Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 3427814 times)
med6753, Neonuros, Specmaster, mnementh, Jambalaya, amwales, K0ELB and 26 Guests are viewing this topic.
Offline FransW
« Reply #62825 on: July 09, 2020, 11:37:58 am »
Accidently, I offered this before but I think perhaps you missed it. I have a PM6654 (with 1.5G option) that's in need of a repair. If you're looking for a victim for a repair video, perhaps you're interested. Free delivery & pickup. No strings or purchase obligation attached.
There's an old thread and Service Manuals @ KO4BB available:
https://www.eevblog.com/forum/testgear/philips-fluke-pm6654c-high-resolution-counter-teardown/
1  Philips / Fluke PM6654C High Resolution Counter - Teardown:
Products => Test Equipment => Topic started by: CaptnYellowShirt on February 28, 2014, 03:13:33
PM
Title: Philips / Fluke PM6654C High Resolution Counter Teardown
Post by: CaptnYellowShirt on February 28, 2014, 03:13:33 PM
2  [time-nuts] question Alan deviation measured with Timelab and counters
Stéphane Rey steph.rey at wanadoo.fr
Tue Jan 13 16:18:30 EST 2015
3  By SaabFAN: Re: Replacement for the PM9610 Prescaler for Philips PM6654 High precision Counter
« Reply #16 on: October 20, 2016, 11:42:20 am »
Well, I got it mostly to work now.
Frans
« Last Edit: July 09, 2020, 11:42:16 am by FransW »
PE1CCN, Systems Engineering, HP, Philips, TEK, BRYMAN, Fluke, Keithley
The following users thanked this post: BU508A, med6753, bd139, tonyalbus
Offline ArthurDent
« Reply #62826 on: July 09, 2020, 01:16:04 pm »
The Fluke/Philips PM6654C is actually a very nice counter. Both of mine have the high stability timebase. Here's a photo of the counter and some of its friends.
The following users thanked this post: med6753, mnementh, tonyalbus
Online BU508A
« Reply #62827 on: July 09, 2020, 01:32:50 pm »
This pendulum is looking very similar to my Fluke PM6681:
« Last Edit: July 09, 2020, 01:37:05 pm by BU508A »
Online med6753
« Reply #62828 on: July 09, 2020, 01:33:35 pm »
Oculus....your PM inbox is full, tried sending you this msg:
"My package to you seems to have dropped into a black hole. Last scan was yesterday in Memphis, TN with a delivery date of today which seemed like a bunch of BS considering it's last location.
But now, no delivery date and recent scan.  :wtf: :-//"
Online 0culus
« Reply #62829 on: July 09, 2020, 01:36:39 pm »
Hmmm. I've had USPS packages show up out of the blue way faster than I expected...will let you know if I get it. I deleted some old messages.
Offline tonyalbus
    • My Channel
« Reply #62830 on: July 09, 2020, 01:39:25 pm »
those look so cool.. :-+
Marconi 2955/2432A/2414A - TTi TF930/TF600/TG102 - HP5302/5315/5323/5385/3478 - Fluke 8000/8010/8125 - SDS1202X-E -XDM2041 - TEK 475 - Anritsu MS610/MF1603 - Keitley 199 - PM2521/2522/2527
https://www.youtube.com/channel/UCwLPcv2xiA3D9lfGArF58ww
The following users thanked this post: BU508A, Specmaster
Offline tonyalbus
    • My Channel
« Reply #62831 on: July 09, 2020, 01:41:51 pm »
It's spread all over the place so I will consolidate it all. Three notes:
1. There's a RIFA hiding in it. Usually across the output terminals. This is not the end of the world scenario but it needs removing on principle.
2. Also there is no reverse protection diode across the output or across the pass transistor so if you're using it to drive something which can shove current back into the supply (capacitors, batteries) it'll blow the shit out of the pass transistors if the line supply fails or is switched off by someone using the vacuum cleaner :-DD. Stuff a fat diode across the output and the pass transistors.
3. The push switches get a bit dicky. They are unobtainium so you will have to get creative with mounting a toggle switch or something alternative. Plus there is mains on the main board so be careful.
Action shot:
Inside. Whole thing breaks in half in the middle with an edge connector.
Front panel with new RIFA replacement, new output cap and additional diode:
Pass transistor diode (on rear heatsink)
I rather like 'em when they're working.
Yours might be a later one with some of the issues fixed. There were about 5-6 revisions.
Edit: oh watch out for the voltage reference diode and resistor. They run hot! Burned myself on the bugger.
Thanks for this!
You happen to have schematics or which pot does what on the board?  i could not find any yet on the net.
Online BU508A
« Reply #62832 on: July 09, 2020, 01:42:41 pm »
Looks like that I have a sweet spot for R&S PSU   :palm:   :-DD
There is another one on the way to me, a NGT 20:
It will fit nicely with my NGB 70/5 and NGB 32/10 (once this is repaired)
The following users thanked this post: mnementh, tonyalbus
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #62833 on: July 09, 2020, 01:59:50 pm »
No argument from me. It oozes "engineer built" and not "marketing driven". More like some engineers having a coffee in Eindhoven going "oeeehh! Let's add this too".
Anyways, broken unit is going to the Captain. The other one is still on the Bay.
Online mnementh
  • *Escaping The Suck*
« Reply #62834 on: July 09, 2020, 02:00:07 pm »
   So... it would appear I have a new assistant.  :-DD
Went Thrifting today since the boi wanted to; who found and decided that "I needed Emmet"... he was only a few dollars, and I always had a soft spot for the daft little nebbish, m'self... so I agreed.  ;) Also found a right proper Scholastic-type globe for the education/office area; it's exactly the same as the ones I remember in every classroom when I was in school. Could be that old too; It has the Post-Soviet States/CIS still labeled as the USSR/Russian Soviet Federative Socialist Republic; so definitely pre-1991.
Don't care; it'll still be useful in general. If there's discrepancies, that'll give the boi a reason to use Google and do... gasp.... research.  >:D
*toddles off to ded*  :=\
Awesome  :-DD
Everything. Is. AWESOME...!
when you're living in a dream...
« Last Edit: July 09, 2020, 02:34:09 pm by mnementh »
Offline Mr. Scram
  • Display aficionado
« Reply #62835 on: July 09, 2020, 02:14:49 pm »
[attachimg=1]
Excellent late-night TV.
Online BU508A
« Reply #62836 on: July 09, 2020, 02:20:13 pm »
[attachimg=1]
You are watching "Bernd das Brot" on Kika?  :o
Whoa, didn't expect this.
But I'm watching it, too.   :-DD
https://en.wikipedia.org/wiki/Bernd_das_Brot
Offline FransW
« Reply #62837 on: July 09, 2020, 02:26:29 pm »
They share equal ancestry.
Made originally in Sweden: Philips Scientific.
OCXO's have a long history which started with the PM660x series.
« Last Edit: July 09, 2020, 02:30:38 pm by FransW »
Online mnementh
« Reply #62838 on: July 09, 2020, 02:30:29 pm »
What the hell is that acid trip worthy thing?  :-DD
Gumby and Pokey didn't play in the UK?
Nope
I had GUMBY growing up...  :o
I remember when SNL was funny too...
« Last Edit: July 09, 2020, 02:48:13 pm by mnementh »
Offline ArthurDent
« Reply #62839 on: July 09, 2020, 02:38:47 pm »
This penduluum is looking very similar to my Fluke PM6681:
No, no, no. It's the other way round. Your Fluke PM6681 is looking very similar to my Pendulum CNT-81 !  :-DD
The following users thanked this post: BU508A, FransW, tonyalbus
Online mnementh
« Reply #62840 on: July 09, 2020, 02:40:55 pm »
Oh sweet cheese and crackers...    :palm:
 |O
Online med6753
« Reply #62841 on: July 09, 2020, 02:44:20 pm »
At least Fluke updated their industrial design when they aligned with Philips  :palm:
(This was before I repainted the case. The blue helped but not much)
Online BU508A
« Reply #62842 on: July 09, 2020, 02:49:42 pm »
What a nice bunch of counters there in your lab!  :-+   ;D
Offline ArthurDent
« Reply #62843 on: July 09, 2020, 03:07:33 pm »
The Fluke 7260A is just plain UGLY and no matter how well it worked, I wouldn't own one. Plus they wouldn't stack well which is a requirement of mine. 8).  One old Fluke counter I always liked was the 1953A.
Offline Mr. Scram
« Reply #62844 on: July 09, 2020, 03:24:04 pm »
 |O
What's going on with your images? I've seen several where the thumbnail doesn't match the actual picture, including thumbnails of what looks like a family photo you didn't seem to intend to post. Are you renaming images or using sketchy software perhaps?
« Reply #62845 on: July 09, 2020, 03:45:50 pm »
That was mostly aimed at Robert, I guess. I'm not trying to push it down your throat. I've dangled it in front of you, if you don't bite I'm not gonna chase you  :-DD
Not sure why you think the reason it's not being bought is the heritage. I agree that's a big reason people don't buy stuff, but this *is* an HP machine  :-//
 :palm:
My bad, I was biased by the two Anritsu.
Quick update regarding the R&S NGB 32/10:
Today I pulled out the power module and checked the semiconductors. All good, except for D203. This one should be a 1N4006 but for some reason I've found a GI826  :-//
I measured the Uf and found a value of around 0.25V, reverse was okay. Checked the datasheet and found that the Uf is starting at around 0.6V (as usual for a silicone semiconductor) and 1.05V@5A. I removed the GI826 and replaced it with a 1N5408 which is imo the much better replacement for a 1N4006.
I will put it together tomorrow and see, if the fuses will blow again. Will also check the capacitors but I need to order the replacements.
Pictures will follow.
Anyway, bed time....
Time zones and work delaying responses :-(
The biggest problem with the 8922x is that - it's BIG. and while the SA works I would not call it full featured or high accuracy. Only 10MHz to 1015MHz, fixed span/bandwidth, very limited maximum span (4MHz, 10MHz overrange)  <70dB dynamic range, 2.5dB accuracy etc). The signal generator is CW only too. Yours is an S so not even FM demodulation.  Better than nothing, but a R&S CRTU will give a full featured  SA to 2.7GHz (same 10MHz lower limit), colour display, full function signal generator (100kHz to 2.7GHz) 50W input capability and power meter in a smaller, lighter box for a similar price.
« Reply #62846 on: July 09, 2020, 03:57:28 pm »
Which boat anchor? The one Tony linked to or this one ->
If you're talking about mine, the TL;DR is that it listed for 600€. This included eBay and Paypal, so outside eBay 525€ through a bank transfer. 500€ round would be OK for me. Still includes 21% belgian VAT so if you are VAT registered ex VAT price is 425.
if i knew about the 425,- .. i would not have bought the Ansitsu but this HP  one for sure... if that helps you to make a choice...it has a TG!
Err no, the 8922x does not have a tracking generator. It has a CW signal generator. The pseudo tracking generator Scalar network analyser software for the similar vintage 8924C (and 8920B) does not work on the 8922x as is. You might be  able to write your own though.
The following users thanked this post: bitseeker, tonyalbus
Offline nixiefreqq
« Reply #62847 on: July 09, 2020, 04:09:26 pm »
it is ok to think "what an ugly baby".
but you don't say it out loud when the proud mom is standing right there!
edit  full disclosure.......i DID own a 7260a.
edit 2  further disclosure.......i sent it to med.  only because it was just begging to be blue.
« Last Edit: July 09, 2020, 04:27:38 pm by nixiefreqq »
free range primate
« Reply #62848 on: July 09, 2020, 04:34:20 pm »
I should get on with repairing mine, maybe then I'd like it too...
Addiction count: AVO-BlackStar-Fluke-Hameg-HP-Keithley-IsoTech-Mastech-Micronta-Solartron-Tektronix-Thurlby-TTi-UniT
Offline Ice-Tea
« Reply #62849 on: July 09, 2020, 05:06:54 pm »
What, you get sleep at night??  :o :o
Ah, it's actually less wide, less high and slightly deeper than a CMU200/CRTU
.. and while the SA works I would not call it full featured or high accuracy. Only 10MHz to 1015MHz, fixed span/bandwidth, very limited maximum span (4MHz, 10MHz overrange)  <70dB dynamic range, 2.5dB accuracy etc). The signal generator is CW only too. Yours is an S so not even FM demodulation.
Granted. Still makes sense if you don't want to spend too much and are looking for a single instrument to cover a lot of bases.
No argument there. Even though there's a marginal added value in some of the audio features.
EDIT: it doesn't have an HP sticker though. That seems to matter a lot to a lot of people.  ^-^
