Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 3447871 times)
Ice-Tea, Brumby, nfmax, Robert763, URI, SingleBitError, 25 CPS, capt bullshot, ch_scr, med6753 and 35 Guests are viewing this topic.
Online tggzzz
« Reply #27725 on: March 21, 2019, 03:35:37 pm »
I think that's because most of the early digital storage ones were crap! Case in point, this horrid thing which passed through my hands very quickly:
Yes indeed. Stunning ADC (and DAC) improvements have been made since the early/mid 90s. That was one of the disappointingly few major differences when I returned to electronics a few years ago. (Nanopower is the other).
At the same time it has led to "commidity integration" where every device is the same digital ARM black blob with some light weight analogue interfaces around the edge. As always I'm too late to the party to enjoy the good bits.
That's always been the case.
I have a Tek instrument where dividing a 5us pulse train down to 10us (and 10us to 50us, all the way down to 5s) is done by three transistors, a couple of diodes, a few resistors and capacitors.
TTL? Bugger that, even RTL and DTL were in the future!
Here's the schematic of three such stages...
« Last Edit: March 21, 2019, 03:42:12 pm by tggzzz »
Online bd139
« Reply #27726 on: March 21, 2019, 03:39:44 pm »
Similarly I've gone the other way. 144MHz from 12MHz with 4 transistors ... oscillator + x3 x2 x2
It's more fun!
Online tggzzz
« Reply #27727 on: March 21, 2019, 03:43:40 pm »
It's more fun!
That Tek instrument also goes from 10MHz to 500MHz, using minature valves (nuvistors) and some interestingly shaped bits of metal - as I posted earlier.
  • *Escaping The Suck*
« Reply #27728 on: March 21, 2019, 04:33:14 pm »
      I thought I would show my rough dc loads, used to proof test a 28V 35A linear PSU, it powered my 1.2GHz 350W PA for EME.
I didn't run them for too long as everything gets very hot esp me! So close to b-f design but mine are much rougher I am afraid.
ROUGH...?!? I'll show you ROUGH. But remember, ya MADE ME!!!
  :-DD
And for those who can't live without actual specs; since now I actually have a tool that will tell me:
Elements are 4 ea of : 1.8mm dia. steel wire wrapped around a 12mm deep socket as a former. Finished 18 turns, ~16mmID/20mmOD, approx 4.5mm spacing between turns. All measurements taken at 20.1°C Ambient. Fresh, cold tap water in bowl, as this is what is used for PSU testing.
1-DC Resistance Dry: 0.27Ω
2-ESR Dry @ 1KHz: 0.281Ω
3-Inductance Dry @ 1KHz: 22.7uH / Q=0.505
4-Capacitance Dry @ 1KHz: 1107uF / tan δ(D)=1.948
5-DC Resistance Wet: 0.24Ω
6-ESR Wet @ 1KHz: 0.259Ω
7-Inductance Wet @ 1KHz: 23.2uH / Q=0.561
8-Capacitance Wet @ 1KHz: 1091uF / tan δ(D)=1.781
Okay... so now you have some baseline specs on my "Coiled Coathanger Ballast Resistor"; you can actually make use of it if you desire. These figures coincide pretty well with the calculated value of 0.304Ω from the demonstration photo above.  :-+
I've confirmed in use that bypassing individual elements results in linear current increase, so each element will be 1/4 of these values.  :-+
"Nothing succeeds like excess." ~me
« Last Edit: March 21, 2019, 04:54:12 pm by mnementh »
Offline worsthorse
  • aina varma, usein väärin
« Reply #27729 on: March 21, 2019, 05:13:07 pm »
Been playing with 10MHz OCXO's and wanted another dedicated power supply I could run for some long term testing.  Found what looked to be a clean, late version HP 6227B (0-25v, 0-2A, dual channel) on eBay not to far from me.  This was the only test equipment item in the sellers store, so I made an offer for $75 from the $135 asking and they accepted.  Shipped fast, and very well packaged which was a pleasant surprise.  Its in better shape than I had hopped for, appears 100% original and no signs of any work.  I am seeing some ripple at max load, more so from the main channel.  The main filter bank caps do appear week, and C10 on the master regulator board needs to be replaced, but this is to be expected.  The hunt is on for some caps, but well worth it for such a nice peace of gear, they don't make things like they use to.
nice bit of kit and very nice photos. Thanks for posting!
i returned to building electronics after a thirty-five year break.  i haven’t been that far away that the black blob phenomena was a surprise; i just wasn’t interested in hanging in that playground.  my solution was to assemble a state of the art lab, circa 1984, and to build stuff from books like solid state design for the radio amateur . the last couple of years has been as much about finding gear and parts, and rehabbing gear as about building circuits.  it continues to be an awful lot of fun, especially when i get some old piece of test gear running like it did the first time i encountered it in 1980.  and i hang out here because i like knowing there are folks that enjoy this stuff as much as i do.
Online bd139
« Reply #27730 on: March 21, 2019, 05:19:17 pm »
You're certainly in good company. On the bench...  :-DD
I was building filters earlier and it covers those nicely.
The following users thanked this post: worsthorse
Offline 0culus
« Reply #27731 on: March 21, 2019, 05:20:13 pm »
I approve of the shameless RPN plug.  :-DD
Online bd139
« Reply #27732 on: March 21, 2019, 05:21:37 pm »
Wasn't intentional but the equals button fanboys can take your button and stick it where the sun doesn't shine  :-DD
« Reply #27733 on: March 21, 2019, 05:22:42 pm »
Tubes are quite easy to blow up from experience, at least when in my hands  :-DD
Yep they sure are if you drop them[emoji1787]
Brymen-Fluke-Solartron-HP-Thurlby-Heathkit-Thander-Tek-Extech-Black Star-GW-Advance-Avo-Kyoritsu-Amprobe-ITT-Robin-TTi
« Reply #27734 on: March 21, 2019, 05:28:15 pm »
Quote from: kj7e
Been playing with 10MHz OCXO's and wanted another dedicated power supply I could run for some long term testing.  Found what looked to be a clean, late version HP 6227B (0-25v, 0-2A, dual channel) on eBay not to far from me.  This was the only test equipment item in the sellers store, so I made an offer for $75 from the $135 asking and they accepted.  Shipped fast, and very well packaged which was a pleasant surprise.  Its in better shape than I had hoped for, appears 100% original and no signs of any work.  I am seeing some ripple at max load, more so from the main channel.  The main filter bank caps do appear week, and C10 on the master regulator board needs to be replaced, but this is to be expected.  The hunt is on for some caps, but well worth it for such a nice piece of gear, they don't make things like they use to.
Before you go writing off any of those caps, I'd physically remove them and confirm it's not just crusty pads/posts on the caps. I can't count the number of such PSUs I've restored to former glory with just a little patience and a $2 pack of detail brushes from Horror Fraught. Fiberglas pen scrubbers are magical on tinned traces.
Of course if you're aware of all this, just chalk it up to advising the next guy who comes along who might not be.  :-+
Cheers,
*Lunch-ily*
« Last Edit: March 21, 2019, 05:50:06 pm by mnementh »
The following users thanked this post: kj7e
Online med6753
« Reply #27735 on: March 21, 2019, 05:36:44 pm »
Are you sure that doesn't say "How NOT to blow shit up"?  >:D >:D :P :P :-DD
The following users thanked this post: InductorbackEMF
« Reply #27736 on: March 21, 2019, 05:40:58 pm »
You're certainly in good company. On the bench...  :-DD      I was building filters earlier and it covers those nicely.
He's still working on the code for that feature set.:-DD
"Start with fire; work your way back from there."
« Last Edit: March 21, 2019, 05:52:39 pm by mnementh »
« Reply #27737 on: March 21, 2019, 05:48:42 pm »
   2430 Digital (Top) vs 2465 Analog (Bottom). Both in the 1986 Tek catalog. 2430 b/w 150MHz. 2465 b/w 300MHz. One must have really wanted a DSO in 1986. Why? 2430 cost $8900 USD. 2465 cost $5350 USD. Quite a difference.  :scared:
Well yeah... the ability to capture nonrepetitive events was a game-changer back then; one of the Holy Grails of scope design. Along with ever-shorter risetimes, which was one of the 24xx series strong points.  :-+
Looks beautiful to me... empirical proof that DSO and CRO can not only peacefully coexist, but will in many cases happily cohabitate as well.  :-DD
"No electron gun, no sale." ~ old man Kirsch
And even in the same case as well as demonstrated by my combiscope, not only that, but the combiscope even cohabitates with my DSO (TDS210) which is a feat that my cats can't do and they are sisters FFS, if they get too close there is a lot of hissing and paw waving going on  :-DD
Online med6753
« Reply #27738 on: March 21, 2019, 06:01:59 pm »
Actually the case on the 2430 is about 2 inches longer in back than the 2465.
Online med6753
« Reply #27739 on: March 21, 2019, 06:05:26 pm »
Look at this. Bastard tant! The 47uf tant on the primary input to the HV oscillator. Shorted and took out the fuse. Always change this cap!  :phew:
Then he opens up an older 465 and it shows the 2 - 22uf tants in parallel. Get rid of them too.
Online bd139
« Reply #27740 on: March 21, 2019, 06:09:56 pm »
Yeah that cap is why I usually buy the ones with failed HT. it’s 99% likely to be that and takes about two minutes to fix. I actually gave fuses in stock in case another scope comes along  :-DD
Offline 0culus
« Reply #27741 on: March 21, 2019, 06:19:58 pm »
Interesting. It's a nice looking scope, maybe primitive compared to later DSOs, but at least it only has soft keys rather than full fledge menus!
Online PA0PBZ
« Reply #27742 on: March 21, 2019, 06:29:00 pm »
Is that cap really saying 80uF, 0-65VDC?   :o
Offline kj7e
  • Damon Stewart
« Reply #27743 on: March 21, 2019, 06:31:43 pm »
Cheers,
*Lunch-ily*
Before I powered it up, I had removed the caps to inspect/clean and run up the voltage on them slowly.  They are weak, but I found some nice replacements from Mouser for about $11/pop and in-stock.
« Last Edit: March 21, 2019, 06:35:00 pm by kj7e »
Offline kj7e
  • Damon Stewart
« Reply #27744 on: March 21, 2019, 06:34:23 pm »
Yeah, and that's C10 on the master reference board.  Its a common part on these supply's that needs to be replaced.  I think I will replace it with a fixed working voltage part though  ;D
« Reply #27745 on: March 21, 2019, 06:35:43 pm »
Yup; was a Sprague nomenclature "thing" back in the day. Took oodles of those out of my 2230. It always made me chuckle.  ;)
*p00t!*
« Reply #27746 on: March 21, 2019, 06:38:17 pm »
Wow, that scope is well travelled, all the way from my old stomping ground, BBC TV Centre, Wood Lane, London W12, that place was swimming with Tek scopes. I really should have got one from them at the time when they switched over to digital ones but I was in my hiatus with electronics then due to having a very young family and sod all money to  spare  :palm:
« Reply #27747 on: March 21, 2019, 06:48:36 pm »
Yeah, and don't forget its brother and cousins on the same board.  :palm:
I've come to hold a healthy loathing for large-value axial caps over the last few years; cost on them is ducking insane, IF you can find something even reasonably close to substitute. |O
*Breathe... just breathe...*
« Last Edit: March 21, 2019, 06:52:52 pm by mnementh »
Online med6753
« Reply #27748 on: March 21, 2019, 06:54:56 pm »
I've grown a healthy loathing for large-value axial caps over the last few years; cost on them is ducking insane, IF you can find something even reasonably close to substitute. |O
If there's enough headroom I will substitute a radial cap and put shrink tubing on the leads. Done that on several of my Fluke DMM's.
« Reply #27749 on: March 21, 2019, 07:13:30 pm »
Cheers,
*Lunch-ily*
Did you try Tedds ?
https://www.tedss.com/Capacitors/Browse/aluminum-electrolytic-large-can-computer-grade
Avid Rabid Hobbyist
