Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 14901009 times)
Carl_Smith and 183 Guests are viewing this topic.
« Reply #34950 on: July 16, 2019, 11:29:25 pm »
Well I had to think long and hard about flipping my analogue scopes, some of which were only about 15 years old but when I got my Combiscope, I had to let let them go, no room. I can honestly say that I have not missed them at all and how nice it is to be able to switch something on and know that it is going to function correctly. I don't think I'll ever need a more powerful scope, not for my area of interest. I think it will see me off, but I do miss the rotary switches of an older analogue, easier to operate.
« Reply #34951 on: July 16, 2019, 11:43:07 pm »
Are you sure that isn't a feature?  :-DD
Well that is a very impressive tally over the years, but maybe the older scopes are getting just a bit to old now and its about time they were allowed to die in peace? The 453 lasted from 1965 to 1974 so they could anything from 45 to 54 years old now and at just 10 hours a week over its life, its had an awful amount of stress and things like multipliers are bound to be extremely fragile by now. So then whats your plan now, start looking at scopes from say the late 80's to 90's or is that it, done now for all time?
Completely agree with all points. The statistical rate of failure is too much of an enthusiast thing now to fight and honestly I don't have the time. You either have to go simpler or newer. Thus I'm going to stick with the DS1054Z as my one and only scope now and give up the analogues. Once they fix all the stuff in the MSO5000 and it's readily crackable I'll hit that. The whole journey has been productive for sure and Jim Williams was very much right with the assertion that a broken scope is an effective classroom. I've learned a hell of a lot of design and diagnostic tricks.
As for what's next, I don't know. Perhaps the Tower of Flukes needs to happen but no more scopes at all!
I give it a week before you're Jonesin' for the smell of warm dust and capacitors!  :-DD
Hmmm... low hours scope... means good healthy CRT. Hmmmmm...
« Reply #34952 on: July 17, 2019, 12:21:34 am »
Found the 2 problems on the S-3 Electronic Switch but now have a new problem.
I don't have a manual for this unit, just a schematic. So when I disassembled it I removed the tubes as they were plugged and wrote down their locations. (There's no markings on the chassis). Upon reassembly I plugged the tubes back in the same locations as I had originally found them. Well guess what?? Four tubes....two 12AU7's and two 12AX7's were swapped. In the wrong sockets. That damn gorilla again.  |O Once again had to shovel his crap.  :palm:
Straightened out that mess and here's the result. Almost there. "B" input, the square wave, has garbage on it. I just have to do some scoping around to find out where it's coming from. But it's been a long day so I'll tackle this in the AM.
Offline tautech
« Reply #34953 on: July 17, 2019, 12:50:54 am »
 :-DD
LMAO as you're using a 475 like bd just blew up.  ;D
Nuthing like rubbing it in !  :horse:
Avid Rabid Hobbyist
« Reply #34954 on: July 17, 2019, 01:02:02 am »
:-DD
Gee....wasn't intentional but now that you mention it.  >:D :P :-DD
Offline tautech
« Reply #34955 on: July 17, 2019, 01:04:04 am »
:-DD
Yeah right  ::) you're just evil !  >:D
Avid Rabid Hobbyist
Offline Neomys Sapiens
« Reply #34956 on: July 17, 2019, 01:06:17 am »
Today I was looking for a book and found in a box these nice ones:
So? How many volumes of the Telefunken Laborbuch?
Just only this reprint. Do you collect them?
No need to collect, as I have all 6 of them. :D
« Reply #34957 on: July 17, 2019, 01:10:46 am »
:-DD
Who? Me?  :popcorn: :-DD
Offline tautech
« Reply #34958 on: July 17, 2019, 01:11:19 am »
Biggest order I've made just arrived, a dozen assorted DSO's, couple of E loads and half dozen PSU's plus some other bits and bobs.
Finally I have 20+ scopes in the stable.  :phew:
Plus the other 1/2 dozen busted ones to fix saved for a rainy day.
And yet more are about to leave the factory !  ::)  :horse:
Avid Rabid Hobbyist
« Reply #34959 on: July 17, 2019, 01:32:04 am »
Not all evilbay sellers are created equal  :-+ Makes up for the other slightly tweaked bit of actual TEA that arrived today.
Brought on a whim but will finish up in the kitchen for weighing spices while my 0-100g good electronic ones can live in the shack permenantly. Woodwork will get a proper going over before it gets to the kitchen.
Online Kosmic
« Reply #34960 on: July 17, 2019, 02:14:24 am »
Little update on the HP 53310a.
Since electrolytic was poring out of the PSU I recapped the whole thing.
So decided to do a quick test just after, half expecting a success. But nothing happen. The PSU was just dead.
Quickly started debugging the primary and found 2 open resistors. So apparently the electrolytic all over the board shorted the 2 pins of C3 and R13 and R14 just died with all the current flowing through them. The funny thing was that the main and secondary fuses were fine.
Replaced the 2 resistors, double checked everything on the primary side, and everything looked in order this time.
Tried another power on. So the good news is the psu is alive now but the bad news is that he is suffering from a bad hick-up. Probably got something on the secondary side loading one of the power rails.
« Last Edit: July 17, 2019, 02:20:52 am by Kosmic »
The following users thanked this post: kj7e
Offline kj7e
  • Damon Stewart
« Reply #34961 on: July 17, 2019, 02:24:52 am »
^ Make sure you test it in circuit, it needs a load otherwise it will "tick".
Online Kosmic
« Reply #34962 on: July 17, 2019, 02:28:12 am »
Yes I did it's a no go  :-BROKE
Offline 0culus
« Reply #34963 on: July 17, 2019, 03:29:12 am »
Took possession of my new home today...now to load up all the test equipment and get it moved into my new lab space. It's going to be a heavy day tomorrow...  :scared:
The following users thanked this post: kj7e, worsthorse, beanflying
« Reply #34964 on: July 17, 2019, 03:33:31 am »
Congrats! Pix of the new bench area required once set up.  :-+ :-DD
Online Kosmic
« Reply #34965 on: July 17, 2019, 03:34:11 am »
Heeeyy congrats  :-+ always a big adventure buying a new house  ^-^
Offline 0culus
« Reply #34966 on: July 17, 2019, 03:36:28 am »
I'll definitely get some pics once I get it set up. No real benches for now, using a couple of 6 foot folding tables plus my heavy duty job site bench for the heavy stuff. Need to recover from all the money I've been hemorrhaging this past month to get this done.  :-DD Then I've got my eyes on some nice benches from Bench Pro.
Offline worsthorse
  • aina varma, usein väärin
« Reply #34967 on: July 17, 2019, 03:54:54 am »
Bastard tants!  :rant: :rant: :rant: :-DD
Bastard tants, indeed.
Change 'em right away. Don't change 'em. Change these but not those. Wait til they go to change 'em. Whatever you choose, you are likely to be wrong.  ;D
« Reply #34968 on: July 17, 2019, 04:28:24 am »
I found it!
Copied and pasted from a post to the HPAK mailing list explaining the serial numbering system; the original author worked for HP:
Thank you, Pat! I've added it to the POI (with some bold highlight ^-^).
« Reply #34969 on: July 17, 2019, 04:51:51 am »
Just a quick postscript. I am now officially giving up on restoring old Tektronix scopes. I'm thoroughly done. Many have passed through my hands now and I am not going to do any more. I need a new challenge. Here's the tally though. I think I did good considering everything I bought was broken or for scrap or was supposedly working but wasn't or wasn't shown as working...
Restored (20 scopes)
- 3x 475
- 2x 475A
- 5x 465
- 3x 465B
- 2x 453
- 1x 2235A
- 3x 2225
- 1x 7603
Scrapped (5 scopes)
- 1x 465B
- 1x 465
- 1x 475
- 1x 453
- 1x 2235
I'm not including the 5x Philips, 2x Hameg, 2x HP, 1x Thurlby, 2x LG, 1x Hitachi, 6x Telequipment (3x D83, 2xD61, 1xS61) ones on top of that as well  :-DD
Phew  :phew: ...
Holy high tension, Batman. Just looking at your list makes me tired. Tek retirement duly earned. :-+
« Reply #34970 on: July 17, 2019, 05:08:20 am »
That's a lot o' caps! What made you use axials in there? Convenient stock? People are usually doing just the opposite since axials cost more.
Hope you get the power supply sorted. Looking forward to seeing how this 53310A runs.
« Reply #34971 on: July 17, 2019, 05:09:36 am »
Talk about a big purchase! Congrats, 0culus! :clap:
« Reply #34972 on: July 17, 2019, 06:56:07 am »
The MSO5000 looks frustratingly slow though.
It’s not that bad actually. I think of it as fractionally faster than a DS1054Z. I played with one on the rigol stand for a bit at Kempton.
Online TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #34973 on: July 17, 2019, 07:09:10 am »
I'm hoping someone here might be able to help me out...
In restoring my Fluke 332D Voltage Standard, I found that the extender card is missing, which makes troubleshooting a pain in the arse...
Does anyone have one they're willing to sell, or have the connectors shown in the attached images, either loose or on salvaged/faulty boards etc?
« Reply #34974 on: July 17, 2019, 08:36:11 am »
Anyone interested in an old but looks in good condition Cossor 1035 MkIII scope? Someone in Fleetwood has one on Shpock and is open to offers?
Sent from my POT-LX1 using Tapatalk
