Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 3452435 times)
mnementh, xrunner, Kosmic, Carl_Smith, vk6zgo, 0culus, BU508A, battlecoder, Wolfgang and 30 Guests are viewing this topic.
« Reply #47600 on: January 22, 2020, 10:57:46 am »
I should pull my finger out and publish some of the long term results with the ltzs. Honestly I think that quite a bit of it comes down to luck - did you get a good ltz and just the right resistor combo for it. I have multiple combinations of pcbs, op amps, resistors and ltz, I think about 70% suck (10+ppm overall true accuracy over the long term - including the box, pcb, reasonable room temp etc) , the others pretty good ie within 2-4ppm long term - as far as I can tell. Looking at all of the references - the 3458 itself looks pretty good - it is an old unit - and I think HP got first dibs on the ltzs and cherry picked the better ones.
I have only had the 3458 calibrated once and it did not seem to like the travel! All its measurements of most of my ltzs were out by 1-2ppm for a month or so after it returned then settled back to pre-cal. It was within spec and no adjustments.
Unfortunately the unit that TiN calibrated for me was not one of the better units.
I am just stepping it up bit at a time and the reality is anything industrial logging wise I need 1-2PPM with decent certainty is all I need and more to make, service and sell the gear I want to now and in future. Sub PPM is another whole level of pain without adding five figures of gear and another couple of $k per year for calibration.
Part of the LTZ and other assorted references plan is converted wine fridge for the references and also modding (decasing it for size reasons) a 34970A to fit inside with them and hold the lot at 20C +-not much then log it seriously over time. Apply that data against the 6 1/2 digit calibrated pair and be happy. The 34401A at least will go back to Keysight this year which is $500'ish and I haven't decided about adding the 34461A to it or not again :-//
Online BU508A
« Reply #47601 on: January 22, 2020, 10:58:13 am »
Has anybody ever tried to use these desoldering blades?
Example: Edsyn RB641
https://www.conrad.de/de/p/edsyn-entloetklingenband-edsyn-rb641-entloetklingenband-rb641-2144527.html
Edit:
This is the holder tool: Edsyn ST-706
https://www.ebay.com/itm/202803481888
« Last Edit: January 22, 2020, 11:07:08 am by BU508A »
« Reply #47602 on: January 22, 2020, 11:02:36 am »
A description for those who can't be arsed to skip around the video to find the meat of it.
Thank you.
Most videos consume too much of my little remaining life, so I can't be arsed to watch them unless I know it contains worthwhile and moving pictures.
:wtf: Are planning on going SK soon then so you got to cram a lot in before you do  >:D
Brymen-Fluke-Solartron-HP-Thurlby-Heathkit-Thander-Tek-Extech-Black Star-GW-Advance-Avo-Kyoritsu-Amprobe-ITT-Robin-TTi
« Reply #47603 on: January 22, 2020, 11:06:41 am »
Thank you.
Yeah, I watched that one at 2x speed and it still took too long to get to the point.
-Pat
Yeah, I suppose I could have told you were to wind it to, but then I remembered that we also have a few relatively newbies on board and his words of wisdom might well have been useful to them  :-+
« Reply #47604 on: January 22, 2020, 11:08:19 am »
10pm collecting a sipping Scotch and all is well with the shack TEA  8)
« Reply #47605 on: January 22, 2020, 11:15:59 am »
He uses one of these ESI 242D https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=ESI+242D&_sacat=0 I won't be adding one to the collection  ::) Details are above in an post from this morning.
I have been going through all the gear in the shack and removing the noticeable offenders. The last one was a simple LED wallwart that was upsetting the Fluke Calibrator at over 1.5m  :-- Off to on was a definite and measurable few PPM.
If I am being careful then PC's and monitors off along with the Coffee machine and the Cal gear is on the back rack with only one mains lead into it. Apart from that I could re arrange and run it off the  decent sized UPS I have but that is another possible source I guess.
Re the 34461A I rate the 34401A I have as more stable.
I  wonder if you guys are as anal with your cars as you are with your DMMs, I mean, your cars have a 0 - 60mph time, do you always check on it looking for those horses that might have escaped over the years  >:D :-DD
« Reply #47606 on: January 22, 2020, 11:19:23 am »
Yes, this is precisely the technique I recommended ages ago when we first talked about "Carlson's Great Capacitor Sin Video". Why the fuck does nobody ever listen...? :palm:
 :horse:
It is not your and my beers, if someone rips solder pad, after watching of carlson lab video.. :-//
My solution by case with minor capitor plague.
Two solder iron!
Those tips look like they need cleaning and so TLC.
Online BU508A
« Reply #47607 on: January 22, 2020, 11:20:40 am »
I am really missing a 6.5 digit speed-indicator in my car.  :(    8)
The following users thanked this post: worsthorse, AVGresponding
« Reply #47608 on: January 22, 2020, 11:28:20 am »
Depends on what you are doing with the results of it.
Some of the coffee and more so food I am looking playing with gear in the order of 0.1C accuracy or better so I need to be able to get well under that for testing and for certainty so a casual check with a 3 or 4 1/2 digit meter and a K type thermocouple won't cut it. Hence some Temperature Cal gear better RTD's calibrated meters and a bit further into the rabbit hole.
Playing with most stuff on the bench an 20 Mhz scope and a $50 meter would still do me like it did for a long time and would do 90+% of all work any of us need for home use but part of it is why we are here I guess
TEA is a bottomless cup  :-DD
« Reply #47609 on: January 22, 2020, 11:48:40 am »
Can't measure time with or without a 6.5 digit speed indicator, need a stop watch for that job  :palm:
« Reply #47610 on: January 22, 2020, 11:50:55 am »
Amen to that, or in your case, a coffee cup  :-DD
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #47611 on: January 22, 2020, 11:55:45 am »
got a 502A Keithley.
So I can test forks and spoons  :-//  (milli-Ohm-Meter)
it have a trusted peace of wood to set the distance of the 2 clamps exactly to 10cm,
means readout x10 = Ohms per meter   ^-^
Martin
« Last Edit: January 22, 2020, 11:58:56 am by Martin.M »
Online BravoV
  • +++ ATH1
« Reply #47612 on: January 22, 2020, 12:01:06 pm »
Bought two of this sacrificial lambs for Thor, "hopefully"  :-[ will save my GPSDO and other T&M equipments if he strikes.
PolyPhaser RF DC pass surge arrestors.
« Reply #47613 on: January 22, 2020, 12:27:15 pm »
Probably better that my solution which is roll half the feed up, wrap it in a supermarket bag, tape it up and sling it out the window until the storm has passed :-DD
Random question: does anyone know any reputable sources of decent quality instrument cases from China at all? I can only find ones described as "metal". I'd rather like to know if it's going to go rusty or not  :-DD
Online BU508A
« Reply #47614 on: January 22, 2020, 12:29:54 pm »
If the source is somewhat related to "Siglent": stay away from it.   :-DD   (no offense @tautech  :)  )
Offline McBryce
« Reply #47615 on: January 22, 2020, 12:32:33 pm »
How inaccurate! So you never really know EXACTLY how fast you are travelling...
McBryce.
Online BU508A
« Reply #47616 on: January 22, 2020, 12:33:42 pm »
McBryce.
* BU508A is throwing a Heisenberg after McBryce....    :-DD
Offline McBryce
« Reply #47617 on: January 22, 2020, 12:37:20 pm »
I'm just imagining the discussion with the Bundespolizist with radar gun in hand: "I wasn't going 70! I was going 68.8273kmh!
McBryce.
Online BU508A
« Reply #47618 on: January 22, 2020, 12:39:52 pm »
McBryce.
Police officer stops Heisenberg.
Officer: "Do you you know how fast you was driving?"
Heisenberg: "No. But I do know exactly where I am."
The following users thanked this post: Henrik_V, worsthorse, Neomys Sapiens, bd139, grizewald, AVGresponding
Online BravoV
  • +++ ATH1
« Reply #47619 on: January 22, 2020, 12:42:41 pm »
The fun part is when you about to roll or in the middle of rolling it and still connected, Thor does his thingy.  >:D
« Reply #47620 on: January 22, 2020, 01:14:07 pm »
How else am I going to get 1.21 jiggawatts!?
Offline Zucca
  • EE meid in Itali
« Reply #47621 on: January 22, 2020, 02:16:58 pm »
Edit:
Never used them and I do not like the idea.  :-//
Everything that put (by definition) force on a PCB or on a component is the wrong way to get the job done IMHO.
PCB and electronics components are like ladies, be gentle with them and they will (possibly) make you happy.
...and of course the older they get, the more you need to respect them.
« Last Edit: January 22, 2020, 02:19:25 pm by Zucca »
Online Cerebus
« Reply #47622 on: January 22, 2020, 02:25:53 pm »
No.
Like you I think I'm going to have to invest in a box and pan folder and start making my own boxes.
Online Cerebus
« Reply #47623 on: January 22, 2020, 02:29:00 pm »
O lordy, you haven't been nonna-chasing again have you Zucca?  :)
« Reply #47624 on: January 22, 2020, 02:44:42 pm »
Edit:
I doubt that the blade would have sufficient thermal mass to melt the solder as it was being pushed under the "leg" anyway
