Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 3349468 times)
med6753, Carl_Smith, Kosmic, nixiefreqq, Neomys Sapiens, JXL, K0ELB and 45 Guests are viewing this topic.
« Reply #63200 on: July 13, 2020, 05:11:22 pm »
gett'n rid of all this small 12V adapters... and a sneak preview of what is coming if you listen well.
 8)
Black Sharpie is the case-modder's friend; you can make that little Dremel hickey almost completely go away with just a dab.  :-+ I'm afraid you're going to find that 12.00V-ish at the terminals is going to be too low; voltage drop across the patch wires to your projects can cause a difference of 0.5V or more delivered to the DUT. To give you some idea; even the industrial-duty HP server power supplies (nominally 12.0V) come set to 12.40-12.50V to account for line loss inside the case of the server!
Unless you want to mod the whole setup with remote Vsense, you'll probably be better off set at 12.40-12.50V out on that thing for pretty much anything you'll run into in the real world.
If the delivered voltage is that important to your application, you should probably consider replacing the trimmer with a front-panel pot so you can set delivered voltage dead-nuts on the fly.  :-+
Anything designed to be powered by a wall-wart is typically going to be driven 0.5V-1.5V hotter than rated spec, even for regulated SMPS. As long as you're within that range, you're not going to hurt anything... there's a reason 16V is the most common voltage for brute-force filtering caps in this application.
I recommend a heavy patch cord (16-18gauge) with 5.5 x 2.1mm coax DC / Barrel connector on the end; this will plug into these:
https://www.amazon.ca/gp/product/B0722J415P/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
I've been using this arrangement on my HP DPS-1200 server Power Supply (and my little homebrew CC/CV PSU) for almost a year; it is just TOO convenient! :-+
I have the POWAAAAHHH!!!  >:D
Way ahead of you here, did this a few months ago now and posted, but instead of a fixed voltage, I used a TTi 1A variable PSU and those very same adaptor set from Amazon  :-+
« Last Edit: July 13, 2020, 05:13:49 pm by Specmaster »
Brymen-Fluke-Solartron-HP-Thurlby-Heathkit-Thander-Tek-Extech-Black Star-GW-Advance-Avo-Kyoritsu-Amprobe-ITT-Robin-TTi
The following users thanked this post: mnementh, tonyalbus
« Reply #63201 on: July 13, 2020, 05:17:41 pm »
 :palm:
If he's planning to use this as a replacement for all those 12V wall-warts while working on things on his bench (like with the addition of one of those DC power tip kits I linked to above) adding remote VSense is probably unnecessary headache, and at worst just inviting Murphy to come kick you in the balls. ;)
Officer Training 101: "Don't Taunt Murphy!"
Did somebody call him, now look what you have done, Murphy is on the prowl :palm:
Offline Saskia
« Reply #63202 on: July 13, 2020, 05:54:00 pm »
The following users thanked this post: mnementh, Specmaster, AVGresponding
Online madao
« Reply #63203 on: July 13, 2020, 07:09:12 pm »
Finished,  TDS5054B-NV  got touchscreen.
I have remove orginal TFT panel without touch digizter and  replace it with modern  panel with LED backlight (innolux G104V1-T03 )and (very good) chinese touch digitzer.  Zero cost, because it came from my job's scrapyard. Solder on TFT RGB TTL cable is painful. (orginal cable is very short and  modern panel connector has offset of 3 cm  |O
brilliant colour and high brightness :-)
Greetings
matt
« Last Edit: July 13, 2020, 07:16:07 pm by madao »
The following users thanked this post: edavid, BU508A, med6753, mnementh, Specmaster, Mortymore, bd139, Kosmic, tonyalbus
« Reply #63204 on: July 13, 2020, 08:10:09 pm »
Newly supplied Li-ion cell @2.4V, recoverable?
Addiction count: AVO-BlackStar-Fluke-Hameg-HP-Keithley-IsoTech-Mastech-Micronta-Solartron-Tektronix-Thurlby-TTi-UniT
« Reply #63205 on: July 13, 2020, 08:27:41 pm »
Today my Rohde & Schwarz NGT 20 power supply arrived.
What a nice and cute PSU. It has no fan and is completely silent.  :-+
I did some checkings and all is working well.
I did not see the jumpings Ero-Shan mentioned,  but the output voltage changes for about 20 - 30mV when the knob for the voltage setting is slightly touched or pushed.
Here are the pictures of this quick teardown:
The front side, looking nice and clean, same goes for the back:
This is the top side with the mains switch and a brittle shrinking tube:
The left side with the transformer in detail:
The right side and the mains input and lots of dust:
The main controller board with lots of 741 and a detailed view of one of the 10x potentiometers, Made in Switzerland:
The bottom, the output capacitors (date code 9033) and the 2N3055 output transistors (date code 9141):
I really like it.  :D
The following users thanked this post: edavid, bitseeker, med6753, Specmaster, Mortymore, FransW, tonyalbus
Online Neomys Sapiens
« Reply #63206 on: July 13, 2020, 09:17:33 pm »
@tggzzz: Yes, I was rather tired when I wrote that post. Especially as the most applicable of the accidents was not one of the two, but the one in which two belgian sailplanes were involved in what was possibly a mid-air collision.
Also, my mind was partially at work. The situation is such: the manufacturers of equipment for ATC and related surveillance could without any problem integrate FLARM into their systems, so that awareness of these participants in the air traffic could be far better. For that, we would need a FLARM license, with which comes the encoding/decoding SW. This is blocked by some light aviation people who insist that their vehicles should not come under any surveillance except primary radar (which sees them worst and is being thinned everywhere).
Right at the moment, it does not seem as pressing as before, but in the pre-Covid airspace over Europe I consider this an anachronism, as governments and Eurocontrol try to build systems extending their means of awareness and coordination to unmanned systems of decidely smaller size.
Also, I might have been in Error as I thought that powered ultralights use that system too - have to recheck that.
« Reply #63207 on: July 13, 2020, 09:30:14 pm »
Not in Sweden; we've had enough Russian air force flights over the Baltic sans transponder that our (Air Force/Naval) primaries are getting beefed up, simply because we need to keep an eye on them for air/sea space management reasons. The Air Force are letting the civilian ATC in on some of the data as well.
As is plainly obvious, secondary radar systems, while offering nice displays with lots of reassuring data, are a coöperative story; unless all involved are playing along, the picture has serious omissions.
« Reply #63208 on: July 13, 2020, 09:38:06 pm »
 continued from previous:
And while I do see the power requirements and the cost of conventional transponders as prohibitive, we could perfectly do with read-only access to Flarm, especially when it would be considered to include a once-per-minute message when alone in the air.
A common point in many of the recent accidents was that ATC was unaware of them. The reasons for this vary, but another sensing tool might be a remedy.
« Reply #63209 on: July 13, 2020, 09:39:54 pm »
Err yes, I've heard Danes complain about you. :popcorn:
« Reply #63210 on: July 13, 2020, 09:47:11 pm »
I know this is the wrong group to look to for advice regarding TEA restraint but here goes...
I have a line on a Tek 575 through a reliable third party. I haven't seen it yet but apparently it works and the price is good though not jammy-git awesome. Now the 575 is big, has a lot of valves, and honestly, I don't test a lot of transistors any more. I am also trying to clear a bunch of gear from here now that I don't much use. I clearly don't need one.
But it is such a freakin' cool piece of kit. I am sorely tempted to pursue.  :palm:
I do not recommend  restraint but patience: skip it for a 370.
« Last Edit: July 13, 2020, 09:52:14 pm by Neomys Sapiens »
Offline TorinoFermic
« Reply #63211 on: July 13, 2020, 10:27:18 pm »
Got my DE-5000 meter !
[attach=1]
 :-DMM
Offline Mr. Scram
  • Display aficionado
« Reply #63212 on: July 13, 2020, 10:37:14 pm »
[attach=1]
 :-DMM
Two TL-22s?
« Reply #63213 on: July 13, 2020, 10:43:22 pm »
Quote from: TorinoFermic on Today at 18:27:18
> (Attachment Link)
 :-DMM
Two TL-22s?
One to turn into 4 wires kelvin clips with cheap 4-wire the other model is more costly for no fucking reason.
« Reply #63214 on: July 13, 2020, 10:48:04 pm »
Which sort of 741 did they use in those power supplies? I could barely believe it, as even the classics generation has some finer examples.
« Reply #63215 on: July 14, 2020, 12:03:22 am »
I'm sitting and staring at the Peak website. I'm going to order a ESR-70 and bother whether to order it alone or not. I like that the DCA-75 works as a basic curve tracer, but here is a DCA-55 already.
Would be different if someone not too far away would have an urgent need for one?
Offline tggzzz
« Reply #63216 on: July 14, 2020, 12:28:40 am »
Understood, accepted, and now it is my turn to be tired :)
I believe there were also fatalities in the Netherlands, but I would want to check that. That's a side effect of not having flown recently: "loss of currency". Regaining currency normally entails having check flights with instructors, but that is problematic at the moment!
FLARM keeps tight control of their software. The software attempts to understand what the pilost are trying to do (e.g. thermal, ridge soar etc) and adjusts the collision warnings appropriately. That requires that all FLARMs are running the same software, i.e. that all FLARM sets have been updated. That is a solid technical reason, even though it annoys open source/API zealots.
The UK has been very different to Europe, historically, about gliding. There was a famous meeting when this was being hammered out in the late 40s/early 50s when the authorities were made to realise that they didn't want responsibility for gliders, and so handed that to the British Gliding Association. The BGA has been extremely competent, technically and in defending gliding interests.
I haven't heard any objections to SSR, except cost and technical practicality. They don't like rich people (airlines) forcing expensive equipment onto General Aviation owners, especially when the GA owners don't get any benefit.
Not sure about ultralights. Batteries and antenna mounting will be a problem, especially with ultralights and parasails.
See point above about maintaining common functions across all users.
If they are flying in uncontrolled Class G airspace, then ATControl don't need to be aware of them and actually don't want to have to be aware of them. Awareness -> control -> responsibility -> too much workload.
« Last Edit: July 14, 2020, 12:30:31 am by tggzzz »
« Reply #63217 on: July 14, 2020, 12:42:45 am »
You might be on to something here. But in this case I have to wonder why that hyperactive product manager / sales honcho had me work several months on it, as that guy has an ATC background. :o
« Reply #63218 on: July 14, 2020, 02:02:23 am »
Sorting components is always good for a surprise. Todays' was discovering that the roll of ominous 1.? Ohm resistors in the piggy box is actually a roll of several hundred Milspec 2.7µH inductors.
Could be worse.
Online mnementh
  • *Escaping The Suck*
« Reply #63219 on: July 14, 2020, 03:15:18 am »
Got my DE-5000 meter !       :-DMM
Welcome to the tan δ side... we have cookies.  >:D
In all honesty... I use my DE-5000 a lot more than my ESR70+ nowadays; and now that I have the MS-8911, I'll probably use it even less for the one purpose I do still use it: quick & dirty board diag.  :-//
https://www.ebay.com/sch/m.html?_odkw=de5000&_ssn=eina-japan&_osacat=0&_from=R40&_trksid=p2046732.m570.l1313.TR11.TRC2.A0.H0.Xde-5000.TRS0&_nkw=de-5000&_sacat=0
https://www.amazon.com/MASTECH-MS8911-Tester-Scanning-Counts/dp/B07P3J146D
*heeds Hypnos' siren call*
« Last Edit: July 14, 2020, 03:20:44 am by mnementh »
The following users thanked this post: TorinoFermic
Online mnementh
« Reply #63220 on: July 14, 2020, 03:47:12 am »
Greetings
matt
Now THAT is some hardcore MacGyverfyin' right there! Well done!  :clap:
*knocks self unconscious with a tapir mallet*
The following users thanked this post: madao, tonyalbus
Offline capt bullshot
« Reply #63221 on: July 14, 2020, 05:24:19 am »
Did you notice Reichelt sells them for less EUR than Peak GBP?
« Reply #63222 on: July 14, 2020, 06:50:12 am »
They used these from Motorola, made in Korea:
The following users thanked this post: Neomys Sapiens, tonyalbus
Offline BravoV
  • +++ ATH1
« Reply #63223 on: July 14, 2020, 07:34:00 am »
I did, while ago while salvaging laptop cells, its Panasonic 2500mAh cell, using CC & CV PS, set to CC at 50mA and CV at 4.1V, once it reached 4,1V, then did re-cycle charge & discharge at my LiIon charger set at 0.5C. Managed to recover it back, though at about 75% capacity, but I guess it depends on how long its been soaked at that low voltage.
Worth a try though.
Online med6753
« Reply #63224 on: July 14, 2020, 08:20:26 am »
Tomorrow's road trip to visit nixiefreqq and pick up the Type 561B and take a quick tour of the Gettysburg battlefield. It will all be easy high speed cruising on interstate highway except the section from Harrisburg to Gettysburg. Going to try to make round trip all in one day but I'll pack an overnight bag just in case. The weather will be hot and clear so A/C use mandatory.
I'll be leaving here about 0430 hours tomorrow.
