I spent some time last night designing an adapter board. I’m spending some time today considering if I can be bothered to fish out cash for JLC to fab it or doing it myself with toner transfer. The latter requires that I buy some new PCB drills.
I'd suggest this:
- use one of your one-sided pcb
- cut out a rectangular piece of sufficient size
- cut a small slit in it so it will separate the Cu side in two areas
- drill 4 holes in it, two in each Cu area, 2x 4mm 2x 1.3mm
- use two of these "Messing M4 Abstandsbolzen" see picture below
- place the capacitor into the other two holes
- solder them
- assemble it in your device
M4 Messing Abstandsbolzen
capacitor 1000µF / 100V / pitch=7.5mm
