the results are very promising.
Even entire pinball wiring harnesses including coils and switches come out very nicely. It just saves such an incredible amount of time.
« Reply #44386 on: December 08, 2019, 12:40:17 pm »
Power meter done. This came from the realisation that I wasn't going to pay MFJ £34 for a piece of inaccurate shit when I can make myself a piece of inaccurate shit for about £15 with a decent sized meter I can actually see.
Turns out this is actually usable to well past 150MHz (!) which was a surprise.
Outside. Caffeine shake wibbly lines FTW.
Guts. Not pretty but that's how you get low VSWR.
Now to build some power attenuators to push it up to 200W!
The following users thanked this post: Martin.M, xrunner, med6753, kj7e, Specmaster, Kosmic
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #44387 on: December 08, 2019, 01:04:25 pm »
make a rebuild of my RD1 ,
it is a trustful shunt for something what is hard working at the antenna output  :)
or the Heartkit Cantenna , a food can filled with a gallone of transformers oil .. the book for the homebrew I have here.
Don`t forget please to use the thick cables, my SK1 oldie have fried some meters from the RG58 by testing the output from the tube.
« Last Edit: December 08, 2019, 01:08:01 pm by Martin.M »
« Reply #44388 on: December 08, 2019, 01:13:45 pm »
I nearly bought a Cantenna a few months ago. Would have been a good investment. Decided that blowing 50W out per attenuator was probably less messy than dealing with oil even if it does keep me warm in winter.
Anyway next project is actually finishing off the thing that this is going to be plugged in to. This is the pseudo bitx which is going into the HP enclosure I have lying around (yes that project I started over a year ago is still going). As always, being a software guy, I wasn't happy with the original firmware so I rewrote it all using AVR-libc from scratch. I've also built the PA which will blow out 50-80W or so quite happily. But all the other bits are missing because they weren't as interesting. At least the IF strip is done and aligned!
Temporary enclosure for ref  :-DD
« Reply #44389 on: December 08, 2019, 01:59:13 pm »
I think it looks damn good.  :-+ That's what "homebrew" is all about. Carry on...... :-+
Online mnementh
  • *Escaping The Suck*
« Reply #44390 on: December 08, 2019, 02:02:27 pm »
Not nearly enough hand-wound toroids for the target user base. Needs to be much more complicated. :-DD
Uh-oh... forgot the top off the basket in my coffee pot this morning. EXTRA TEXTURE!!!  :P
« Reply #44391 on: December 08, 2019, 02:15:37 pm »
I'm winding those glorious bastards now  :-DD
Online mnementh
« Reply #44392 on: December 08, 2019, 02:20:19 pm »
Somehow, I KNEW you would be. :-DD
*inducted*
« Last Edit: December 08, 2019, 02:21:54 pm by mnementh »
Online mnementh
« Reply #44393 on: December 08, 2019, 02:22:12 pm »
...Apart from that, I explained it badly. The concept is to encourage the parents to believe that they shouldn't inflict their little darlings on you.
But then you miss out on the joy of teaching them horrible, disgusting campfire songs and filling them with caffeine & sugar until they vibrate just before handing them back to their adoring parents.  >:D
I would NEVER do that. Unless it was absolutely, positively hilarious. :-DD
Online mnementh
« Reply #44394 on: December 08, 2019, 02:39:59 pm »
Power meter done. ...Guts. Not pretty but that's how you get low VSWR.      Now to build some power attenuators to push it up to 200W!
Kinda surprised you didn't leverage that huge chunk of AL box as your heat-sink.  :-//
A little thermal goose-grease on the joint between front/back and you would probably not have too bad of a hot-spot, plus should keep stray capacitance from that big heat-sink floating in the air inside of the ground plane to a minimum. The goose-grease is probably not strictly necessary, but it can't hurt; plus a wet joint right close to where the angry pixies are dancing would reduce the chance of crusties causing resistance/capacitance between front/back.
But mostly thinking of the stray capacitance of that heat-sink. :P
  *fulminating at the mind over my morning cuppa chunky homestyle coffee*
Online mnementh
« Reply #44395 on: December 08, 2019, 03:02:53 pm »
If you don't have any industrial alkali products, you can scrub with Windex afterwards. Any decent quality window cleaner refill will do well; as long as it has enough ammonia (alkaline) that you can smell it. Then a rinse and/or scrub with distilled water and blot with a towel. Then put in the oven at low heat to dry completely; as hot as you feel comfortable handling them with gloves on (for me, this is about 300°F), This causes the metal to expand, opening up all the micro-fractures on the surface so it readily absorbs your oil treatment.
 I used to use ordinary motor oil or 3-in-1 Oil; with the advent of readily available full-synthetic in low viscosities like 0W-30/0W-20 I started using that to wipe my files down between applications of the file card. I've found it does seem to promote smoother cutting, especially in "drag-filing"; and it repels clogging noticeably better, especially with soft problem metals like aluminum. :-+
Offline tggzzz
« Reply #44396 on: December 08, 2019, 03:05:30 pm »
Don't need externally applied chemicals; internally generated ones are sufficient :) Such generation can be stimulated by
  • going from 0-55mph in 5s with their bum 9" off the concrete
  • pulling 3G and feeling their cheeks being dragged towards their shoulders
  • pulling 0G, and watching mud floating in front of their face
  • falling out of the sky, with only 10s to live  - unless they dive harder at the ground and then pull 3G
  • eyeballing sheep as they whizz past at 65mph, or raptors at ~0mph
... which provokes either adrenaline or a spaced out smile. If it provokes neither, then their parents are more than welcome to keep the.
And I would always do that, even though hilarity probably won't ensue :)
« Reply #44397 on: December 08, 2019, 03:06:10 pm »
It was some careful experimentation that lead to that hunk of crap. I actually started with a bit of RG174 on the end of the BNC connector but the mounting turned out to be a complete bastard and the VSWR was poor so I tried soldering it to the BNC connector itself. That worked nicely to 150MHz so I dared not touch it. Heatsink goes around it. I could probably mount it flat to the front panel but it's a bit of a pain as I wanted a 50mW-ish input as well.
Anyway got fed up of toroids so dug out another project from a long time ago that still works:
That was only supposed to knock out a couple of watts but I've been futzing with it and an MRF237 to give it more grunt. Now to try and make some contacts on minimalist kit. No computers involved!
Offline Saskia
« Reply #44398 on: December 08, 2019, 03:15:52 pm »
« Reply #44399 on: December 08, 2019, 03:20:48 pm »
I’d have loved that job :)
