Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 4307223 times)
morris6 (+ 1 Hidden) and 13 Guests are viewing this topic.
« Reply #63150 on: July 12, 2020, 10:43:38 pm »
https://www.newegg.com/iogear-gw4k30gh60/p/N82E16815290099
I read an article about 60GHz spectrum allocation a few years ago; this is the first consumer application I've seen of the technology. When you get into these frequencies, the air itself becomes a physical barrier; for certain applications this is a pro, not a con. :-+
https://www.fiercewireless.com/tech/sub10-systems-oxygen-absorption-makes-60-ghz-perfect-for-backhaul
 :-/O
60 Ghz for consumer stuff, yeah right. Tell us where you can get licensing for such bands.
In other news, our 11 GHz AirFiber backhaul link for community data is up and running albeit not fully optimized to get 1 GHz data speeds just yet. Tricky little buggers to align at just 10km with only a 20 beam.  :o
Still, it's providing a good bit higher throughput than the previous 5 GHz link.  :phew:
If you read the article I linked to, you'd see that frequency allocation is not licensed or is "lightly licensed"... For the time being, anyways.
What I found interesting was not the shortcomings (mostly rain and short distance) but the amount of BW available compared to licensed bands, as long as you're able to work within the short ranges possible. These are the real beginnings of a staple SciFi technology... "narrowcast". It's a great time to be around and in the tech sector!
 :-/O
:wtf: with all the loonies around with the 5Ghz theories, they'll come and burn down your system saying that 60Ghz will give them Coronavirus 12 times worse  :-DD :-DD
Brymen-Fluke-HP-Thurlby-Heathkit-Thander-Tek-Extech-Black Star-GW-Advance-Avo-Kyoritsu-Amprobe-ITT-Robin-TTi
« Reply #63151 on: July 12, 2020, 10:48:53 pm »
I hope that atmospheric changes and foliage changes and object changes don't cause reliability problems. At 10km range I presume you are in the fresnel zone.
The 5 GHz links have been brilliant and we've had zero issues with rain fade etc for deployment to customers.
AirFiber 11 GHz is another big jump up in HW for us as these things apparently have a 300km range  :o so using them over just 10km with only a 2o fresnel makes them tricky to align as they don't come equipped with precision HW to allow for micro adjustments.
We have them throttled way down but still above our licensed dB ATM and as it's mid-winter here we're not terribly keen on spending much time up masts right now to optimize them. We're getting ~ 500 MB link speed and 1-2 dB channel imbalance which is good enough for now until a nice day comes along and the team of 4 of us can get together (2 @ each end) again to tweak it more. IIRC they have ~12 signal strength indicators and we're getting ~#9 at both ends so we're getting close.  :-/O
Avid Rabid Hobbyist
  • *Escaping The Suck*
« Reply #63152 on: July 12, 2020, 10:54:28 pm »
That's great... thanks for including me in your little cosplay.  >:D Did you get my shirt back yet...?
 :popcorn:
Don't ask, med. Otherwise you'll get ... answers.   :scared:   :scared:
It's called a diversion, DUH.   ;)
Shifting the blame is a time-honored tradition; one should not be surprised to see it employed by a goofy dwagon when a joke backfires. Just think of it as the equivalent of hiding behind a potted plant in shame...  :palm:
BTW... that's supposed to be DAFUQ...? Da FAQ is where yo go to find answers to Frequently Asked Questions...  ::)
« Last Edit: July 12, 2020, 10:56:08 pm by mnementh »
« Reply #63153 on: July 12, 2020, 11:47:41 pm »
 :popcorn:
You need really a better diversion than a poor potted plant.  :popcorn:
I recommend this guy:
 :-+   :-DD
« Reply #63154 on: July 13, 2020, 12:06:36 am »
 :-DD
Offline nixiefreqq
« Reply #63155 on: July 13, 2020, 12:27:14 am »
:-DD
have to admit that some of the dragons comments are lost on me.  (he may be overclocked just a scooooch over the limit).
but the dog with the phonograph horn on its head did make me laugh out loud.
free range primate
Offline 0culus
« Reply #63156 on: July 13, 2020, 01:48:16 am »
Thanks to FedEx working on Sundays here, I have a shiny new Type 82 plug-in for the 585A. This is (one of) the appropriate plug-ins for the 585A...it does not need the plugin-in adapter and allows the full bandwidth of the scope. After a good warm up and a few alignments to match it to the 585A, it appears to be working perfectly.  :-+
The following users thanked this post: xrunner, med6753, mnementh, Specmaster, wolfy007, Kosmic, TorinoFermic
« Reply #63157 on: July 13, 2020, 02:54:22 am »
Now that is some dead-sexy hollow-state goodness right there! Well-played!  :clap:
 :-/O
Offline Neomys Sapiens
« Reply #63158 on: July 13, 2020, 03:19:40 am »
Three fatalities in two accidents with ultralight aircraft in southern Germany in one day - I wonder how long those people will continue to try to keep their bloody FLARM out of official surveillance.
Personally, I think it amounts to criminal intent to put up resistance against it.
Offline BravoV
  • +++ ATH1
« Reply #63159 on: July 13, 2020, 04:17:21 am »
Have you ever catch by surprise that found a T&M equipment that you thought you never bought it ?  :palm:
Sign of age, isn't it ?  ::)
Offline Brumby
« Reply #63160 on: July 13, 2020, 06:59:38 am »
Not yet........
Have found one or two things I forgot I had - but have always remembered that I had acquired them.
Offline tggzzz
« Reply #63161 on: July 13, 2020, 07:09:13 am »
If you want anybody to think about that, more context and explanation is required.
Offline Brumby
« Reply #63162 on: July 13, 2020, 07:25:23 am »
Checked out the LF oscillator.  It is the only piece of hollow state test gear I have (excluding CROs).
Found some foam strips which had perished to dust - which completely collapsed when I removed them.
It works.
There was a curious flat spot on the output level control - and some distortion when the amplitude was near maximum.  Voltage level on scale seemed to not match what I saw on the scope (20.5V indicated; 5.3V p-p on scope for 1kHz signal) - but I wasn't particularly chasing it.  Usable though.
Today's acquisition.
.... now added to my repair queue.
I'm sure Bean would approve - but I have to stop! (for the time being  )
« Last Edit: July 13, 2020, 07:28:57 am by Brumby »
The following users thanked this post: BU508A, mnementh, Specmaster, wolfy007
« Reply #63163 on: July 13, 2020, 07:35:54 am »
I reckon, he is relating to these two incidents (sorry, both in German):
https://www.presseportal.de/blaulicht/pm/110972/4649894
https://www.presseportal.de/blaulicht/pm/42900/4649400
Offline tggzzz
« Reply #63164 on: July 13, 2020, 09:15:06 am »
No apologies necessary. Unfortunately google translate means my schoolboy German has atrophied so that it is now little more than a fantasy!
For Neomys Sapiens to make such comments he must have more information available than is published in those articles. I'm not sure what he means by "...keeping...out of official surveillance".
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #63165 on: July 13, 2020, 09:32:36 am »
I think a mandatory intercom, transponder plus TCAS would reduce accidents. OK, it costs money, but not even funerals are free nowadays.
Offline tggzzz
« Reply #63166 on: July 13, 2020, 09:38:40 am »
For that to happen two things are required: common equipment, and a source of power.
FLARM has power requirments that can be tolerated in unpowered aircraft, i.e. batteries - which perform poorly when they get cold at altitude.
General aviation transponders simply eat too much energy, especially if they are regularly "pinged" by ground based surveillance systems.
Offline Wolfgang
« Reply #63167 on: July 13, 2020, 09:50:58 am »
Clear enough, but safety never comes for free.
Offline Mortymore
  • Country: pt
« Reply #63168 on: July 13, 2020, 10:25:16 am »
Yet, another Power Clamp Meter, this time IPM138 (AC/DC)
I should stop looking for ISO-TECH @Evilbay  :horse:
« Reply #63169 on: July 13, 2020, 10:54:36 am »
20kW? 82.7A? Through these thin wires? WTF?   :wtf:   :-//
Offline Mortymore
  • Country: pt
« Reply #63170 on: July 13, 2020, 10:57:46 am »
Nop. Through 10 turns of 2.5mm2 single core copper wire. The actual current flowing is 8.27A
EDIT: image attached
« Last Edit: July 13, 2020, 11:06:16 am by Mortymore »
The following users thanked this post: BU508A, Specmaster, tonyalbus
Offline Zucca
  • EE meid in Itali
« Reply #63171 on: July 13, 2020, 11:54:40 am »
So, I was one week away in Sicily for my covid little honey moon. Thanks the virus no tourits on the beach, on the streets. Everywhere I went, the local people where happy to see some tourits again. It was bombastic!
I never felt like this before, I was like the king of everything.  :-DD  :-DD  :-DD
Anyway I am back and I was happy to see my bench and my toys in my lab again.
I missed you TEA. Tonight I want to solder something, I want that smoke smell back in my face.
Happy to see the TEA machine healty and working full blast as usually.
The following users thanked this post: edavid, BU508A, med6753, mnementh, Specmaster, Mortymore, Kosmic, TorinoFermic, tonyalbus
Offline tggzzz
« Reply #63172 on: July 13, 2020, 12:31:57 pm »
It is always a tradeoff. Everything is a tradeoff.
The tradeoff is simple if a "safe solution" does not work - drop the non-solution and keep looking for something that does work.
Offline tggzzz
« Reply #63173 on: July 13, 2020, 12:36:25 pm »
Good idea; switch to this bloke... https://www.bidspotter.co.uk/en-gb/auction-catalogues/hunt4auctions
Be aware the starting price is usually below the reserve price, which I find intensely annoying.
« Reply #63174 on: July 13, 2020, 12:49:55 pm »
So, I was one week away in Sicily for my covid little honey moon. Thanks the virus no tourits on the beach, on the streets. Everywhere I went, the local people where happy to see some tourists again. It was bombastic! I never felt like this before, I was like the king of everything.  :-DD  :-DD  :-DD
Anyway I am back and I was happy to see my bench and my toys in my lab again. I missed you TEA. Tonight I want to solder something, I want that smoke smell back in my face. Happy to see the TEA machine healthy and working full blast as usually.  :)
Welcome home, Z.  ;D
 :popcorn:
