Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 14883060 times)
Vince, Robert763 and 35 Guests are viewing this topic.
Offline worsthorse
  • aina varma, usein väärin
« Reply #50225 on: February 19, 2020, 06:43:43 pm »
I'm glad that the 'one knob for everything' interface seems mostly to have gone the way of the dodo.
-Pat
Me, I prefer all knobs and buttons. This is my primary rig, which I bought as much for the user interface as I did the receiver inside:
Menu driven touchscreen interfaces on test equipment and radios makes me crazy.
okay, okay. makes me more crazy. ;D
The following users thanked this post: Brumby, Cubdriver, bd139
« Reply #50226 on: February 19, 2020, 06:45:00 pm »
Also to note I am diverting some of my budget to buying a rather expensive bicycle and half a new wardrobe at the moment so need to keep things "as tight as a duck's arse" :D
*sigh* I miss being able to tolerate bicycles. I keep telling myself I could maybe actually ride one of the fatbikes with a electric motor assist; but then I start looking at the whole e-bike rabbit-hole and I realize I'd never actually finish building...  |O
 :scared:
I have a friend who has had three spinal surgeries and uses a recumbent bike now. Worth a look.
That usually turns into adding an extra wheel when I look at it.
Then a motor.
Then you end up with this which is basically an RC car you sit on  :-DD
https://youtu.be/_4ZCLd2fGl8
« Reply #50227 on: February 19, 2020, 06:54:30 pm »
No-o-o-o... THIS is the kind of Rabbit-Hole I always wind up peering down...  :-DD
While surfing around I've found this weird-looking scope from Metrix:   It is a Metrix MTX 3252 2 Channel 60Mhz Oscilloscope      https://www.ebay.com/itm/283474628268Never saw one of these before.  :o
That's certainly funky looking!!  I've never seen one either.
At first glance, I thought it was a fukkin' old HP printer. :-DD
*back to the bench*
The following users thanked this post: BU508A, bd139
« Reply #50228 on: February 19, 2020, 06:55:17 pm »
hey bd
were you bitchin' a couple of weeks ago about a sweep problem in an hp 1740?
grabbed one of mine to look at some ttl stuff and discovered it was having sweep/retrace hiccups.
pulled the cover and found this note.  hmmmmmm.  that is my handwriting.  musta' put that note in there 15 or 20 years ago.
followed my instructions from the past (or maybe i am finally gonna' get around to that time machine and its from the future?).  it is now working a-ok once again.  most likely pushing at the top reseats that white connector waaaaaay down at the bottom of the board?
or did you already sell your only hp scope?
Oh yes, while the 1740A is a great scope, its weakness and also its greatest feature at the same is its modularity via those push fit connectors. Unless these are kept clean on a regular basis they get dirty and cause intermittent contacts between the boards and the power buses.
« Reply #50229 on: February 19, 2020, 07:00:12 pm »
I'm finding that many of the techniques I used as a kid are not exactly good for an old fart like myself; but trying to glean useful information from the sea of "Health & Fitness Guru" bundahoo is a mental workout like none I've ever faced before. Last session I literally went to bed with a pounding headache from all the BS. |O
Try finding a textbook of exercises that's aimed at physiotherapy students. Physios don't go in for woo-woo, bundhoo, or any of that malarkey.
My experience with physiotherapists here in the UK is that those guys and gals really know their stuff and can get you sweating and aching in minutes without putting you at any risk of doing yourself harm. I've had all kinds of aches, pains and dismobility go away by seeking advice and exercise plans from physios and, kind of obviously, actually following the advice and exercise plans.
Offline tautech
« Reply #50230 on: February 19, 2020, 07:05:01 pm »
hey bd
Nope, the way the interconnects are factory soldered, wave I suspect left the TH pins light on solder that when combined with thermal cycling and other physical stress caused the solder fillets to crack. Reworking them and leaving beefy fillets generally fixes them.
Avid Rabid Hobbyist
Offline factory
« Reply #50231 on: February 19, 2020, 07:13:44 pm »
But when I looked at this scope, another one crossed my mind:
The scopes from Yokogawa (YEW), for example the Yokogawa DL1300A 100MHz digital scope.
This one comes with a printer too.
https://www.ebay.com/itm/293044805150
Has anybody worked with one of these scopes and can share one or two stories about them? Just curious how the perform and the handling is.
We have a 150MHz DL1520 version at work, most people (myself included) preferred the Yokogawa (or Kawasaki as it usually got called) over the digital LCD Tek scopes.
The menus aren't too bad on that version (in my opinion), plus there is separate timebase knob, the printer was also very useful.
The internal battery is only used for saved data & the clock, so no problems with cal data when it dies.
Bad points are the amber CRT being hard to see with over bright modern lighting, the printer paper is thermal so will fade over time (+ expensive), the floppy drives are unreliable and like most Yokogawa test gear I've never found any component level service manuals.
I can't comment on other versions as I've not used any.
I liked it so much I ended up buying one too;
How many things do I really need to measure simultaneously?
Still can't find the "Any" key though.
« Last Edit: February 19, 2020, 07:28:21 pm by factory »
The following users thanked this post: BU508A, Mortymore, bd139, Kosmic
« Reply #50232 on: February 19, 2020, 07:19:11 pm »
hey bd
Yep. Here's the inside of my 1740A. Was not happy about having to repair this one. Was difficult as hell!
This was the worst bit
End game:
Yep the traces were gone. I had to scrape out all the carbon and epoxy it then run new traces with wire out of some ladder line.
The following users thanked this post: Brumby, mnementh, grizewald
« Reply #50233 on: February 19, 2020, 07:22:49 pm »
Took a break from the bench and got away from that blasted 485. I'll dive back into tomorrow (maybe...I may wind up tossing it in the closet).
Anyway, weather forecast for the next 6 days is sunshine and no rain/snow. Got outside and gave the CR-V a good mid-Winter cleaning. Touch free car wash, hand towel dry by me, dressing on the tires, Amor-all wipes on the black trim. Looking spiffy!  :-+ So watch it snow a foot tomorrow.  :palm:
Behind it under the cover is the Civic hibernating. Haven't taken it out in almost 3 weeks because the weather has been shitty. Tomorrow I should be able to get it started, drive it, and charge up the battery.
The following users thanked this post: bd139, Kosmic
Offline tautech
« Reply #50234 on: February 19, 2020, 07:26:47 pm »
Yep I forgot how much other damage can occur from those cracked solder fillets from heating and now remember the fun you had with yours bd.  :(
Yet it’s a nice concept that is nice for fault finding and checking the PSU before lighting up the rest of the scope.
Avid Rabid Hobbyist
« Reply #50235 on: February 19, 2020, 07:30:18 pm »
Go back to what I posted yesterday and view the video of some knuckle head fixing a Tek 422 scope. It's amazing in the end he fixed it.
Offline factory
« Reply #50236 on: February 19, 2020, 07:40:39 pm »
And some how he got away without replacing a single tant.  >:D
« Reply #50237 on: February 19, 2020, 07:53:12 pm »
Those are just waiting patiently for when he's fixed it before they die :-DD
Edit: mini rant. Electricians. Never shall I allow one in my house after being sent something a few minutes ago from a family member. I've advised her to NOT power up her upstairs lighting which appears to have been fixed by being wired into a 13A plug and inserted into the socket in her cupboard because the lazy fucker couldn't work out how to replace the breaker in the CU. At no point did the thought go into his head as to why the breaker kept going pop?  :palm: :palm: :palm:
« Last Edit: February 19, 2020, 07:57:02 pm by bd139 »
« Reply #50238 on: February 19, 2020, 08:15:19 pm »
SNIP
Yeah, here is a public announcement for people in the TW and SW post codes of London to be on lookout for a man clad in Lycra and cycling crash helmet riding a new expensive bicycle and if spotted to look in the opposite direction as it will not be a very pretty sight and you may if spotted and you fail to look other way experience some disturbed and interrupted sleep yourself
You have been warned.  :-DD :-DD :-DD >:D
« Last Edit: February 19, 2020, 08:17:05 pm by Specmaster »
« Reply #50239 on: February 19, 2020, 08:21:15 pm »
Yep, I must admit to cringing when he filmed that capacitor foaming, he got up real close and personal and never once gave any thought to the consequences or to switching it off. He really was a danger to himself  and ought to be certified.
Online tggzzz
« Reply #50240 on: February 19, 2020, 08:23:09 pm »
Seconded.
They are cheap, they acknowledge that there's little point in more than half a dozen sessions, and they are unlikely to do harm. What's not to like?!
If still in doubt, compare that with many other parts of the medical industry :)
« Reply #50241 on: February 19, 2020, 08:28:18 pm »
:wtf:, He clearly was not an electrician at all, if he has any qualification at all it is probably for something like PAT testing or some other crap. He had no right to be allowed to touch electrics at all, it is a silent killer. Get round there quickly and sort it out for her.  :scared:
Offline factory
« Reply #50242 on: February 19, 2020, 08:34:56 pm »
:wtf:, He clearly was not an electrician at all, if he has any qualification at all it is probably for something like PAT sticker testing or some other crap. He had no right to be allowed to touch electrics at all, it is a silent killer. Get round there quickly and sort it out for her.  :scared:
There you go, fixed that for you.
« Reply #50243 on: February 19, 2020, 08:35:02 pm »
SNIP
No lycra here. I refuse.  :-DD
Actually reminds me of something I saw the other day. Two lycra clad folk on carbon fibre bikes in Richmond at the lights got completely owned by a hipster on a fixie who kept turning around and making loser signs at them.  :-DD
Apparently NICEIC registered although I suspect that's the company and not this turd. She's got another one arriving on Friday to sort it out. My instructions were simply to "don't turn anything on that is on that circuit and refuse to pay them"
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #50244 on: February 19, 2020, 08:37:24 pm »
SNIP
Will they even let a homeowner do electrical work over there?  I seem to recall reading somewhere (may well have been here) that they were difficult about that - only licensed electricians were allowed to do any wiring, and that the inspectors could usually tell if a homeowner had done something themselves - the giveaway being that what the homeowner wired was done correctly rather than being the normal hack job typically done by a real electrician.
-Pat
« Reply #50245 on: February 19, 2020, 08:38:31 pm »
hey bd
No, I never had any issues like that  on mine at all. it was just down to the very contact between pins and their respective contacts in the sockets having got dirty / corroded after years of the heating / cooling cycles, after much pain staking cleaning resolved the issues.
Offline factory
« Reply #50246 on: February 19, 2020, 08:41:05 pm »
He does have a face visor for the EOL videos, some of the stuff he does in the abandoned mine videos seems way more dangerous, like the recent one where he climbs a very dodgy ladder that's barely attached to anything.
« Reply #50247 on: February 19, 2020, 08:46:28 pm »
*back to the bench*
Yeah, I think that Meteix is a French company and it looks to me that they have a few of the old styling engineers from Citroen working for them, as they loved to be quirky on their cars.
« Reply #50248 on: February 19, 2020, 08:46:43 pm »
SNIP
-Pat
You can do anything you like but it needs to be signed off by an electrician if "notifiable" so any new circuits and bathroom/shower stuff usually. I  know someone who signs off anything I do if you slip him 50 quid without even looking at it :-DD. That shows how stupid the system is.
« Reply #50249 on: February 19, 2020, 08:50:22 pm »
 :scared:
Then a motor.
Geez, his legs literally become the crumble zone there  :scared: :scared:
