Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 2858199 times)
capt bullshot, Zoli, mansaxel, cyclin_al and 17 Guests are viewing this topic.
« Reply #50850 on: February 27, 2020, 03:10:27 pm »
Could have rolled it down the stairs  :-DD
Offline SilverSolder
« Reply #50851 on: February 27, 2020, 03:33:50 pm »
You haven't lived until you've tried lugging a 1970's 26" colour TV up a flight of stairs on your own...   They must have weighed around 50Kg, more if there was a fancy wooden enclosure with shutters etc.
When I was in the 20ies, I've moved around a WEGA 3062 color TV set. Two stairs up. Alone. Wasn't really funny.
Two things to notice about our 20ies:  (1) we were amazingly strong, and (2) amazingly stupid.
When my car wouldn't start, I remember pushing it up a small incline nearby, then I would run round to the driver's door, jump in and let it roll down the hill again, then start it by dumping the clutch in 1st gear.   Today, I think I'd have gotten around to changing the battery!   :-DD
« Reply #50852 on: February 27, 2020, 03:47:41 pm »
Testosterone is hindering logical thinking.  :-DD
The following users thanked this post: SilverSolder, mnementh
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #50853 on: February 27, 2020, 04:00:05 pm »
Shouldn't be this far of..
(Attachment Link)
This is how volt-nuttery starts, isn't it? Who's to blame? Meter or reference? I must buy more stuff, obviously...
Without doubt, the reference is the problem. I have one of those, from RoadRunner here on the forum which was adjusted by him to 10.00000V before he posted it to me.
The day before yesterday, I put it on the calibration lab's Fluke 8508A and it read 10.0005275V.
Heh, well, I don't know. The order of magnitude of the difference isn't that far of what one might expect from a few years out of cal instrument.
On the other hand, I had some Fluke 8842s around some time ago and they also pointed to an offset of the reference as well...
« Reply #50854 on: February 27, 2020, 04:02:35 pm »
That's better. Tek 2245 for scale
Another monitor and arm arriving Saturday.
Previous crowding issue, hopefully now resolved :)
Edit: there's space to the left still for a whole half rack with of HP goodies (couple of power supplies, DMM, 3312A planned)
« Last Edit: February 27, 2020, 04:16:00 pm by bd139 »
Offline worsthorse
  • aina varma, usein väärin
« Reply #50855 on: February 27, 2020, 04:09:49 pm »
You have to point your router’s DNS server to an upstream DNS server which it can get that info from. If it works out of the box it’s using the resolver on the box which is probably configured by your ISP or uses OpenDNS or google DNS upstream.
Your PC is told where the DNS server is on your local network when it gets its IP address via DHCP.
If you add a PiHole to your network all you’re doing is sticking another box in there and telling your router to use DHCP to tell everyone to use the PiHole dude for DNS.
No, that is not how it works.
In DNS we talk about 3 different actors;  name servers, full-service resolvers, and stub resolvers.
  • The name server is loaded with data from a file. It answers queries from that, and nothing else.
  • The full-service resolver is configured with a special set of name server addresses to boot-strap from, the root servers, and nothing else. The rest, it can recursively find by asking the root and traversing the tree.  It then caches this data.
  • The stub resolver is the libraries your application are linked with in the end node. They, on Real Computers, look in /etc/resolv.conf for a set of full-service resolvers to query. The behaviour is  similar on Windows.
The PiHole is a Full-Service Resolver with a limiting configuration that makes it behave, in part, like a name server. If you have bought "broadband" instead of actual Internet you might nog be able to use it as a full-service resolver without configuring it to forward is queries to another full-service resolver. Which, of course makes the Pihole partially useless, because the entity running the other FSR will get your queries anyway. The goal must be that the PiHole or alternatively, the  FSR you set up with less blockings, can talk to the root servers and all other name servers that server names on the Internet.
Correct but from an end user perspective too much info  :-+
So... can I set up pi-hole and a full service resolver in the same box on the local side of my router and get the benefits of both pi-hole-ness and not using someone else's DNS server?
EDIT: Let me modify this: I'd like to block ads as close to the router and as transparently as possible, along with limiting the amount of information about my internet usage released to various corporate entities, and do both without a lot of server maintenance.  Is that too much to ask?  ;D
« Last Edit: February 27, 2020, 04:16:27 pm by worsthorse »
bark less, wag more.
Online mansaxel
« Reply #50856 on: February 27, 2020, 04:15:54 pm »
Back home now so a slightly more extensive reply. Your points are true for the Internet at large and all the front facing stuff but most ISP end users (and last mile infrastructure) and corporates with private network space use fully caching nameservers to keep traffic and RTT down and control borders. Local resolver on the box will talk directly to the cache which is authoritative. The cache will service a zone off the public internet as well (like .local). We're using dnsmasq and a large Active Directory forest for this. There are probably more of those networks out there than any other including the internet. I mean we have 32 IP addresses with about 12,000 devices behind them and every Thompson / D-Link / TP-Link POS router that ships runs nameserver cache.
Yes, there are several networks operating according to that principle.
In my corporate environment, we've got internal and external DNS, with suitable leaking in-between, cache forwarding etc. We buy DNS service as secondaries from several different operators, and run our own interrnal service, including DNSSEC-validating caches.  I'm planning for anycast resolvers inside, to get better service availability. And no, you can't trust Microsoft with important things like DNS, so we're running our AD DNS on 3rd party Real Computers.
Privately, I'm running a couple of name servers for zones I host, and all my servers have their own unbound  FSR running on ::1.
I've got under 3ms to the Internet exchange in Stockholm, so latency is not a problem. Neither is bandwidth, nor address scarcity.
The kids computers are contaminated with Win 10, so am running a Samba4 AD to rein them in, with a public DNS zone.
Why public? Because I fucking hate .local. I'm friends with people operating root DNS services, and I've been running the name services for .SE, and the amount of crap badly configured computers throw at the infrastructure they're not paying for is insane. .local is a major player here.
« Reply #50857 on: February 27, 2020, 04:30:59 pm »
That's pretty much what I'm trying to simplify at the moment because we don't want to bother with managing it and finding anyone who can run it in budget isn't a good ROI. Agree with Microsoft DNS. Total shit show.
I just get Amazon to do it now. I can't be bothered with looking after this stuff when I get home. As for Samba, the kids use OneDrive that comes with my O365 family sub. Entirely not my problem then! I don't have any local storage other than a couple of physical removable disks for periodic backups. I was running a Seagate 2 bay NAS but even that was too much for me to be bothered with :)
Yeah I don't like .local but it solves a whole load of pain if you are running AD with DNS. As for public there's good public and bad public. I'm currently living in a poorly contrived split-horizon DNS nightmare half in AD and half in a pikey DNS provider. we have things like www.google.com.company.local Ugh kill me. Everything is going to AWS and everything in public R53 zone with public addresses and Duo network gateway in front of it. That gives everyone SSO to the domain, sensible public addresses for services and easily revocable 2FA without having to spend a fortune setting up AO VPNs and stuff so they can all tap into the shit show.
Trying to get down to zero physical infrastructure, lose all the shitty grade third parties with their sticky fingers in everything, get to zero overheads and everything code driven and deployed in AWS.
Why did I take this job? Oh more money for test gear (and impending IR35 changes :-DD)
Online mansaxel
« Reply #50858 on: February 27, 2020, 04:38:00 pm »
It depends. (of course I had to answer like that)
If you have a broadband connection that blocks your ability to ask the greater Internet DNS queries directly, you're going to have a harder time getting there.  This is a TE thread, so let's set up a test:
On a Real Computer (linux will do, Windows definitely not), make certain you have the program "dig"; on Debian-derivates it is in the "dnsutils" package.
Ask the computer:
$ dig primary.se. soa @primary.se. +mult
Note the answer row that contains:
;; ANSWER SECTION:
primary.se.      86400 IN SOA casper.besserwisser.org. mansaxel.besserwisser.org. (
            2020022101 ; serial
            600        ; refresh (10 minutes)
            1800       ; retry (30 minutes)
            3600000    ; expire (5 weeks 6 days 16 hours)
            300        ; minimum (5 minutes)
Now, wait a few seconds, and then re-ask the same question.
  • If the TTL  (the "86400" number) is unchanged, you are lucky.
  • If it is decremented (roughly corresponding to the amount of seconds elapsed between the questions) you have something on the way that leeches your queries, and proceeds to potentially lie to you..
  • If you get no answer at all, you have something more sinister blocking you
The first case is the best, and the simplest. A PiHole will help, and help well.  In the second case, you will leak query data more than necessary. In the third case, you'll leak as much as the second, but additionally will have to configure a forwarding setting in the PiHole to circumvent the blocking.
Online mansaxel
« Reply #50859 on: February 27, 2020, 04:53:06 pm »
I see. We're a 2500 (plus consultants) people company with lots of time-critical IT systems (broadcast) so the option of clouding everything is only an expensive idea in the minds of bosses that have been to the reality distorsion that is Gartner conferences, nothing that's even remotely practically possible.
Luckily enough, things are reasonably right, and there are funds to get them better.
At home, I get to do things my way. Sort of adjacent to TEA, time-nuttery or volt-nuttery.
Offline worsthorse
« Reply #50860 on: February 27, 2020, 04:57:41 pm »
So if this is too OT, let me know and I will take the conversation offline...
I ran the query twice:
; <<>> DiG 9.8.3-P1 <<>> primary.se. soa @primary.se. +mult
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 22480
;; flags: qr aa rd; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; WARNING: recursion requested but not available
;; QUESTION SECTION:
;primary.se.      IN SOA
;; ANSWER SECTION:
            2020022101 ; serial
;; Query time: 173 msec
;; SERVER: 192.36.115.53#53(192.36.115.53)
;; WHEN: Thu Feb 27 08:53:07 2020
;; MSG SIZE  rcvd: 96
lhotse:~ wch$ dig primary.se. soa @primary.se. +mult
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 47996
;primary.se.      IN SOA
;; ANSWER SECTION:
            2020022101 ; serial
;; Query time: 184 msec
;; WHEN: Thu Feb 27 08:53:38 2020
I have a fiber connection through the telco, with a dynamic IP, and I've changed the router to use cloudflare for DNS for now.
Based on what you wrote and this query, sounds like I should be able to do this?
Off to do more reading on setting up DNS!  Thanks!
Online mansaxel
« Reply #50861 on: February 27, 2020, 05:00:44 pm »
<snip>
Yeah, you're good. Go ahead!
  • *Escaping The Suck*
« Reply #50862 on: February 27, 2020, 05:12:08 pm »
Yeah they tend not to feel as heavy as they are. I put this down to the size and the memory of old big CRTs. I certainly don’t want to lug a 21” FD Trinitron around now  :-DD. Some younger folk arriving these days in the IT industry have never owned a CRT and think the LCDs are heavy
Thats so true, I remember going to Epsom to collect a 21 CRT monitor for Cad purposes and I had to carry it down a narrow flight of steps from an upstairs office, I was bleeding knackered by the time I'd got it into the car  :phew:
36" Trinitron KV-HR Series:   https://www.hoylen.com/articles/tech/sony-kvhr36m31/Sony-SHCS-Sight-brochure-KV-HR36M31.pdf   My back screams just from me LOOKING at that brochure.  :-DD
Here's a 40" WEGA Trinitron on fleaBay... 480P native res & 4:3 Aspect tho, so probably not as heavy as that KV-HR which was 16:9 (much thicker glass) and IIRC, 1440P native res.  :o
« Last Edit: February 27, 2020, 05:14:10 pm by mnementh »
« Reply #50863 on: February 27, 2020, 05:22:24 pm »
Thanks to the generosity of PA0PBZ  :-+, I have now finished the Thurlby CM200 project. The 1mm sockets which he kindly sent me, were slightly too large to fit the existing holes. A few minutes with a dremmel soon cured that and it was discovered during the removal process of the old ones, that they had all suffered plastic fatigue possibly due to being exposed to UV for to long. This is on my bench stack and is a useful addition in the battle against bad capacitors including those bastard TANTS.  :-DD
Brymen-Fluke-Solartron-HP-Thurlby-Heathkit-Thander-Tek-Extech-Black Star-GW-Advance-Avo
The following users thanked this post: PA0PBZ, Zucca, BU508A, med6753, salvagedcircuitry, bd139, Kosmic
« Reply #50864 on: February 27, 2020, 05:32:38 pm »
cloudflare? Seriously? Insiders name them "clownflare".
https://blog.fefe.de/
Sorry, it's in German but one can follow the links.
- Key extract with Heartbleed at cloudflare: https://twitter.com/indutny/status/454773820822679552
- TOR and Cloudflare: a very bad idea: https://blog.torproject.org/trouble-cloudflare
- Cloudbleed: https://bugs.chromium.org/p/project-zero/issues/detail?id=1139
- using 1.1.1.1 (or 8.8.8.8) is a very bad idea if you are interested in your privacy.
  Same goes with this pilot project with Firefox and encrypted DNS.
- DNS outage at cloudflare: https://ianix.com/pub/dnssec-outages/20190321-www.cloudflare.com/
- another nice cloudflare outage which caused millions of websites going down: https://metro.co.uk/2019/07/02/cloudflare-outage-means-websites-including-detector-10103471/
I'm staying away from cloudflare as far as I can.
« Reply #50865 on: February 27, 2020, 05:44:34 pm »
   Currently restoring a Luxo Terea task light like this one purchased for CAD$8 at the thrift. I was lucky enough to find the CC power supply from it hanging on the "Wall o' Wall Warts" elsewhere in the store; would've been a total dicksore to find a substitute.  :phew:
A bit of a disappointment for Luxo; while the LED head is cast aluminum and it does have a nice heavy cast-iron base, the top hinge is glas-filled composite plastic and the base is rough-cast with a plastic shell. Also, the bottom hinge is made of cheap-feeling stamped steel, where the Luxo of old would've been a finish-cast one piece with the hinge machined into the casting itself. *sigh*
Still a damn sight nicer look & feel than 99% of what comes out of China (it was made there too); I'm not a fan of the silver so I'm going satin black on this one.
*tzzzzzt*
« Last Edit: February 27, 2020, 05:51:16 pm by mnementh »
« Reply #50866 on: February 27, 2020, 05:49:45 pm »
Still a damn sight nicer look & feel than 99% of what comes out of China (it was made there too); I'm not a fan of the silver so I think I'm going to go satin black Tek blue on this one.
*tzzzzzt*
Fixed that for you.  :-DD
Here you go:
Offline worsthorse
« Reply #50867 on: February 27, 2020, 05:50:43 pm »
i am happy to have another option for DNS resolution until i get something running behind my router here.  i ended up pointing to cloudflare to avoid using the telco provided DNS and google DNS servers, both of which i knew to be bad.  didn't realize cloudflare had issues and assumed that whoever i choose, as long it is "out there" is a privacy issue.
« Reply #50868 on: February 27, 2020, 05:56:43 pm »
*tzzzzzt*
Fixed that for you.  :-DD   Here you go:
LOL...  :-DD You caught me. I started that post last night but forgot to click send; you posted while I was editing to reflect that. Thankfully, it's already painted and in reassembly.  :phew:
« Last Edit: February 27, 2020, 06:01:00 pm by mnementh »
« Reply #50869 on: February 27, 2020, 06:18:49 pm »
If you are interested in some DNS alternatives, perhaps you want to check out these:
https://securedns.eu/
https://dismail.de/info.html#dns
https://digitalcourage.de/support/zensurfreier-dns-server  (Sorry, it's in German)
https://www.digitale-gesellschaft.ch/dns/ (a service based in Switzerland, site is in German)
The following users thanked this post: Mr. Scram
Online mansaxel
« Reply #50870 on: February 27, 2020, 06:29:35 pm »
<snip>
Seconded. Also, they're a major driver between the metadata gathering operation that is DoH.
Offline worsthorse
« Reply #50871 on: February 27, 2020, 06:41:25 pm »
<snip>
Thanks all for the heads up and help. I've temporarily swapped our router DNS pointers to a couple of opennic tier two servers until I learn enough to get a DNS server running locally.  And I guess I need to go learn what DoH is, too.
Its always somethin'
« Reply #50872 on: February 27, 2020, 06:57:02 pm »
*tzzzzzt*
You guys are dickheads.  :P :P :-DD
« Reply #50873 on: February 27, 2020, 07:08:07 pm »
Thank you.  >:D
Are you feelin' tha lurrrrve...?
« Reply #50874 on: February 27, 2020, 07:20:48 pm »
You saved me a lot of typing there  :-DD
Also their http/2 implementation is a fucked up puddle of diarrhea. They claim it’s nginx but it has new and even more special bugs in it. Grr.
As for secure DNS, the best solution is go full 1990 and use the hosts file.  :-DD
« Last Edit: February 27, 2020, 07:22:56 pm by bd139 »
