Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 2025036 times)
tautech, Brumby, Kosmic, med6753, Black Phoenix, mnementh, Andy Watson, wilfred, syau and 30 Guests are viewing this topic.
« Reply #41450 on: October 18, 2019, 05:53:52 pm »
I cannae deny it; may as well own it.   :-+
Quick!  Convert that to TEK 547s. :-DD
Twelve.
IF you fill the remaining space with helium balloons. >:D
I ROM it to 17500...
looking across my lab, I'd guess a 547 is 10x10x15 ping pong balls...
so go about 260000 div by 15
Most air freight is by weight rather than volume.
Offline worsthorse
  • aina varma, usein väärin
« Reply #41451 on: October 18, 2019, 06:17:56 pm »
Or stick arouind and let us assist you with a mental shoehorn so you can fit your collection into an Apartment like @med has  >:D
Yeah...  I mean, you can always raise your bed a bit for a little extra storage space underneath - or put one in the lounge room with a cushion on top and call it a pouffe.  Two of the same height with a plank of wood across the top makes for a sturdy coffee table.
Channel your inner MacGyver.
;D
(Attachment Link)    Yeah... bedframes with metal or wooden slats like these are cheap ($100-ish), and they do away with the useless box-spring or "foundation" to give you oodles... just oodles of storage space underneath. I kept 6 55L storage tubs under each of the kids' double-size mattress beds with these frames.  :-+
"Very helpful... very helpful indeed..." Chibila thought to himself...
Good Lord Man... you've just spent the last six months digging out of your current predicament and trying to fit what was left into a convey of trailer trucks and you're encouraging this innocent young soul to start buying 55L containers?
HAVE YOU NO SHAME?
 :-DD   :-DD   :-DD
Offline worsthorse
« Reply #41452 on: October 18, 2019, 06:20:12 pm »
Wow, I'm surprised. The answer is RIGHT THERE.  |O
voltage readings are wrong I think. now I have to read ahead to the proper current end of the thread to find out if I am wrong.
 ;D
edit: i was correct. i am going to bask in my self-generated glory for a while before posting again.  >:D
« Last Edit: October 18, 2019, 06:35:29 pm by wch »
Offline worsthorse
« Reply #41453 on: October 18, 2019, 06:28:51 pm »
Vintage high-end TE is like many mid 90's and earlier vehicles - They were solid designs and builds. So solid that people ran them for decades with minimal maintenance, but now the neglect is showing and overhauls are necessary. You get what you put in, though, and if you take the extra time to inspect and clean everything during the course of your repairs, they'll be set to last for another couple decades.
Agreed... solid, and usually, straightforward designs and builds. I have Tek gear that was calibrated in 1987, put in storage in 1988, and not turned on again until 2019 (you do the arithmetic) and it generally just works. Most of the repair work I've done over the last six months has involved replacing bad caps, cleaning switches, and tweaking calibration.
Granted, I've been working mostly on signal generators, DMMs, and the like that all operate under 100MHz and I've not spent a lot of time working on oscilloscopes, but still... a lot of bang for the buck left in this old gear. (as I demonstrated when I shorted the plus and minus 150VDC rails through a 2W resistor last week)   ;D
Offline bsudbrink
« Reply #41454 on: October 18, 2019, 06:36:23 pm »
Look at the “fine print” in my PS for the “why” behind my “conservative” estimate. ;)
Ah.
Why do I smell smoke...?
From the jet engine as it whooshed over my head?
Online mnementh
  • *Escaping The Suck*
« Reply #41455 on: October 18, 2019, 06:54:26 pm »
IF... that CA5 is getting a helium-balloon assist in lifting the weight of those dozen dark-matter-laden 547s, yes. Otherwise, just going to be some very noisy taxiing.   ;)
 :bullshit:
Online mnementh
« Reply #41456 on: October 18, 2019, 06:59:56 pm »
HAVE YOU NO SHAME?
 :-DD   :-DD   :-DD
*extends paw in customary greeting* Hi... my name is mnem! Have we met...? :-DD
*enabler-dwagon*
« Last Edit: October 18, 2019, 07:02:37 pm by mnementh »
The following users thanked this post: worsthorse
Offline bsudbrink
« Reply #41457 on: October 18, 2019, 08:00:12 pm »
They can only put 4 M1A1s in a C-5...
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #41458 on: October 18, 2019, 08:13:11 pm »
It can only carry FOUR 63 ton tanks at a time?  What a piece of crap!!  /s   >:D
Even knowing how airplanes work, it still amazes me that you can get one off the ground with not one, but four main battle tanks in it.   :o :o :o  (Just be damned sure to tie them down tightly - if THAT load shifts it will definitely ruin your day.)
-Pat
Offline bsudbrink
« Reply #41459 on: October 18, 2019, 08:14:41 pm »
-Pat
Yea, but we're talking Tek 547s here...
Offline worsthorse
« Reply #41460 on: October 18, 2019, 08:18:09 pm »
-Pat
And don't forget to put air in the tires before loading.   ;D
Online Mr. Scram
  • Display aficionado
« Reply #41461 on: October 18, 2019, 08:52:08 pm »
You're trying to trick us! Tank tires don't have air in them!  ;D
Offline worsthorse
« Reply #41462 on: October 18, 2019, 10:26:04 pm »
Oh my. The USPS carrier left this on my porch about fifteen minutes ago:
Giant packaging fail. What was the seller thinking?  |O
The worst thing: I bought this stuff as a lot. There is no inventory of it and I will not be able to figure out what was lost.   |O
And USPS couldn't even be bothered to slap a label on it noting the damage, let alone some packing tape.  |O
Offline ArthurDent
« Reply #41463 on: October 18, 2019, 10:32:56 pm »
IC the damage.  :-DD
« Reply #41464 on: October 18, 2019, 10:56:33 pm »
Until the phosphor starts flaking off the inside of the unobtanium CRT... or it just plain goes dim or fuzzy. :o
Denial: Not just a river, etc... ;)
"If a man made it, a man can fix it."
"Everything ever made is living on borrowed time." ~ Grand-dad
Hopefully I'll be dust before that happens.  8)
Again.....don't you have some looooooong driving to do?  :-// :-//
Wasn’t it you who just a few dozen pages back had to replace a fuzzy CRT...?  ;)
Looooong driving is done. Everything that remains is nice short 3-4 hour chunks.  ;D
 :popcorn:
What, thought that you'd have gone straight to your new home and be getting it ready for your bench, and finding some neat storage locations for your pile of gear  :-DD
Online mnementh
« Reply #41465 on: October 19, 2019, 01:26:13 am »
IC the damage.  :-DD
Grooooannnnn!!! *Tosses soggy ol’ boot right at Arthur’s digital watch* :palm:
Online Black Phoenix
  • Country: hk
« Reply #41466 on: October 19, 2019, 01:30:07 am »
Local Area Network in Australia. The LAN down under...  :-DD
Online xrunner
  • hp>Agilent>Keysight>?
« Reply #41467 on: October 19, 2019, 01:44:59 am »
It's shocking how often I electrocute myself.  :P
I am a Test Equipment Addict (TEA) - by virtue of this forum signature, I have now faced my addiction
Offline Neomys Sapiens
« Reply #41468 on: October 19, 2019, 01:45:38 am »
Today was a good TEA day. I received my basically like-new -hp- 8672A synthesized signal generator. And I went from 1 Tek P6042 to 3, plus some spare unobtainium transistors and cabling to replace the bad probe cable on the one I got with a pile of Tek gear at hamfest.  :-+
If you connect the Analogic2045 as modulation generator and add a decent amplifier I can see some monitoring bozos quitting their job on a mental sanity ticket.
 >:D
Online 0culus
« Reply #41469 on: October 19, 2019, 02:52:32 am »
 >:D
Man, that's evil. I'd like to keep my amateur license though!  :-DD
Offline fanta
« Reply #41470 on: October 19, 2019, 07:52:50 am »
Thanks to everyone for their help, unfortunately I can't quite get away with stuffing that much equipment under my bed  :-DD. I've thrown up a post in the buy/sell/wanted section, fingers crossed.
The following users thanked this post: mnementh, beanflying
Online beanflying
« Reply #41471 on: October 19, 2019, 08:13:07 am »
$2 AUD HP Logic analyser in Eastern Sbs Melbourne  :o  eBay auction: #303327468857 Jump fast for an Anchor locals.
Coffee, Food, R/C and electronics nerd in no particular order :)
Offline tggzzz
« Reply #41472 on: October 19, 2019, 08:26:52 am »
 >:D
Or have black helicopters hovering overhead.
I was once an arms importer. I imported an HP boat anchor that was a DDS plus hardware for modulating the output each sample. Allegedly it could spoof military aircraft (etc etc), and so for export puposes it was classified as a munition.
The following users thanked this post: bd139, Kosmic
Online bd139
« Reply #41473 on: October 19, 2019, 09:21:05 am »
Lots of stupid shit like that out there. I remember the stupid crypto munitions export laws in the US. Guess who was responsible for filling in the paperwork so the US subsidiary could export it to the UK subsidiary.  :palm:. Haha but you couldn’t file the declaration unless it was sent over a secure channel. Which we didn’t have because you couldn’t import it. So we had to get the home office involved to declare a 2m square bit of ground as US territory for a week, pop a couple of cryptos in onto one of the dark networks. Whole thing was a joke.
Edit: oh and two weeks after we fixed all that, Clinton relaxes the restrictions
« Last Edit: October 19, 2019, 09:23:03 am by bd139 »
Online Brumby
« Reply #41474 on: October 19, 2019, 09:44:02 am »
Sorry.  If I was to have my own aeroplane, I doubt it would be a C130.
Of course not.  Clearly insufficient for the task.  Any TEA'r would need a C5A.
I thought about that after I posted ... then I thought I'd wait and see if someone would pick up on it.
I didn't have to wait long.
