Orbix screws:
https://www.oscsales.co.uk/orbix/products
For when you really don't give a fuck
-group-therapy-thread/?action=dlattach;attach=1005286;image)
For when you hire muppets and you want it done* by lunchtime.
*or at least LOOKING like it might be...
Thank goodness those are not what we call self-tapping screws here.
What I am familiar with is this sort of self-tapping screw:
These have a sharper thread, which works well for attaching metal to metal. I have used these for attaching sheet metal, brackets or metal tubes to brackets up to 1/4" thickness. They work very well for attaching plastic or steel to steel. I would never use them for driving into wood, like is shown in the Orbix picture. When dealing with aluminum, they can seize up as @Cerebus says, but only 1 out of 200. Usually it is close enough to leave it as is, and the threads prevent play between the pieces unless high strength is important (in which case these should not be used in the first place). As also said, these need to be driven at high RPM, but this type of head works very well with an impacter as AVG recommends using. This head type seems to resist snapping off if overdriven; I have only snapped 3 in my life. IME, never had issues stripping threads with this type.
Switching gears, I have not been able to find a B450 motherboard anywhere for my so-called budget build, which is well over budget
. However, it is possible for me to pre-order a B550. Any recommendations on a B550 or X570 motherboard that is sort of in a budget category? I might as well look at choosing a good upgrade path if the budget path is not going to work out on this one. Once I figure that out, the only part left is the RAM. I thought RAM was a different type of animal than a rabbit, but this is a big rabbit hole for me. Between choosing manufacturer, clock speed, latency, chip manufacturer, it is still a minefield of choices. Saskia has given me some good hints, so I have learned a lot, but making that choice is still daunting.
-group-therapy-thread/?action=dlattach;attach=641927;image)
