Brumby, PA0PBZ, BU508A, Saskia, Sas, Specmaster, mansaxel, Robert763, capt bullshot, Calambres, Cubdriver, med6753 and 48 Guests are viewing this topic.
I’d just like to drop a fuck you in here to oscillators. Especially ones that worked absolutely fine yesterday but not today
Quote from: Cerebus on August 02, 2020, 04:18:49 pmQuote from: mnementh on August 02, 2020, 03:28:48 pmAnd there was another brand I can't remember now with a square of skin big enough to identify as pig, hairs included. *blerk*What? You asked for dead pig, you got dead pig - where's the problem. At least it wasn't chittlin's.It was supposed to be a chicken pot pie. mnemAt least it wasn't rabbit.
Quote from: bd139 on August 02, 2020, 05:27:08 pmI’d just like to drop a fuck you in here to oscillators. Especially ones that worked absolutely fine yesterday but not today Just build an amplifier, guaranteed success!
This weeks installment of toolpr0n for you: connector contact insertion and removal tools (a small assortment of)
Quote from: mansaxel on July 31, 2020, 01:12:58 pmWhat's the trick to get a module out of the frame if the handle is broken? I did use the following trick, which is applicable if the remaining part of the lever is visible and functional:<snip>
Quote from: Cerebus on August 02, 2020, 04:18:49 pmQuote from: mnementh on August 02, 2020, 03:28:48 pmAnd there was another brand I can't remember now with a square of skin big enough to identify as pig, hairs included. *blerk*What? You asked for dead pig, you got dead pig - where's the problem. At least it wasn't chittlin's.Disgusting, but at least not as bad as shot in wild fowl dishes. Especially since that thrice-damned steel shot. Broke a tooth on a single #7 or #8 pellet in a partridge confit.
This weeks installment of toolpr0n for you: connector contact insertion and removal tools (a small assortment of)[attach=3][attach=2][attach=1]Lower part on the first pic are all Mil-listed, upper part around half. This is a field which is likely to rub the inadequacy of one's kit right under your nose. Wayyyy to go until I am able to handle just all of those connectors which I have already encountered, and just more so if I include all those which I am likely to encounter.
Quote from: Neomys Sapiens on August 02, 2020, 06:24:59 pmThis weeks installment of toolpr0n for you: connector contact insertion and removal tools (a small assortment of)[attach=3][attach=2][attach=1]Lower part on the first pic are all Mil-listed, upper part around half. This is a field which is likely to rub the inadequacy of one's kit right under your nose. Wayyyy to go until I am able to handle just all of those connectors which I have already encountered, and just more so if I include all those which I am likely to encounter.Having had to professionally purchase some of that tackle in the past I shudder at what that tool case represents in "new replacement cost" real money.
Quote from: Neomys Sapiens on August 02, 2020, 06:24:59 pmThis weeks installment of toolpr0n for you: connector contact insertion and removal tools (a small assortment of)This is an area where the hunt for completeness will kill you. I admire the effort. And here I thought I was a crazy man for owning 6 torque wrenches.
Quote from: Neomys Sapiens on August 02, 2020, 06:44:10 pmQuote from: Cerebus on August 02, 2020, 04:18:49 pmQuote from: mnementh on August 02, 2020, 03:28:48 pmAnd there was another brand I can't remember now with a square of skin big enough to identify as pig, hairs included. *blerk*What? You asked for dead pig, you got dead pig - where's the problem. At least it wasn't chittlin's.Disgusting, but at least not as bad as shot in wild fowl dishes. Especially since that thrice-damned steel shot. Broke a tooth on a single #7 or #8 pellet in a partridge confit.There's really no excuse for this nowadays is there? Now they're using steel shot it's easy enough to detect electrically. Most commercial food factories have magnetic/inductive sensing to make sure that a nut or washer off the machinery hasn't made its way into the product. Surely that can be repurposed for game?
Quote from: Cerebus on August 02, 2020, 06:56:17 pmQuote from: Neomys Sapiens on August 02, 2020, 06:24:59 pmThis weeks installment of toolpr0n for you: connector contact insertion and removal tools (a small assortment of)Lower part on the first pic are all Mil-listed, upper part around half. This is a field which is likely to rub the inadequacy of one's kit right under your nose. Wayyyy to go until I am able to handle just all of those connectors which I have already encountered, and just more so if I include all those which I am likely to encounter.Having had to professionally purchase some of that tackle in the past I shudder at what that tool case represents in "new replacement cost" real money.Indeed. And aquisition was not exactly free. It is about 1/3 regular purchases, 1/3 surplus and ebay and the remainder found/migrated/contributed by others.
Well, I was all set up to join the discord session last night and guess what, I fell asleep. It was so bloody hot last night in my small lab that I just dropped off to sleep. I had 3 fans switched on to cool the place down and still it was 33C in here . I'm guessing that the body just shut itself down to. Did I miss anything good?
Quote from: Neomys Sapiens on August 02, 2020, 07:02:39 pmQuote from: Cerebus on August 02, 2020, 06:56:17 pmQuote from: Neomys Sapiens on August 02, 2020, 06:24:59 pmThis weeks installment of toolpr0n for you: connector contact insertion and removal tools (a small assortment of)Lower part on the first pic are all Mil-listed, upper part around half. This is a field which is likely to rub the inadequacy of one's kit right under your nose. Wayyyy to go until I am able to handle just all of those connectors which I have already encountered, and just more so if I include all those which I am likely to encounter.Having had to professionally purchase some of that tackle in the past I shudder at what that tool case represents in "new replacement cost" real money.Indeed. And aquisition was not exactly free. It is about 1/3 regular purchases, 1/3 surplus and ebay and the remainder found/migrated/contributed by others.If you're feeling really generous to the community... some close-up pics with mic'd-out dimensions would be a huge contribution. Even if it's just a few of the ones you've used most.Cheers,mnemThis spoo is not fresh.
Quote from: Specmaster on August 02, 2020, 07:25:56 pmWell, I was all set up to join the discord session last night and guess what, I fell asleep. It was so bloody hot last night in my small lab that I just dropped off to sleep. I had 3 fans switched on to cool the place down and still it was 33C in here . I'm guessing that the body just shut itself down to. Did I miss anything good? In the chat were some people, e.g. bd139, but in the audio channel there were only four of us:Saskia, ch_scr, BU508A and AVGresponding. But a lot of people left early, probably for being tired.Perhaps next discord session, if the heat stays away.
Quote from: Cerebus on August 02, 2020, 06:53:28 pmQuote from: Neomys Sapiens on August 02, 2020, 06:44:10 pmQuote from: Cerebus on August 02, 2020, 04:18:49 pmQuote from: mnementh on August 02, 2020, 03:28:48 pmAnd there was another brand I can't remember now with a square of skin big enough to identify as pig, hairs included. *blerk*What? You asked for dead pig, you got dead pig - where's the problem. At least it wasn't chittlin's.Disgusting, but at least not as bad as shot in wild fowl dishes. Especially since that thrice-damned steel shot. Broke a tooth on a single #7 or #8 pellet in a partridge confit.There's really no excuse for this nowadays is there? Now they're using steel shot it's easy enough to detect electrically. Most commercial food factories have magnetic/inductive sensing to make sure that a nut or washer off the machinery hasn't made its way into the product. Surely that can be repurposed for game?A major point about game is that there is no factory.If you buy a game fowl, there has to be shot in it, somewhere vital.
