And I slept through a fluke 8800a. If anyone got it, well done.
Was that the one went for £70 shipped? I lowballed it and got knocked back, went for silly money imo.
That's the one. I was going to put 50 on it as it's 5.5 digits but was unconscious at the time it finished
okey now i am even more confused i usualy already am..
on my doorstep just now...
Nice, tell us how it goes the initial testing and I would like how these meters are easy to calibrate.
Oh you're into a world of fun with the 3478A. If you have penis fingers like me, then run away. Some gotchas:
1. The switch shaft plastic is brittle at this age. I managed to break it off one removing the switch to replace the RIFAs.
2. It has RIFAs. Grr.
3. It has a soldered in memory backup battery which needs to be replaced almost certainly immediately at the moment. Doing this is a bastard without losing the cal data. I lost the cal data when I did mine
4. The cal can be re-entered via the front panel but it's boring. There is a way of pulling it off the HPIB interface but it means you need to build or steal an adapter and find some software to do it.
The good bit is it only needs cal on 3V on the AC range if I remember correctly which means it's pretty easy to cal comparatively with another DMM that is calibrated and an AWG or something.
