Today arrival one of these ACV and ACA Digital LCD build-in meters.
I've bought this one in the bay:
Product type: D69-2049
Before hooking it up to the mains voltage I did some checking first.
Opening was easy, just some plastic snap-in tongues.
I've found some solder debris and one bent snap-in tongue:
This is the top view of the pcbs. I took them apart to check the spacing in the mains section but I missed it to take some pictures.
However, the clearings are looking reasonable to me, the lines to the full bridge rectifier are on the opposite sides of the pcb. All other clearings are reasonable. The LC Display is connected via zebra stripes to the PCB and LEDs were used as a light source together with a diffusor.
I have also applied some ferrules to the cables of the current sensing transformer.
I hokked it up then to my variac and around 180VAC it is starting working. Compared to my BM235 it is a bit off, but this can be eventually calibrated out. On the left 225VAC, zoom to the display which is nice and crisp and on the right 258VAC.
I'm not hundred percent convinced about it but honestly I'd expected worse. As you can see, on the front on the right side there is a little switch. I've shortened the leads of this switch, because right on the other pcb/side there were the leads of the green connector (incoming mains). The space between them are now good 7mm throgh air, before it was more likely 3-4mm.
I'm thinking about purchaising another two of them so I can measure then in my new lab the incoming 3-phase mains voltages and currents.
