Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 1620742 times)
med6753, vindoline, Jambalaya and 10 Guests are viewing this topic.
« Reply #16250 on: September 13, 2018, 04:07:38 pm »
Ours was one of their 10KVA 10U jobbies. Think it had RBC-44 cartridges in it. The inlet termination exploded (reason unknown), set fire to the entire rack destroying one of our core Junipers (£25k a pop), two DL380s (£20k a pop each) and half the Avaya stuff in there (no idea how much that was as we were renting it).
Made a right mess.
Incidentally because we had been hit by the clue stick, this was one of two machine rooms in the building and the spare one kicked in apart from the dev stuff which resulted in some arm waving annoyance.
edit: the guys we had come in to fix it actually used paint scrapers to get the bits of plastic off the rack so they could get the batteries out and dispose of it.
Was it the battery inlet, or the AC inlet?
AC inlet I can see being possibly user error; plugged into a wrongly rated socket in the PDU, or a PDU that should have been replaced with the last HW refresh or the one two refreshes ago.  I see THAT all the time, and particularly lease companies don't press the issue even though they should for the sake of the install. You don't wanna know how many times I've arrived to do a rack & stack to find some crusty old 4 foot power strip with outlets that have broken and pushed inside the rail, and they tell me "plug into one that's good; power distribution upgrades are outside our SOW." :palm:
The other possible problem is the battery inlet connector; it is just a big Sermos connector. I STILL hate those things with a passion, even though I have to work with them all the time. Actually, probably BECAUSE I have to work with them all the time. There installer error can fuck you too; you HAVE to get them plugged in right, so BOTH contacts snap. It is, IMO, TOO EASY to get them cocked so they're making partial contact, ESPECIALLY after having to move that big thick cable so you can plug it in and then route it so you can get the cover back on. This is a problem with the units that use the RBC26 & RBC43  especially due to the angled/recessed plug. The RBC44 isn't that bad though; that battery cavity is huge.
But that is after all is said and done a design issue; IMO, the Sermos connector is NOT a good choice for long-term high-current load connection, no matter how much they swear it is, and even though everybody uses the damned things.   :rant:
I'm all out of "pithy".
« Last Edit: September 13, 2018, 05:42:55 pm by mnementh »
« Reply #16251 on: September 13, 2018, 04:12:48 pm »
It was a hard wired unit and was connected directly to the bus bar on top of the racks via a dedicated tap off. Unit was three months old. One of the AC inlet modules exploded. It was past the termination and actually inside the device. Enough of the termination was left to eliminate the installers from the chain of blame. There wasn't a lot of it left in there to work out why it blew on the board. It sucked 8KW peak that little box :)
« Reply #16252 on: September 13, 2018, 04:31:42 pm »
https://www.amazon.co.uk/ThermoPro-Digital-Instant-Cooking-Thermometer/dp/B07CB8JG21/
Here it is... they got the model wrong in the Product listing; it is the TP-01S, not TP-01A. I think that may be a special packaging just for Amazon; it came in a little sealed box, not the usual hook-hang card-style blister-pack.
AVOID the little bulb-shaped one they also offer on that page; my last one had that same kind of segmented LCD display and it was an utter POS. You breathe on the little fucker and it all turns black and you can't read it; absolutely USELESS on the grill.
*Juicy-ometer*
£4.99, now we're talking.
Thanks mate. Looks like SWMBO's Amazon account is about to take a hit.
Edit: SWMBO came in 30 seconds later, she has been mugged...
Ummm.... glad I could help you mugg SWMBO...?
Just make sure the next time she likes something you cooked that she knows the thermo-tormentor made it possible and she'll forgive us. ;)
"Now, waitaminnit... I was just showing him how to cook properly... put down the sword, Red..." *Accidental grope* "Oh Shi...!!!"
« Last Edit: September 13, 2018, 05:45:03 pm by mnementh »
« Reply #16253 on: September 13, 2018, 04:36:06 pm »
And THAT is why I excessively document EVERY STEP OF EVERY INSTALL. There is no such thing as too many photographs.
[EDIT]
I really have no idea what else I can say here; APC has been one of my go-to suppliers for decades, and the reason is I work with their product all the time and have had a near-zero failure rate. And not a single failure I believe was not directly caused by environment or dumbass-fuckery. They're one of the few products I think of in decade terms; deploy it and forget about it for 10 years...
[/EDIT]
Unless you're a dumbass. Then ONE photograph is probably one too many.  :-DD
« Last Edit: September 13, 2018, 05:41:29 pm by mnementh »
« Reply #16254 on: September 13, 2018, 06:25:12 pm »
We're currently waiting for the fresh from the oven turnovers to get down below lava temperature in the middle...
Online med6753
« Reply #16255 on: September 13, 2018, 07:36:24 pm »
Is this TEA or the cooking channel?  :-// :-DD
Offline neo
  • The specialist.
« Reply #16256 on: September 13, 2018, 07:39:27 pm »
Both, and neither. This is the magical room of TEA where everyone knows your name and the topic at hand is whatever the guy in the (metaphorical) corner happens to be babbling about.
« Reply #16257 on: September 13, 2018, 08:18:37 pm »
I think it all started way back when bd139's oven was bust and we were all taunting him about what baked or roast things we were enjoying while he was waiting for a replacement and 'is missus was spending all the new oven money on haircuts and shoes.  :)
« Reply #16258 on: September 13, 2018, 08:24:38 pm »
 :-DD such sympathy
I'm getting my own back now. I just had a roast dinner. On a Thursday. Screw the rules.
Offline Neomys Sapiens
« Reply #16259 on: September 13, 2018, 08:37:12 pm »
Can't be bothered to sort/fix any TEA gear tonight so my mind got wandering onto powerpole connectors for test leads and radios. Have ordered some to play with.
That's what all the power for my ham equipment is connected with.  :-+
IMHO, what sucks most is that they are using those pesky blade fuses on this box. One characteristic fits all? But most that are sold don't even belong to a defined one.
« Reply #16260 on: September 13, 2018, 08:38:55 pm »
:-DD such sympathy
Yep, you can always count on your fellow members for sympathy, although to much rubbing it in about a roast dinner on a Thursday could cause a waning in the sympathy stakes  :popcorn:
« Reply #16261 on: September 13, 2018, 08:54:47 pm »
I rather like blade fuses. I bought some inline 3M brand fuse holders for this project.
:-DD such sympathy
What sympathy is this? I don't remember any  :-DD
I had apple strudel for pudding. Waitrose own brand fresh individual portions. Yum. https://www.waitrose.com/ecom/products/apple-strudel/091816-47272-47273
Online med6753
« Reply #16262 on: September 13, 2018, 09:02:33 pm »
You guys really suck. You keep mentioning these delicious items that this diabetic can't eat.  :scared: If you don't cut it out I'm going to go buy an apple pie and eat the whole thing and then go into a diabetic coma.   :-DD
And it will be YOUR fault.  >:D ;D
« Reply #16263 on: September 13, 2018, 09:04:45 pm »
While I was out today attending a family funeral the postman dropped this little gem of for me along with 5M of 12AWG black and red silicon cable so I can make some heavy duty meter leads and can also double up as leads for the power supplies, just waiting the arrival of some suitable stackable banana jacks etc.
This little meter is pretty accurate, certainly accurate enough to use in the mobile tool kit and can measure DC current by clamping the meter around a cable and during testing I found is within 0.2 of mA on its readings so it's not a shabby little performer at all considering its cost (mine was half price because I used up some Nectar points). I was feeling a bit down and needed a new toy to play with at the time I ordered it and bugger if within hours of ordering it I stumbled across that 8842A as well  :palm: and there was no way on earth I was not going to make a determined effort to secure it as it was fully loaded, but it needed to be at a much reduced price, it was listed at £250 and I managed to get it at £100 which was my limit and to my pleasant surprise the seller was only a few miles away and he kindly offered to deliver it to me the same day...result. :-+
« Last Edit: September 13, 2018, 09:14:23 pm by Specmaster »
« Reply #16264 on: September 13, 2018, 09:07:54 pm »
You had apple strudel on its own or with cream, maybe ice cream. Yum I love apple strudel, I could do with some right now to lift my spirits a bit. :-DD
« Reply #16265 on: September 13, 2018, 09:08:49 pm »
Now you made me think of a Kaiserschmarrn and an Obstler.
Unrelated but current: I snagged a supposedly working DC503A counter fot the Tek TM500 system today.
I already have one, but for 30.- I would even take it for the plugin and the spares.
But I would be willing to exchange it for another TM500 unit (which ones, we will see).
Applies to Ge and other european adress.
« Reply #16266 on: September 13, 2018, 09:13:33 pm »
If it's any consolation SWMBO is a diabetic and can't eat half of what I do. You're not alone in your misery  :-DD
With cream. Unfortunately all is not well with me either so lactofree cream it is. Lactose is my kryptonite  :-DD
Jebus that's cheap! TM500 stuff is a mugging usually.
Online med6753
« Reply #16267 on: September 13, 2018, 09:19:20 pm »
Good...karma at work for eating all that forbidden stuff in front of the SWMBO.  :-DD :-DD :-DD
« Reply #16268 on: September 13, 2018, 09:28:00 pm »
There you go, loads more sympathy  :-DD
« Reply #16269 on: September 13, 2018, 09:32:57 pm »
Anyone here got 8842A? if so, do you use the 20 \$\Omega\$ range in 4 wire mode for the extra resolution, and so is it ultra slow reading or is my meter? If I do the 4 wire mode on the 3478A it gives me 4 dp anyway, even in 2 wire mode and so much faster?
Online GreyWoolfe
  • NW0LF
« Reply #16270 on: September 13, 2018, 10:10:23 pm »
Depending on what it is, this diabetic doesn't necessarily care.  Mrs GreyWoolfe brought home a home made cheese cake from a patient/friend and I made sure that I had my share.  Yes, my blood sugar jumped into the 130-140's range (diet maintained type 2) when it is normally in the 100-110 range but that's OK.  Cheese cake is a protein for diabetics says Mrs GreyWoolfe and she is our PCP's medical assistant. :-+ :-+
That which doesn't kill you still requires a co-pay.
« Reply #16271 on: September 13, 2018, 11:28:00 pm »
"brrblblrrbrrblblrrrblbrrrblbrrbl..."
:-DD such sympathy
Yep, you can always count on your fellow members for sympathy, although too much rubbing it in about a roast dinner on a Thursday could cause a waning in the sympathy steaks...  :popcorn:
There, fixed that for ya.  :-DD
I just had roast chicken for dinner... not the same, I know... but  :-//
It's my understanding that except for a rare few with LI that manifests as acute IBS, 6-8 grams, sometimes as much as 12 grams per meal is still tolerated well.
Heavy whipping cream has almost no lactose; it's all fat. Well, 0.41 grams per ounce... which still makes it less than a gram for the 60 or so grams I pour in a cuppa coffee.
Alternately, unsweetened almond milk; I prefer vanilla flavored as it masks the slightly fishy taste of plain almond milk. Zero lactase, 1 gram carb for 8 oz. All recommended carbs on my 10-20 gram a day keto diet.
*Coffee time*
« Reply #16272 on: September 13, 2018, 11:35:54 pm »
Your making me hungry, I'm downstairs to find something to nibble on........................
Online med6753
« Reply #16273 on: September 14, 2018, 12:22:54 am »
Oh this type 2 diabetic cheats on occasion too. You have to or you'll go nuts. My A1C stays between 6.3 and 6.5 and I control it with 1 oral med and diet. (It was 7.9 when I was diagnosed 4 years ago! :scared:) No insulin shots required. I don't check my blood sugar but every 6 months I have blood work done and my fasting blood sugar is usually 80 - 100. And my weight is normal for my height and I make sure to keep it that way. So I'm diagnosed as a "controlled diabetic".
« Reply #16274 on: September 14, 2018, 12:50:08 am »
I regularly temporarily forget that you guys in the States use mg/dL for blood glucose where we use mmols. Normal in mmols is in the 4-7 range, so 130-140 sounds like you're a walking corpse with corn syrup in your veins, until I remember that's in mg/dL so is actually around 7.5 mmol and is "Meh, a little high. I've seen worse induced by a single dose of corticosteroids".
