Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 2416253 times)
beanflying, morris6, med6753, mansaxel, FransW, bd139, Addicted2AnalogTek, nfmax, Zucca and 12 Guests are viewing this topic.
Offline Brumby
« Reply #26050 on: February 24, 2019, 09:37:59 am »
Bet the contacts are smoked on one of the RF relays when it’s supposed to be short.
That's one of the things I was concerned about.  Access could only be gained (practically) by decapitation.
Probably someone connected their radio to the output to do receiver testing and accidentally keyed down. Mr attenuator said “fum” and went to attenuator heaven.
There is reverse power protection.  At the right you can see a coil wrapped in yellow which surrounds a reed relay, so that will (should) open to protect upstream.
:-BROKE Time for a thread with the RF and Hams @brumby I reckon  :)
I had thought about that since I don't want to clutter this thread too much - but I thought it only fair to share my initiation experience...
Just into three figures over the voucher  :phew: sort of.
Relax.  That's normal.
Online bd139
« Reply #26051 on: February 24, 2019, 09:52:03 am »
Reverse power protection doesn’t always win in time :)
Online Specmaster
« Reply #26052 on: February 24, 2019, 10:09:20 am »
I expect that would greater depend on the amount of reverse power connected, if you connect to great powerful radio, the amount of RF power may be such that the energy let through is far greater then the protection was designed to handle and although the protection relay may have opened up, the damage could well have been done in the initial burst? In the same fashion as a circuit breaker on a power circuit, they are only designed to handle so much energy, if it sees a far greater amount then all bets are off as to the probability of it actually clearing the fault with no damage being done.
« Last Edit: February 24, 2019, 10:12:33 am by Specmaster »
Online Specmaster
« Reply #26053 on: February 24, 2019, 10:15:02 am »
Looks like something I built. Bet the contacts are smoked on one of the RF relays when it’s supposed to be short. Probably someone connected their radio to the output to do receiver testing and accidentally keyed down. Mr attenuator said “fum” and went to attenuator heaven. I would test each attenuator pad with an ohmmeter carefully.
TBF teks leaf switch arrangement was better than that thing by the looks.
@Specmaster: cool videos. Thanks for posting  :-+
I’m going to haul my ass to the hamfest. Wish me luck.
OK here's wishing you luck, you can be my ears and eyes on this occasion and see if it's worth visiting on another occasion. Funds are a bit low after getting the camera and a new 15 to 250 telephoto lens to add to my 70 to 300 one. So then I'll have 2 cameras with me, a 50D and the 7D.[emoji106]
Looking reasonable so far. Queuing nice and early. It’s bloody freezing though  :--
On the plus side, it's nice bright and sunny day, ideal for outside photography, I keep my fingers crossed for something nice to test the camera on when I get there
Online bd139
« Reply #26054 on: February 24, 2019, 10:52:07 am »
Radio rally a bit pants. Got me some RF power transistors, enclosures, cable and connectors but nothing TEA related of interest. The best scope they had was a Gould one that had been eviscerated by a T-Rex by the looks of it.
There was a heathkit AC voltmeter for £15 but I’ve fought one of them already and couldn’t be bothered.
Spent a whopping £19
Offline Brumby
« Reply #26055 on: February 24, 2019, 11:02:19 am »
Now is the time I start reaching for the little hair I have left.
The contacts of this second stage read from left to right:
- 20dB control ( 0V, 15V )
- 10dB control ( 0V, 15V )
- 30dB control ( 0V, 15V )
- Reverse power detection output
- Reverse power protection relay  ( 0V, 5V )
Between the reverse power detection circuitry and the reverse power protection relay is a capacitor.  In one unit it measures 195pF, the other 220pF.  With 15V on the pad controls and 5V on the protection relay, this capacitor is what you can measure between the input and output.
I set this up - and that was exactly what I measured.  I then connected the first stage, powered the two pad controls and measured the full path between the low band input and the output - and all I measured was that capacitor ... as it should be.  So, I quickly ran the 1kHz cal signal from my faithful old Hitachi CRO through the low frequency input and checked operation of the pads and reverse protection relay.
It all worked as I expected it should.
 |O
Walking away for today.
  • *Escaping The Suck*
« Reply #26056 on: February 24, 2019, 02:04:17 pm »
...I’m going to haul my ass to the hamfest. Wish me luck.
Luck!   May all your vendors be stricken with temporary stupidity and an overwhelming desire to GTFO!
And may you need to rent a lorry to get it all homE!
« Reply #26057 on: February 24, 2019, 02:08:59 pm »
Sometimes my TEA comes in the form of Digital and Tongueular devices...
Oh my... would you look at all those delicious carbs...
*dwagon dwool*
Online Specmaster
« Reply #26058 on: February 24, 2019, 07:55:00 pm »
Off topic again but for those interested here are some test shots on my new Canon 7D and Sigma 15-250 zoom lens. I went to North Weald as planned but it was quiet so I went to Stansted instead and got real close to end of the runway (almost directly under the flightpath) and took a few photos to test the speed of focus and clarity of the new lens as well. I'm really impressed with the results so far, what do you guys think?
With the amount of birds flying around there, it's a surprise that there have not been many if any actual bird strikes reported, as you see in the 2nd and 3rd photos, this plane appears to have a near miss today.
I did try some 1080p video but they were just to close for comfort and I have to practise a bit more before I can post a short clip, it really needs to be mounted on a tripod as its a heavy camera and not meant to be handheld at arms length as both the zoom and focus are manually controlled.  :palm:
« Last Edit: February 24, 2019, 07:56:58 pm by Specmaster »
Online bd139
« Reply #26059 on: February 24, 2019, 08:02:42 pm »
nice  :-+ ... my father said a good camera can see the hairs on the frozen stowaway in the undercarriage and that's a contender for that  :-DD
It wasn't that long ago you could go for an amble across the runway at stansted. Either that or I'm getting old  ???
Offline URI
« Reply #26060 on: February 24, 2019, 08:13:03 pm »
Wow, so much going on here... managed to catch up though.   :horse:
Ok, while I was just reading and reading and reading I received a neat little power supply I got cheaply because it was equipped with a US power plug and wired for 115V.
No problem with that as the service manual shows how to configure it for 230V.   :)
The voltage fine adjustment knob has a missing piece but that's not a big deal.
I rewired the little guy for 230V, swapped the US power cord with a CEE 7/4 ("Schuko") -plug cord.
After that I performed a quick test and checked the electrolytic caps. -They were all better than their spec.
As a result the little supply worked fine.
But the meter needed adjustment.  :-/O
After calibrating I was able to set the voltage and current to x.0 without external help (e.g. the dvm I used for checking). Very impressing.  :-+
The plus and minus terminals had to go and I replaced them with some modern HP-look-alikes I bought years ago.
The original terminals had to go:They don't hold the plugs of my lab cables because they're not deep enough.
Interestingly the ground terminal was of another, more modern type.
After all I'm quite pleased with this little power supply.   :)
And for TEA I ordered a Siglent 1104X-E today because I need a digital scope to take with me at meetings where I would have a bad feeling leaving my Agilent DSO-X 3034A alone..   :palm:
« Last Edit: February 24, 2019, 08:15:12 pm by URI »
The following users thanked this post: salvagedcircuitry
Online Specmaster
« Reply #26061 on: February 24, 2019, 08:49:41 pm »
I think your father was right and so are you, I remember Stansted being developed into becoming a fully operating airport as my father was actually working for one of the construction companies doing the development many years ago while I was still a child and I used walk around Stansted then and nobody cared. These days they is a massive police presence and their was a large armed police presence on the approach to the main terminal today. I have been stopped by police before because I standing close to the boundary fence and there was a time when nobody was allowed near the fence to observe the planes at all.
Online bd139
« Reply #26062 on: February 24, 2019, 09:13:26 pm »
Nice little supplies those. I got one off ebay about a year ago. Unfortunately the seller was a flipping idiot and it turned up in pieces :(
Does it buzz like a lot of HP supplies? Mine did. That always annoys the hell out of me (sorry if it annoys the hell out of you now I mention it!)
Yes everything changed big time in 2001 at least. I have been stopped by Stansted security as well for having a piss in a hedge  :-DD
Offline Neomys Sapiens
« Reply #26063 on: February 24, 2019, 09:59:17 pm »
I would rather stay away from such meetings istead of suffering the loss of just a screwdriver or test lead.
Where do you have to?
Offline tautech
« Reply #26064 on: February 24, 2019, 10:33:55 pm »
Some stuff Bean posted weeks ago finally arrived  :phew:
AVO probe tips and some RF adapter goodies.
Thank you kindly mate.  :clap:
Avid Rabid Hobbyist
Offline URI
« Reply #26065 on: February 24, 2019, 10:34:04 pm »
I can't complain. I just checked: When I put my ear on it I can hear it hum. Half a meter away it's barely noticeable. My 6114A's 50Hz hum is louder...    :popcorn:
« Reply #26066 on: February 24, 2019, 10:40:03 pm »
   Ok, while I was just reading and reading and reading I received a neat little power supply I got cheaply because it was equipped with a US power plug and wired for 115V. No problem with that as the service manual shows how to configure it for 230V.   :)   The voltage fine adjustment knob has a missing piece but that's not a big deal. I rewired the little guy for 230V, swapped the US power cord with a CEE 7/4 ("Schuko") -plug cord. After that I performed a quick test and checked the electrolytic caps. -They were all better than their spec. As a result the little supply worked fine. But the meter needed adjustment.  :-/O
After calibrating I was able to set the voltage and current to x.0 without external help (e.g. the dvm I used for checking). Very impressing.  :-+The plus and minus terminals had to go and I replaced them with some modern HP-look-alikes I bought years ago. The original terminals had to go:They don't hold the plugs of my lab cables because they're not deep enough. Interestingly the ground terminal was of another, more modern type. After all I'm quite pleased with this little power supply.   :)
The knob is easy enough to fix up passably with a little epoxy and a black marker (or repaint the whole thing if you're feeling froggy).
That screwcap on the (-) terminal though... you should for sure attack the red ring on it with a black Sharpie. Leaving it with two red rings like that is just taunting Murphy.  :-+
"It's not fair to tempt... and tempting fate is just stupid." ~ grandmother
Online bd139
« Reply #26067 on: February 24, 2019, 10:41:37 pm »
Red for all outputs is standard for HP. My 6236B:
Tallking of which if anyone has any knob caps for HP stuff lying around they don't want, I'm interested. The lack of them is grating on me to the point I nearly spent £40 on something to sacrifice just for the knob caps :-DD
« Reply #26068 on: February 24, 2019, 10:47:36 pm »
It's still stupid. To paraphrase Dickens: "If HP presumes otherwise, then HP is a ass."
[EDIT]
If I had that supply, I would immediately move the cap with the black ring to COM, then paint the ring on the removed cap green for the GND terminal. What do you guys over there use for EARTH GND... GREEN w/YELLOW Stripe, right? That would be harder... but still doable with a steady hand, or maybe a bit of pinstriping tape. If I lived there, it would be a regular part of my toolkit for sure.
[/EDIT]
 :horse:
« Last Edit: February 24, 2019, 10:59:55 pm by mnementh »
Offline factory
« Reply #26069 on: February 24, 2019, 10:57:49 pm »
I didn't know they were worth that much, but these are just begging for make a silly offer.
https://www.ebay.co.uk/itm/Hp-Agilent-Knob-joblot-HP-Rotary-Switch-Knob-Joblot/113617071108?hash=item1a741aec04:g:dQ4AAOSwoZJcCSdt:rk:8:pf:0
« Last Edit: February 24, 2019, 11:04:58 pm by factory »
« Reply #26070 on: February 24, 2019, 11:02:30 pm »
Wow... that's one for the "Are you high on CRACK?!?" chronicles.  :palm:
*poot!*
Online beanflying
« Reply #26071 on: February 24, 2019, 11:03:17 pm »
Slow Boat Via China  :-// At least they got there in the end :)
Coffee, Food, R/C and electronics nerd in no particular order :)
Offline GregDunn
« Reply #26072 on: February 24, 2019, 11:25:27 pm »
As promised, and for those who don't sit on the Repair forum and wait for new posts all day:   >:D
https://www.eevblog.com/forum/repair/hp-3468a-and-hp-3478a-new-acquisitions-(minor-cleanup)/
When I get the 3478A case squared up I'll add to the thread, but for now I'm just going to let them cook and see if there are any stability issues.
Offline URI
« Reply #26073 on: February 24, 2019, 11:46:54 pm »
Well, its two red marked terminals for plus and minus is common HP style. I'm used to it. Forces me to always check twice.   >:D
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #26074 on: February 24, 2019, 11:59:09 pm »
Funny, I just got one of those little buggers the other day, too - I'd been looking for one of the 12V ones for less than a small fortune, and finally found one to my liking. Took the photo Friday, then saw a bunny and forgot to post it.  They're nice little supplies, and I finally have at least one of each flavor.
-Pat
