Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 3427603 times)
amwales, K0ELB, BU508A, mnementh, scl, Specmaster, SingleBitError, med6753, Brumby, tggzzz, 25 CPS and 38 Guests are viewing this topic.
Online Brumby
« Reply #62500 on: July 05, 2020, 07:28:19 am »
My exercise injury minimisation policy involved removal of all equipment that involved any sudden changes in movement, including two treadmills ... gone.
All that is left is an exercise bike and a rowing machine - smooth motions all the way.  The rowing machine, in particular, allows for a great variation in intensity from casual boating to olympic competition.
The following users thanked this post: mnementh, Specmaster, bd139, AVGresponding, tonyalbus
Offline tonyalbus
    • My Channel
« Reply #62501 on: July 05, 2020, 10:14:54 am »
So I am new here, first time posting here in TEA.
Welcome, its called therapy here, but be aware... you will and up with more TE ...
i think  :-DD
Marconi 2955/2432A/2414A - TTi TF930/TF600/TG102 - HP5302/5315/5323/5385/3478 - Fluke 8000/8010/8125 - SDS1202X-E -XDM2041 - TEK 475 - Anritsu MS610/MF1603 - Keitley 199 - PM2521/2522/2527
https://www.youtube.com/channel/UCwLPcv2xiA3D9lfGArF58ww
The following users thanked this post: mnementh, TorinoFermic
Offline mendip_discovery
« Reply #62502 on: July 05, 2020, 10:34:04 am »
Quote from: AVGresponding
Welcome to the madhouse!
These might be made to suit your purpose perhaps:
--FOB Power Supplies--
Quote from: Specmaster
And a 25A load?
Naa, I have a Transmille 3000 series calibrator (22A) UKAS traceable at work.
Quote from: bitseeker
Yep, that's how it begins. ;D
Sounds like you need some more test gear. That's how it spreads... :-DD
Quote from: xrunner
Welcome mendip.
You have joined us now. Forget the life you used to have - before TEA. Don't look back because you can never go back. It will never be the same now. All that pre-history will soon be forgotten. That's how I remember it when it happened to me.
Quote from: Brumby
Indeed.  Welcome mendip!  Make yourself at home.
We have several rabbit holes you might care to explore...
I have here at home, 121GW, 2 x AVO8, Decade Resistance, Capacitance Box. Plus various HAM gear, K40 (40W CO2) Laser Cutter, a ton of motorcycles, and a Land Rover Defender. I have a warren to explore if I ever feel the need.
Looking forward to seeing this tester. It's not something I've run across.
Its basically for testing the Ginger Clare Flash testers though I suspect I could use it for any flash tester even them Seaward HAL units. So only enough kV to perk ones senses (5kV) and enough amps (25A) to knock you down if you are foolish. I had a 6kV 150A supply in a few weeks ago that I demonstrated AMPS and VOLTS to the lads at work, they think I am a loon[1], I told them to wait until its 120kV and 3000A then you will see how much fun it can be.
Quote from: tggzzz
Welcome to the madhouse, or Hotel California as it is sometimes called.
If I go up the road from my house, I can see the Mendips
I will remember to use the Royal Wave next time I am overlooking the commoners down on the levels. ;-)
Thanks for all your welcomes, I plan to annoy people for a while.
[1] I think I ought to order a white lab coat and practice a sinister laugh.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
The following users thanked this post: Specmaster, tonyalbus
Online med6753
« Reply #62503 on: July 05, 2020, 10:43:53 am »
Nah, you'll dirty up the lab coat fixing the Land Rover.   :P :-DD But after perfecting the sinister laugh this is appropriate for when that old pile of TE powers up. (Applies to the Land Rover too).
Welcome to our party of misfits.  :-+
Online xrunner
  • hp>Agilent>Keysight>?
« Reply #62504 on: July 05, 2020, 11:30:46 am »
 K40 (40W CO2) Laser Cutter <----- WANT.
Got any pics of your laser cutting projects?  :popcorn:
I am a Test Equipment Addict (TEA) - by virtue of this forum signature, I have now faced my addiction
Offline tonyalbus
    • My Channel
« Reply #62505 on: July 05, 2020, 11:34:59 am »
And i have put something on background of my PC screen, behind me ;-)
The following users thanked this post: xrunner, bitseeker, BU508A, med6753
Online tggzzz
« Reply #62506 on: July 05, 2020, 11:56:40 am »
Oooh. Hello friend  >:D
Quote from: tggzzz
Actually I'm not on the levels; I'm on a 1:6 hill and my house has 2/3 of an extra storey at the back :)
Having lived on the edge of the Fens in the 80s, when I moved here I made it a priority to be in the midst of trees and contours :) Basically a 1:50000 OS map has 10 times as much ink (of any colour) as near Cambridge.
Offline tonyalbus
    • My Channel
« Reply #62507 on: July 05, 2020, 12:21:11 pm »
Bags of components everywhere and empty drawers....
little stuff in big drawers and vs vs ....i need to reorganize... :palm:
[attachimg=1]
« Reply #62508 on: July 05, 2020, 12:33:53 pm »
K40 (40W CO2) Laser Cutter <----- WANT. :-+
https://blog.jackstringer.co.uk/misc/2020/sorting-jubilee-clips/
https://blog.jackstringer.co.uk/my-vehicles/2020/bmw-on-lockdown/
https://blog.jackstringer.co.uk/misc/2020/tap-and-die-storage/
I have some Low ohm resistors about so I may make up a low ohm resistance box, the handy thing of the laser is I can cut my own project boxes so I can get just the right size.
Online xrunner
« Reply #62509 on: July 05, 2020, 12:36:12 pm »
The left side of your house looks like an illustration of how to estimate the area under a curve with rectangles.  You need triangle-shaped storage cabinets.  :-DD
[attachimg=1]
The following users thanked this post: mnementh, Mr. Scram, bd139, tonyalbus
Online xrunner
The following users thanked this post: slburris, Neomys Sapiens
« Reply #62511 on: July 05, 2020, 12:39:36 pm »
Sadly the boss has just fitted CCTV to the place so I can't do, helpers.
Quote from: tggzzz
lol, being accepted on the Fens makes you perfect for the Levels. They find working in imperial measurements rather easy, helped by the number of fingers on each hand.
Online med6753
« Reply #62512 on: July 05, 2020, 01:13:48 pm »
A close encounter you don't want to have..... :scared:
Was outside washing the CR-V. What is that flying around? A bat! During the day?  :o Big fat warning. That poor thing is obviously sick, most likely rabid. Anytime you see a nocturnal mammal out during the day that's a clue to stay away.
I watched it fly around and try to roost on the side of the building but it kept falling. Yep, sick. Eventually it flew off into the woods. We've had a rash of rabid raccoons lately which seems to happen every 5 years or so. But this is the first time I've seen a sick bat.   :--
Online med6753
« Reply #62513 on: July 05, 2020, 01:29:43 pm »
[attachimg=1]
No, you need a bigger storage area.....to fill up.  :-DD
Online tggzzz
« Reply #62514 on: July 05, 2020, 01:48:36 pm »
Quote from: tggzzz
Oh, I wasn't on the Fens, merely near them. Having some sense of history, I made very sure I was on high ground (i.e. 10m AMSL whereas the nearby drain was 5m AMSL) :)
One of us here has seriously considered going back to the fens, but I think currently that is not on the table. If the concept reappears, I will continue to have fun gently prodding him :)
As for numbers of fingers, one must bear in mind that they are very inbred on the Fens. Musclepower is prized more than brainpower. Bit like the Forest of Dean. Not sure about imperial vs metric, but they don't choose between Labour and Conservative candidates, but between Whig and Tory.
At least on the Somerset Levels you can see surrounding high ground. The joke in Cambridge is that going east from the Hills Rd bridge over the railway, the next highpoint is in the Urals. Fenlanders won't know where the Urals are.
Online mnementh
  • *Escaping The Suck*
« Reply #62515 on: July 05, 2020, 02:32:59 pm »
Da Dwagon's Day of Dietary Debauchery has BEGUN!!! BUAHAHAHAHAHA!!!
Today marks 2 weeks 3 days since I went back on a 20 gram Keto diet; so officially 2 weeks since the day of transition misery.
Blessings upon my wife who made fresh coffee just because I asked nicely; and who is joining me on the diet. Or was it me joining her...?  :o
« Last Edit: July 05, 2020, 03:17:44 pm by mnementh »
Online mnementh
« Reply #62516 on: July 05, 2020, 02:59:36 pm »
Naaahhh... I don't think we need to worry until he starts showing off his latest -Inator...
K40 (40W CO2) Laser Cutter <----- WANT. :-+   Got any pics of your laser cutting projects?  :popcorn:
...which should be in a day or two, as construction has obviously already begun.  :-DD
Welcome to The Land of Misfit Toys TEA... I'm certain you'll fit right in here.   >:D
Offline SilverSolder
« Reply #62517 on: July 05, 2020, 03:02:00 pm »
I just shed 10lbs over the last 3 months by cutting back the total number of calories (doesn't matter if they're from carbs, fat, or protein - just kept it balanced and below the daily limit).   Harder than I thought it would be!
« Reply #62518 on: July 05, 2020, 03:05:58 pm »
Yep it fucking sucks.
43lb down since 29th December counting calories and walking a lot. Starting to look like I’ve stolen a skin suit from someone, like the bug guy in Men In Black. Don’t lose it too quick!
Been using nutracheck app to manage balanced diet.
The following users thanked this post: xrunner, SilverSolder, mnementh
« Reply #62519 on: July 05, 2020, 03:19:36 pm »
I tried the subtly named "Fat Secret" app!  :D
Online mnementh
« Reply #62520 on: July 05, 2020, 03:23:50 pm »
Yeah; I need to go low-carb for other reasons, and honestly hypoglycemic is the only diet I've ever been able to STAY on. Problem is it's hard when everything in the house is food for wife & kids NOT on the diet.
That banana just lies there, mocking me. It mocks me and I am mocked. :-\
Offline Mr. Scram
  • Display aficionado
« Reply #62521 on: July 05, 2020, 03:28:39 pm »
Slow and steady wins the race. Except that a race has a beginning and an end and a healthy lifestyle doesn't end. Learn to love the changes. Anything you loathe isn't going to last. I was doing reasonably well but the lock down has done a number on me. My weight has been redistributing itself and is now slowly ticking up and I'm honestly also done sitting at home.
« Reply #62522 on: July 05, 2020, 04:06:41 pm »
Early on in the lockdown I realized I would go crazy if I didn't start some kind of "health project"...   which ended up consisting of eating (much) healthier, getting regular exercise, etc. -  the best exercise is the increased cardio I get from kicking myself, for having taken so long to "get the message" about how important it is, given how much better I feel and how much more energy I have!
Offline Mr. Scram
« Reply #62523 on: July 05, 2020, 04:29:40 pm »
I had a wake up moment a few years ago and I was doing reasonably well. I was and am eating fairly healthily but I neglected to adjust for the change in physical activity. It's not rocket science but I let it sneak up on me.
« Last Edit: July 05, 2020, 04:40:34 pm by Mr. Scram »
Online med6753
« Reply #62524 on: July 05, 2020, 04:32:19 pm »
Decided to do some troubleshooting of the bias issue on the Type 106 Square Wave Generator before attempting a final calibration. Found 2 suspicious items....
First, the cathode of V15 (Pin 2) shows some noise and instability for about 3 minutes of so then settles down. While not completely unacceptable it should settle down quicker than that. I think that 6EW6 is going soft. Checked Ebay. Found a PAIR of NOS RCA's for $14 including shipping/tax. And about 100 miles away. Should have them in a few days. That's a no brainer. Should have spares anyway. These tubes are VHF pentodes which is why they are so cheap. Audiophools ignore them.
2nd, probing around Q34 and Q43 found Q43 to be touchy mofo. You're outta here.  :-- Replacement 2N3904 installed. Seems to be a lot better now but I have to wait until the unit cools down completely and then do a cold start. Fingers crossed.  ;D
The following users thanked this post: BU508A, mnementh, Kosmic
