Marck, beanflying, Jambalaya, Ingeniq, Brumby, Zucca, Emo, Saskia, BU508A, Ero-Shan, VK5RC, morris6, med6753 and 17 Guests are viewing this topic.
As suggested by Specmaster. And a damn good suggestion it was. And here's the results. A folding side table on the scope cart (trolley). I was somewhat limited in how large I could make it but it does accommodate a typical manual. But a little problematic if it has fold-outs.
Quote from: factory on August 20, 2019, 09:29:39 pmDavidP.S. How long will it be before your looking for one of these to check that gauge against? No, the bigger question is how long before he blows himself up?
Quote from: mnementh on August 20, 2019, 07:48:43 pmAnd Now For Something Completely... ON-TOPIC!!!mnemIt had to happen sooner or later.So which came first, the Sprague Yellow Jacket capacitors or the company that makes those gauges? DavidP.S. How long will it be before your looking for one of these to check that gauge against?
Quote from: med6753 on August 20, 2019, 09:54:13 pmNo, the bigger question is how long before he blows himself up? One of these instead then.
Quote from: med6753 on August 20, 2019, 07:07:21 pmAs suggested by Specmaster. And a damn good suggestion it was. And here's the results. A folding side table on the scope cart (trolley). I was somewhat limited in how large I could make it but it does accommodate a typical manual. But a little problematic if it has fold-outs. Nice job, glad I suggested that now, of course it can be used for other things if need be [emoji106]
No.mnem
Quote from: Specmaster on August 20, 2019, 11:26:42 pmQuote from: med6753 on August 20, 2019, 07:07:21 pmAs suggested by Specmaster. And a damn good suggestion it was. And here's the results. A folding side table on the scope cart (trolley). I was somewhat limited in how large I could make it but it does accommodate a typical manual. But a little problematic if it has fold-outs. Nice job, glad I suggested that now, of course it can be used for other things if need be [emoji106]Yeah, like lunch and your favorite beverage while tinkering.
Or the oscilloscope you're using to fix your oscilloscope... mnemagain.
Has to be hefty in order to carry the weight of his coffee bucket
That is a pretty impressive shelf. And it will always have the service manual on it
Quote from: bitseeker on August 19, 2019, 04:19:31 amThose images look great. I checked out some videos, too. Very clear, unlike the scopes from just a few years earlier. The ADSM302 is this year's model with twice the working distance (up to 22cm), but the 301 seems just fine (up to 12 cm), considering the lower cost, the same resolution, and the same frame rate.Help me! It looks like I'm getting one, now. Order submitted. I can't help you now it's too late. The base is solid aluminum but it's not great for laying a board on because it's too slippery-slidey. Just need to put on a material to help a board stay put. Looking at some options like a piece of ESD mat. I did some soldering with it yesterday and was very pleased with how it went. Took another pic for you at full magnification.
Quote from: mnementh on August 20, 2019, 03:56:10 pmNo.mnem I'm convinced, Carole King has meant you with this song:
Four pages of catch up... That's what I get for being busy elsewhere, but there were some gems - and I'm not including the monkeys.
Quote from: Specmaster on August 21, 2019, 01:25:32 amHas to be hefty in order to carry the weight of his coffee bucketHey... I strongly resemble that remark... mnem (Attachment Link)
Quote from: xrunner on August 19, 2019, 12:24:53 pmQuote from: bitseeker on August 19, 2019, 04:19:31 amThose images look great. I checked out some videos, too. Very clear, unlike the scopes from just a few years earlier. The ADSM302 is this year's model with twice the working distance (up to 22cm), but the 301 seems just fine (up to 12 cm), considering the lower cost, the same resolution, and the same frame rate.Help me! It looks like I'm getting one, now. Order submitted. I can't help you now it's too late. The base is solid aluminum but it's not great for laying a board on because it's too slippery-slidey. Just need to put on a material to help a board stay put. Looking at some options like a piece of ESD mat. I did some soldering with it yesterday and was very pleased with how it went. Took another pic for you at full magnification.Nice.Now I officially hate you. (Now, where's that link....?)
Here, especially for Down Under:https://www.ebay.com.au/itm/183855334498
Tggzzz, if you get a chance to open up your 485 this week these are the parameters you should set up on yours to match my readings. This set up should result in a trace but trigger light OFF. My trigger light is on.Scope set up:Channel 1: 1v/div, GND. No signal.Int Trig set to channel 1Time/div set to 1mSHoriz Display to ASweep Mode to Auto TrigSlope to +Level to slightly negativeA Trig Coupling to ACA Trig Source to INTDC voltages on U780:<copied below>
Quote from: med6753 on August 19, 2019, 10:31:20 pmTggzzz, if you get a chance to open up your 485 this week these are the parameters you should set up on yours to match my readings. This set up should result in a trace but trigger light OFF. My trigger light is on.Scope set up:Channel 1: 1v/div, GND. No signal.Int Trig set to channel 1Time/div set to 1mSHoriz Display to ASweep Mode to Auto TrigSlope to +Level to slightly negativeA Trig Coupling to ACA Trig Source to INTDC voltages on U780:<copied below>I've highlighted the differences I suspect are significant. med tggPin 1 +0.495V -27mV Pin 2 +0.0789V 71.4mVPin 3 +0.3027V -284mVPin 4 +4.981V 4.97VPin 5 -4.961V -5.01VPin 6 +0.0291V 5.44VPin 7 +0.4347V 5.55VPin 8 +0.6746V 604mVPin 9 0 0Pin 10 0 unstablePin 11 +5.518V 5.55VPin 12 +0.0108V 5.5mVPin 13 0 0Pin 14 +4.945V 4.91VPin 15 +0.8714V 891mVPin 16 0 1.2mVPin 17 -0.4684V -505mVPin 18 0 0Pin 19 0 0Pin 20 +4.980V 4.98VThe scope traces for pin 17, J816, Q816 base are very similar.The positive going pulse on pin 16 is around 100ns wide and 2.5V high, the low duty cycle makes it very dim on an analogue scope.Using the conditions on diagram 6, most of my U780 voltages are similar to the diagram - but not pin 2 which is 77mV instead of 9mV (surprising since it looks like a bias setting from a voltage divider). Pin 3 is very similar which implies it is an output, not (as I guessed) a bias input. A scope trace of pin 1 shows an ~400mV output which falls to 0mV at the sweep interval.My approach would be to check decent waveforms at the input to the tunnel diode section, i.e. u740.9 and u740.5 TPcheck values of R791, R792, since they are the load to u780.3check decent waveforms coming out of the tunnel diodes, especially u780.1fettle with the tunnel diode pots "between" u740 and u780 to try to get good waveforms hitting u780
