Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 3350596 times)
Cloud, BravoV, med6753, Fungus, Eric-H, jlo, Gary350z, tonyalbus, Specmaster, Messtechniker, morris6, K0ELB, URI and 38 Guests are viewing this topic.
« Reply #2725 on: October 11, 2017, 11:29:06 pm »
Have we got any truck nuts to go with volt nuts, time nuts and temp nuts??
Nothing too nuts only a '70 TK Bedford 7 tonne tipper.
Needs some work.....always needs work.
Avid Rabid Hobbyist
Offline AF6LJ
« Reply #2726 on: October 12, 2017, 12:04:41 am »
My TEA is getting worse... TopLoser is killing me with those prices. Help please!
It's looking good.
Keep it up. :)
Sue AF6LJ
Test Equipment Addict, And Proud Of It.
Online Specmaster
« Reply #2727 on: October 12, 2017, 12:36:52 am »
Argh yes, the Bedford TK and the Thames Trader, the best selling trucks of the period.
Brymen-Fluke-Solartron-HP-Thurlby-Heathkit-Thander-Tek-Extech-Black Star-GW-Advance-Avo-Kyoritsu-Amprobe-ITT-Robin-TTi
Online Vgkid
« Reply #2728 on: October 12, 2017, 12:40:29 am »
I'll definitely bring a few post-refurb shots here.  There will most likely be a longer thread started in the metrology section!
I look forward to this. I have an Azonix a1011 that I got cheap (thanks CataliniWOW) that works, just need to buy a pt100 rtd for it.
Offline bitseeker
« Reply #2729 on: October 12, 2017, 01:15:27 am »
Me too.  :-DD
The damn pusher got me twice already, and he is offering free shipping on my next fix.  :scared:
Think I have to become a member in here soon. ;D
No one becomes a member here. That already happened out there and then we come here to post about it. :-DD
Welcome, eeviking. ;)
I TEA.
Offline AF6LJ
« Reply #2730 on: October 12, 2017, 02:55:35 am »
That's Cute ^^^^^
Sue AF6LJ
Offline djos
« Reply #2731 on: October 12, 2017, 03:12:36 am »
Me too.  :-DD
Coming to this thread is causing me to add things to my TE acquisition list, so I'm not sure it's helping ... or is it?  :-DD
The impossible often has a kind of integrity which the merely improbable lacks.
Visit my Tindie store for Tandy 1000 Adapters for EX, HX, SX, SL, TX & TL etc
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #2732 on: October 12, 2017, 03:48:47 am »
Well, that's all relative to point of view.  Your credit card (and perhaps SWMBO) would say that it is not helping.  As a TEA 'sufferer', it's all good.   >:D >:D
 ;D
-Pat
Offline djos
« Reply #2733 on: October 12, 2017, 03:51:01 am »
 ;D
-Pat
It's motivating me to design and build more stuff for my retr0 buddies, which then funds acquisitions ... at least that's the theory.  :-+
  • *Escaping The Suck*
« Reply #2734 on: October 12, 2017, 04:12:14 am »
What do you think about the Tek 2645, some people think it may be one of the best, if not the best scope they made?, 300Mhz and 4 channels?
I would say they are the best unitized scope Tek made... but there are a number of 7000 series modular scope configurations that beat it. It certainly was considered to be a reference standard for analog 'scope accuracy and performance for decades after its release, and the fact of being able to be sealed/calibrated for use as such was probably where that came from. That, and the fact that Tek calibration procedures for the 2465 specify another calibrated 2465 as required gear to do the calibration correctly. ;)
I have one that has been on my bench since it was bought new by the company I worked for, one whose calibration history suggests it was in service at NASA around the time of the Shuttle missions, and another parts unit that I've used to keep the other two alive.
That and my 2230 were the heart of my bench for almost 20 years; now the 2230 has kakked a flyback AGAIN and I have a 1054Z serving right under the ol' 2465.
I do agree that they are a bit of a handful for amateur use; and decent 15-puff probes are not cheap anymore. The generic 100MHz probes everybody has will serve for most users; but if you REALLY need what the 2465 can do, they're going to distort the signal. What makes the 2465 so amazing is not what it's SUPPOSED to be able to do; it's what it CAN do that it shouldn't be able to.
Cheers,
moo?
« Last Edit: October 12, 2017, 04:31:53 am by mnementh »
Offline neo
  • The specialist.
« Reply #2735 on: October 12, 2017, 06:17:42 pm »
Well now i want a Tek 7904 with all of the modules listed.  It's going to be interesting to see how long it takes me to get one  :-DD
« Last Edit: October 12, 2017, 08:02:18 pm by neo »
Offline neo
  • The specialist.
« Reply #2736 on: October 12, 2017, 08:41:25 pm »
While on the subject of oscilloscopes could some offer me some advice on how to better use mine? (Hitachi V-1065A) I got channel one connected to my function generator and then EXT Input directly to channel one and it locks onto any signal up to the 2.3 MHz limit of my function generator, though the triangle wave is very shaky.
I thought to myself this is progress i figured out how to make it lock onto a signal up to 2 MHz, so i tried to connect it to a 30MHz signal and the display completely lost it instead of displaying the signal it just displays a bar as opposed to the signal.
My exact settings regarding the trigger are TV-H and divide by 10, either i am missing something or it is not triggering properly at higher frequencies.
« Last Edit: October 12, 2017, 09:02:21 pm by neo »
Online bd139
« Reply #2737 on: October 12, 2017, 09:00:09 pm »
Sounds like wrong trigger setting. The bar is “rolling persistence”.  Try the following (working from a picture of the scope here):
1. Set it on auto trigger mode and make sure 20Mhz BW limit is off.
2. Connect your signal source to the probe on channel 1 or use a BNC or something. Make sure it’s a 10x probe if you’re using one as the 1x probe will not have enough bandwidth!
3. Set the source to channel 1
4. Change the channel 1 volts/div so the signal is at least 2 divs high.
5. Set the time base to fastest speed.
6. Slowly turn the trigger level control from full anti clockwise to clockwise and see if it locks.
That scope should trigger pretty well up to 120MHz or so.
« Last Edit: October 12, 2017, 09:02:09 pm by bd139 »
The following users thanked this post: neo
Offline neo
  • The specialist.
« Reply #2738 on: October 12, 2017, 09:09:40 pm »
I've tried just that with no luck.
Online bd139
« Reply #2739 on: October 12, 2017, 09:38:43 pm »
What connection and/or probes and generator are you using?
Offline neo
  • The specialist.
« Reply #2740 on: October 12, 2017, 09:48:15 pm »
The function generator with a 2MHz limit is Instek GFG-8020H, the probe is http://www.ebay.com/itm/1Pair-New-100MHZ-Oscilloscope-Clip-Probes-for-HP-Tektronix-Hitachi-1X-10X-TP6100-/381152195371?hash=item58be70f32b:g:g9UAAOSwpDdU2XhB
, and i had it connected to function generator directly with a bnc cable. The 30 MHz source is a ring oscillator which i am experimenting with for a circuit.
I also connected the scope to my Simpson 415A with a BNC and it worked fine up to 1.5MHz before rolling persistence kicked in on that one
Online bd139
« Reply #2741 on: October 12, 2017, 10:09:35 pm »
In that case it sounds like the trigger is borked. Might just need cal steps running on it.
Offline neo
  • The specialist.
« Reply #2742 on: October 12, 2017, 10:12:39 pm »
I've always kinda thought of it as dodgy, maybe i was right to blame the instrument. Either ways forgive my ignorance but, cal steps?
Online bd139
« Reply #2743 on: October 12, 2017, 10:27:31 pm »
Grab the service manual for it and run through the calibration steps (cal steps). This might require specialist equipment such as time-mark generators etc however but just have a scan through for any trigger calibration and check out steps.
Online Specmaster
« Reply #2744 on: October 12, 2017, 10:58:15 pm »
Cal steps on a scope will almost certainly cause your TEA to get worse with the slow addition of yet more expensive and complicated test gear to set up the scope and so the cycle starts off again, it never stops, just keeps rolling along until lack of funds puts the brakes on  :-DD
Offline neo
  • The specialist.
« Reply #2745 on: October 12, 2017, 11:09:21 pm »
Lack of funding already has put a stop to the majority of my TEA.
In lighter news, SUCCESS! I connected channel 1 and 2 together and used channel 2 as the trigger and after alot of fine fiddling around with buttons i got it to lock onto and read the 30 MHz signal.
Online Specmaster
« Reply #2746 on: October 12, 2017, 11:14:26 pm »
What scope are you using?
Offline neo
  • The specialist.
« Reply #2747 on: October 12, 2017, 11:19:31 pm »
Hitachi V-1065A. Interestingly enough i just spent a week trying to figure out how to make this scope work for frequencies this high just to see what the output could do, current wise, before collapsing.
Should a ring oscillators oscillation look like a sine wave?
« Last Edit: October 12, 2017, 11:26:53 pm by neo »
Online Specmaster
« Reply #2748 on: October 12, 2017, 11:34:28 pm »
Well that baby is good for 100Mhz and as such you should not require to provide any external sync signal to get the trigger to lock onto the incoming signal. It sounds as if it does need to be calibrated and you can do that job pretty well yourself. Keep an eye open on Ebay for a Heathkit IG4505 and you can do it reasonably well with that without all other expensive kit provided you don't require it to be calibrated to Lab standards.
shows how to use this unit.
Offline neo
  • The specialist.
« Reply #2749 on: October 12, 2017, 11:38:22 pm »
I think mine may be slightly dodgy, using it has always been possible given the right amount of time but trying to get it to lock onto 30MHz has been like pulling teeth.
