Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 28713328 times)
0 Members and 526 Guests are viewing this topic.
« Reply #48250 on: January 29, 2020, 05:55:43 pm »
It's getting harder and harder to find any quality solder with clean lead and simple, organic rosin flux anymore. Well, without pay a kidney and a spleen for it, that is.  :palm:
*Current mood: 60/40*
In one of my ohmygawdtheyaretryingtochangemyworld moments I decided that good quality solder and solder wick was transforming into unobtanium and I started looking around for bargains.  At one point I bought twenty six rolls of various width NOS solder wick at a hamfest. At another, I found an electronics dealer going out of business sale and acquired five one pound rolls of multicore lead solder in various diameters and a smaller roll of silver solder. I think I have enough to last a while.
Once I bought a beat-to-hell piece of Tek gear to get the untouched roll of silver solder tacked inside. At that point, I started to think that maybe I had a problem. ;D
Yeah, bd139 and myself did similar, we took advantage of an eBay seller who had a limited supply left and I think we had his last 20 rolls between us, so I doubt that we'll be buying any more solder, ever.
Online Wolfgang
    • Electronic Projects for Fun
« Reply #48251 on: January 29, 2020, 06:01:04 pm »
Don’t make me post the ass of your Tek  :-DD :popcorn:
Edit: actually the last thing I threw together is a right piece of shit. Bob Pease style. I was experimenting to see if I can use a Widlar current mirror instead of two resistors to control a BJT multivibrator frequency yet keep consistent 3:1 duty. It worked!
I would say this is 60ies to 70ies Bronx style, a bit fluffy but you can feel the determination.  8)
« Reply #48252 on: January 29, 2020, 06:18:44 pm »
the moste cute mini scopes ever are british COSSOR
Did my work experience at Cossor :-+
Inside HM 307 not bad. Dirty so will clean out. Not esure if the choc bloc is original cable tied to the transformer. Latest date code is week 25 1980.
Only got one issue I can see:
Will ESR check the electrolytics.
Edit: just found some reference pictures and choc block is coming out  :palm:
« Last Edit: January 29, 2020, 06:20:26 pm by bd139 »
The following users thanked this post: grizewald
« Reply #48253 on: January 29, 2020, 06:38:15 pm »
I suspect that the choc block was to replace a dedicated voltage selection connection block mounted on the transformer, similar to the TTi psu's?
Edit: Now I've enlarged the photo, I think that the transformer has been replaced / rewound and those leads are the winding ends that would normally have been terminated at some solder tags mounted to side of the core laminations which are missing, so they improvised their own terminations. Unless the transformer gets really hot, I'd be inclined to leave the block but move it as far forwards as I could to increases clearance at the back end, and tidy up the amount of exposed contact.
« Last Edit: January 29, 2020, 06:49:26 pm by Specmaster »
« Reply #48254 on: January 29, 2020, 06:52:54 pm »
Okaaay... I've scoured the local swapsheets for a cheap air compressor to clean out my Ryzen7 beast once I'm all done replumbing it. Off to the bench, and will likely be quite busy for a while.  >:D
First world problems...
« Reply #48255 on: January 29, 2020, 06:55:40 pm »
24V 2.2A (around 50VA). Issue is size and mounting.
(Attachment Link)
Sounds close to a common HVAC/Doorbell transformer. Over here they're typically 120VAC IN / 24V-28V@48-60VA OUT, and come in either "screw to the outlet" wall-wart style or encased/flanged as this one. Available at most Homeowner Hell type stores for $15-20.
I expect you'll have the same for 240VAC over there. :-//
*wire-nut*
Nothing like that here now. All battery powered.
Heh heh I have my eye on a nice little 24V toroidal tranny in the old door hold system at the building we're refurbing. Looks to be 100-150VA or thereabouts.
It is most definitely coming home with me rather than going in a skip at the end of the job.
The run/charger tranny out of the old emergency lighting system is a different matter; I expect someone will want to weigh that one in as it's somewhere around 1.5-2kVA. Since I don't really need a transformer with around 48V @ 40A output, I'll not argue too strongly    ::)
Speaking of big assed PSUs, this looks a bargain for anyone who can go pick it up
https://www.ebay.co.uk/itm/WK-Wayne-Kerr-AUTORANGING-POWER-SUPPLY-POWERS-ON-NOT-TESTED-FURTHER-AP10090/254495700951
« Last Edit: January 29, 2020, 06:58:34 pm by ThickPhilM »
« Reply #48256 on: January 29, 2020, 07:07:13 pm »
@bd139, OK seems I was wrong, these winding taps are supposed to go through a grommet on a partition and terminate there. That transformer is actually mounted in a hole in the partition, the likes of which I don't recall seeing before.
Edit:
Looking at the two photos, I'm beginning to think that choc block could be original but poorly terminated, the photo I found would mean that the transformer is exposed at the rear of the scope??? In my photo it looks as if the transformer was bolted to the rear panel  externally and the bottom connections have been extended but interestingly, the tappings at the top would appear that those long leads are original.
« Last Edit: January 29, 2020, 07:19:35 pm by Specmaster »
Offline alextwin007
  • Collector of mini test equipment
« Reply #48257 on: January 29, 2020, 07:15:39 pm »
Welp now I have two more adorable scopes to keep an eye out for to add to my collection  :-DD
Since my tek 214, tek 322, nls ms-15, and waterman pocketscope need some more adorable friends :P
Having a test equipment addiction is difficult when you don't have a lot of room.  The solution, only collect small adorable test equipment.
Looking for a tek 1401 / 1401A, if you have one message me
Offline GreyWoolfe
  • NW0LF
« Reply #48258 on: January 29, 2020, 07:30:36 pm »
Honestly what do you do with all that bandwidth?  I'm quite happy here on 63/16. I can crank that to 270/35 but I don't need it.
Ditto. I pay for 60/25 but typically get 80 down and it's more than enough.
100/10 here.  Works great here even on VPNs for work.  Typically, I get 115 or so down regardless of the time of day.  For an additional $25 a month I could go to 400 down but I can't be bothered.
Online tggzzz
« Reply #48259 on: January 29, 2020, 07:39:01 pm »
Look at the page number. It's med's year of birth!
So he's actually beaten Methuselah!
Online tggzzz
« Reply #48260 on: January 29, 2020, 07:44:11 pm »
« Reply #48261 on: January 29, 2020, 07:47:49 pm »
??? so what are you say here  :-//
« Reply #48262 on: January 29, 2020, 07:49:28 pm »
Here's a little idea for you folks with 3D printers should you fancy the idea.
« Reply #48263 on: January 29, 2020, 08:04:13 pm »
Heh heh I have my eye on a nice little 24V toroidal tranny in the old door hold system at the building we're refurbing. Looks to be 100-150VA or thereabouts. It is most definitely coming home with me rather than going in a skip at the end of the job. The run/charger tranny out of the old emergency lighting system is a different matter; I expect someone will want to weigh that one in as it's somewhere around 1.5-2kVA. Since I don't really need a transformer with around 48V @ 40A output, I'll not argue too strongly    ::)
EVERYBODY needs JUST such a transformer!!! *coughSPOTWELDERcough*
 >:D
« Reply #48264 on: January 29, 2020, 08:34:08 pm »
Edit:
That's an HM307-1 in your photo. This is an HM307-3. They made it shorter and changed the chassis for it. It does indeed look original TBH.
Found that there were 3 knackered electrolytics in it, one has leaked, so replacing them and a 1.2K 4W resistor which appears to have cracked at one end. I replaced a few other electrolytics as a "just in case" as they are quite high value. Small ones are usually ok.
« Reply #48265 on: January 29, 2020, 08:43:36 pm »
Are you sure about it being shorter, looking at your photo would suggest that yours is the shorter of the two as the transformer is actually covering the first few inches of the bottom PCB which appears to be same PCB. The bottom terminals on the transformer on yours are almost directly above the connection points on the PCB and in the other photo some distance away to the left?
« Reply #48266 on: January 29, 2020, 08:45:05 pm »
Yeah 100%. There's no provision for a transformer that sticks out on this unit. It is inside the case.
« Reply #48267 on: January 29, 2020, 08:47:03 pm »
Yeah, looking at again, I can see there is a vertical board that goes across the top of the second smoothing capacitor  :palm:
« Reply #48268 on: January 29, 2020, 08:53:26 pm »
To me it looks like it is a primitive voltage selector.
« Reply #48269 on: January 29, 2020, 08:58:27 pm »
Thats what I first thought as well, rather similar to the early Thurlby psu's, they use a choc block on the transformer for the 120/240 selection.
Just went to install these new binding posts, never gave a moments thought that the mounting holes might be a different size, but the Heathkit has 9mm holes and the new posts are 7mm  |O, back to the search again.
« Reply #48270 on: January 29, 2020, 09:27:33 pm »
Whoops. I think these work in them. I'm sure I used them on something heathkit a few years back: https://www.rapidonline.com/truconnect-4mm-binding-posts-83061
« Reply #48271 on: January 29, 2020, 09:37:50 pm »
You know you're a hopeless nerd when... You can't make yourself cut the ATX plug off a working power supply because of that little voice in the back of your head saying "Never be caught without a backup for your backup."
*Raises clawed paw* Ifni save you if you heard that in Chief O'Brien's voice.
« Last Edit: January 29, 2020, 09:39:27 pm by mnementh »
Offline grizewald
  • Country: ua
« Reply #48272 on: January 29, 2020, 09:51:37 pm »
Oh well, the 34401A finally went for £191, which is probably insane for a broken meter.
Yeah that's the one I was looking at when I posted asking about unobtainium levels on display parts.
When it went past £50 I was out lol, I figured there's a fair chance the guy got it back broken because the person he sold it to swapped the good parts for bad ones and returned it DOA...
Yeah, I bailed out when it passed £75.
  Lord of Sealand
Offline WastelandTek
« Reply #48273 on: January 29, 2020, 10:01:17 pm »
so Worsthorse...did you get it?
I'm new here, but I tend to be pretty gregarious, so if I'm out of my lane please call me out.
Offline rcrook
« Reply #48274 on: January 29, 2020, 10:01:57 pm »
I just recently got this HP 1640A Serial Data Analyzer to try to restore. First bit of Test equipment I have bought to restore.
First thing I did was to create some replacement feet so I could at least stand it up. (I will put the STL file up on thingiverse tonight) As you can see from the photos, the CRT seems to work and I think the old 8080 CPU may still be ok, not sure about the rest though. But that's the whole point. I think it should be a cool little starting project for my upcoming addiction?
Randall.
The following users thanked this post: BU508A, grizewald
