Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 27833885 times)
Gertjan and 1109 Guests are viewing this topic.
Offline HalFET
« Reply #7375 on: February 14, 2018, 07:25:17 am »
Be glad that they don't clean it better.  Dirty lets those of us who recognize a diamond in the rough to get it for less $$$!!
I second that. :-+
And that looks like a nice counter - nice score.
That is a nice one. I have the "A" version, but no 1GHz option. One day I'll find one at a good price.
Quick disassembly and cleanup it looks quite good.  Came with the 1GHz option 003, I found the OCXO option 004 separately and installed.  GPSDO is on its way.  Going to replace the large power supply AE caps for good measure.
How much was the OCXO for it? And can it be GPS disciplined or is that a manually tuned one?
Yeah, this is easily one of the best counters HP ever made. They're really good price-value wise. My only remark is that you need an angle grinder to open up some of them.
« Reply #7376 on: February 14, 2018, 09:17:46 am »
I just discovered that 10, 7805 regulators that i bought are not worth anything and are probably counterfeit.
Talking of forgeries. I bought 60 assorted TO92 regulators from China for less than $1. They all turned up labelled National Semiconductor. Also, they all work bang on spec.  :-+
Genuine or not they do the job.
Offline Brumby
« Reply #7377 on: February 14, 2018, 09:59:07 am »
It's called "Pot luck".
Sometimes it's good.  Sometimes not.
OK if you have the time.
« Reply #7378 on: February 14, 2018, 11:49:31 am »
Large 10m tall antenna pole just arrived. It is longer than my house is diagonally. Time to annoy the neighbours by burning their TV front ends out. This is going to require some TEA expenditure. Need a VNA or antenna analyser now (any excuse - ho ho ho!) :-DD
Offline ChrisLX200
« Reply #7379 on: February 14, 2018, 01:48:55 pm »
You'll need to put a flashing red light on top to warn low flying aircraft :)
« Reply #7380 on: February 14, 2018, 01:52:09 pm »
Many a true word spoken in jest, he is very close to Heathrow Airport so he may indeed need a red light.  :-DD
« Reply #7381 on: February 14, 2018, 01:56:48 pm »
Yes I literally am under Heathrow 27L approach so may be a good idea  :-DD
Offline kj7e
  • Damon Stewart
« Reply #7382 on: February 14, 2018, 01:58:01 pm »
I tried to explain to my neighbors getting the radiating portion of the antennas away from the ground lessened the chance for RFI,  I had some who where cool, some who where not.  In the end I won.
74' freestanding tower with KT36XA for 10,15 and 20m and a 5 ele for 6m above.  Rotatable dipoles for 40m off the side and 75m at the top with a 2m/70cm omni to cap it off.
It didn't help I was feeding it from a Henry 4K Ultra hahahahahahah;
« Last Edit: February 14, 2018, 02:32:52 pm by kj7e »
« Reply #7383 on: February 14, 2018, 02:02:45 pm »
That's more like it. When I get myself a larger property I will build a proper tower like that. At the moment I have to try and keep this low key. So 10m pole with inverted V loaded dipole for 20/40m with a 2m going on the top if no one notices it to start with :(
We're limited to 400W ERP here top end so no fancy amplifiers really.
Eventually want a tower big enough to take a full set of weather station sensors as well as I have a Heathkit weather station in the cupboard.
« Last Edit: February 14, 2018, 02:04:36 pm by bd139 »
Offline tggzzz
« Reply #7384 on: February 14, 2018, 02:29:47 pm »
Before 2nd July 1987 you wouldn't have been - back then it was 28L :)
(Yes, I know, don't bother to explain it to me...)
Offline tggzzz
« Reply #7385 on: February 14, 2018, 02:32:38 pm »
Check the deeds carefully; quite a few have strangely restrictive covenants.
« Reply #7386 on: February 14, 2018, 02:47:55 pm »
Magnetic declination for those who want to google it :)
Yes. Fortunately they only usually apply to permanent structures. The usual trick is to use a movable concrete block and make sure you take it down occasionally, which is perfectly fine :)
I know someone who has a 60 foot mast in their garden who did exactly that. The village council objected to it being constructed and contacted the local council to complain about planning. The planning inspector turned up, he demonstrated that it was temporary by folding it down and moving it and left.
« Last Edit: February 14, 2018, 02:50:33 pm by bd139 »
Offline kj7e
  • Damon Stewart
« Reply #7387 on: February 14, 2018, 02:54:49 pm »
Problem solved!
« Reply #7388 on: February 14, 2018, 02:56:30 pm »
Hahaha. If only that worked here. Flag pole rule doesn't apply here. Plus people think you are nuts or scum, which is usually the case, if you fly a flag here.
« Reply #7389 on: February 14, 2018, 03:02:22 pm »
Using that would almost take up the entire garden around your location unless I'm mistaken. They are very mean with garden sizes over here in general, the country houses have by far the largest gardens around.
Offline tggzzz
« Reply #7390 on: February 14, 2018, 03:06:58 pm »
You can reason with local authorities, and they don't have spare money. OTOH residents' associations staffed by Captain Mainwaring wannabees...
« Reply #7391 on: February 14, 2018, 03:11:56 pm »
That would indeed. Mine is pissy. Fortunately we've got property on the end so there is a 2.5m wide piece of garden that runs from the front of the front garden to the back garden. Total span is about 25m. I am rising the pole on the fence slightly above the roof and then the elements are running along the roof profile.
I ran it through EZNEC to look at the radiation patterns and it mostly misses the roof by the looks if I hoist it 1m above.
Actually looking at a house just outside Chatteris this weekend. That has a 75x40m footprint.
Best way to deal with those types I found is getting them to sue me. They spend a lot of money being told they can't win by their solicitors :)
« Reply #7392 on: February 14, 2018, 03:26:19 pm »
Up in the Fens eh, very flat there, should be good for radio signals yes?
« Reply #7393 on: February 14, 2018, 03:27:33 pm »
Possibly. There is a radio telescope out that way which is a good tip on it being not too noisy. Well not until I turn up  :-DD
Offline tggzzz
« Reply #7394 on: February 14, 2018, 04:18:46 pm »
Things to look out for...
Contours, which can be vital.
The price of brussel sprouts, so you can converse with the natives.
Shop fittings: which decade are they from.
Low flying SR71s and U2/TR1s (oops, showing my age).
A 1:50000 OS map. Compare the amount of ink (any/all colour) compared with other places you know. (My current location has an order of magnitude more than near my previous house in Cottenham!)
Sky. Lots of it, and bugger all else.
The time/money cost of travelling to somewhere you want to be.
Opinionated? Shurely shome mishtake.
« Reply #7395 on: February 14, 2018, 04:24:41 pm »
Arh yes, that'll be the The Mullard Radio Astronomy Observatory along the A603 which is or was part of the Cambridge University but I believe that they are derelict now.
« Reply #7396 on: February 14, 2018, 04:29:09 pm »
Haha yes its certainly far from anywhere and loads of sky, space and loneliness and not that much low flying going on these days,we have virtually no air force left, apart the USAF at Lakenheath and Mildenhall  :-DD
« Last Edit: February 14, 2018, 05:18:01 pm by Specmaster »
« Reply #7397 on: February 14, 2018, 06:23:56 pm »
This space For Rent.
I for one have much enjoyed your closings like we used to for another sadly departed member SgtRock aka Clear Ether.  :-DD
If you need inspiration have a look at his posts:
https://www.eevblog.com/forum/profile/?area=showposts;u=6719
Ahhh... yes, he has some good quotes. My Post Scripts are more of a thing I do to keep my wit sharp. Sometimes it's immediately relevant to the conversation at hand, sometimes it's stream of consciousness, sometimes it's something that the conversation tangentially reminded me of... sometimes it's purely "Random Mode". :eek:
My mother was a hippie, and a soulful blues singer, and crazy wicked smart. She taught me that your mind is your most precious possession, and that if you don't use it, you lose it. ;)
I see it as honoring her and her wisdom in some small way.
I would seriously be tickled pink to see such a thing with my own eyes. ;)
As for space vs travel distance... I agree with my granddad; if you can see your neighbors, they're too damned close.  :-DD
"Every moment deserves its own song." ~ my mom
« Reply #7398 on: February 14, 2018, 06:27:46 pm »
Problem I found years ago living out in the countryside is that if you can see your neighbours you can usually smell the cow shit instead :)
Still thinking about that 7904 on eBay. Doesn’t power up. Thinking of low offer. Might just be duff PSU caps as it’s an early switcher.
Offline tggzzz
« Reply #7399 on: February 14, 2018, 07:05:56 pm »
I would seriously be tickled pink to see such a thing [SR71] with my own eyes. ;)
Very unlikely to, now. ISTR NASA keeps one flying.
The first time I saw one it had an armed guard, and the other dripped fuel as it accelerated down the runway. I refuse to consider how many decades ago, but I do remember that the entry cost was per car - so we took 7 people in a 5 seat car, with two in the boot :)
There is an SR71 at Duxford, 10 miles south of Cambridge; you can touch it. The last time I went there was in a DC-3 :)
