Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 3429148 times)
K0ELB, Robert763, Saskia, battlecoder, med6753, tonyalbus and 21 Guests are viewing this topic.
Offline 0culus
« Reply #65275 on: August 03, 2020, 03:19:55 am »
Use a pocket protector. I bet those are fairly universally sized.  :P
Except no one probably knows what they are anymore except for hardcore nerds.
Offline bitseeker
« Reply #65276 on: August 03, 2020, 03:58:35 am »
Crap, one of the seller on ebay accepted my lowball offer on one of those old Fluke shunt  :palm:
They are really not helping.
Good catch, Kosmic. Now, you need an 8100A to go with it, like this. Side-by-side, the output of the shunt is right next to the input of the DMM. ;)
The only thing I don't like about the A90 is the handle. It's the newer style that doesn't have a rotating crossbar. As a result, it doesn't fold under the enclosure like the early 8100A can (later 8100A also have the annoying handle).
« Last Edit: August 03, 2020, 04:06:52 am by bitseeker »
I TEA.
The following users thanked this post: Kosmic, tonyalbus
Offline bitseeker
« Reply #65277 on: August 03, 2020, 04:02:29 am »
[...] Dumbfuckistan units.  :-DD
OK, is this really necessary?  ::)
...not saying Imperial units are good mind you. I like my powers of 10.  >:D
He's just flexing his recently acquired metricness. :-DD
« Last Edit: August 03, 2020, 04:05:16 am by bitseeker »
I TEA.
The following users thanked this post: tautech, mnementh, nixiefreqq, 0culus
« Reply #65278 on: August 03, 2020, 04:37:54 am »
Here in Sweden, the most common use today is by nurses. Of which there are more than the particular pocket-protector-worshipping class of nerd.
/has fountain pens but no protector..
Online BravoV
  • +++ ATH1
« Reply #65279 on: August 03, 2020, 05:05:02 am »
Question for all of you. What common object, other than a ruler, would one use for scale in a photograph that is universal? Yeah, a ruler works but it doesn't have that same visceral feel that, say, a box of matches does.
For the Brits, a standard box of matches would work, but the "standard box of matches" varies in size around the world. A packet of Gitanes is the same size the world over but most people don't have a pack of French Cancer Sticks to hand. A bunch of keys? Pretty universal but you don't really want to embed the key profile of your front door key in a photo for publication. I've been over a few other things in my mind and discounted all of them as not universal enough. Pencil? The ubiquitous Bic? Too long and thin. Cups and cutlery are too variable in size.
I finally hit on a standard pack of playing cards. Right kind of scale, the same size all over the world, something that fits in the hand.
So, can anyone else think of a common household object that is truly universal worldwide, and that fits the bill better than a pack of cards? Thoughts? Something obvious that I've missed?
For sure in this electronics world, my fav is TO-220 as in my most posted photos.  :P
The following users thanked this post: Robert763, mnementh
Offline Zoli
  • Grumpy old men
« Reply #65280 on: August 03, 2020, 05:11:40 am »
 :popcorn:
Yes. Yes, it REALLY IS necessary.  >:D Kill them with fire.  :-DD
And shoot the ashes into the sun. On a rocket programmed in a mix of both units.   :scared:
Only if you want to miss te target.  :-DD :-DD :-DD
Online tggzzz
« Reply #65281 on: August 03, 2020, 06:43:04 am »
For no good reason I stumbled out of bed a few minutes early this morning. Went to kitchen to get coffee, glanced out the back, then rushed to get my camera.
Sometimes it is worth getting up.
The following users thanked this post: Zucca, Cerebus, drussell, BU508A, med6753, capt bullshot, bd139, nixiefreqq, Kosmic, TorinoFermic
Online tggzzz
« Reply #65282 on: August 03, 2020, 06:49:39 am »
Your contention about this relative strength of PLA vs SLA is unsubstantiated and contradicted in my experience and examples.
I too have doubts about SLAs long term stability, it isn't a wonder material. I also have doubts about PLAs long term stability. But if PLA isn't strong enough when manufactured, it isn't going to get any stronger!
OK. I'm confused. PLA (polylactic acid) is a material. SLA (stereolithography) is a process, which can use many different resins. So surely any comparison is a chalk and cheese one unless someone mentions what particular SLA resin is being compared.
A quick survey suggests that SLA materials seems to range from a rather nebulous "standard", "transparent", "durable", "ceramic reinforced" of unnamed chemistry  with ultimate tensile strengths ranging from 31-75 MPa, Young's modulus of 1.3-4.1 GPa, all the way through to familiar engineering materials of ABS, Nylon, SBR/TPR. For reference the first set of material properties I can find for PLA are UTS=26.4 Mpa,  and Young's modulus of 2.3 GPa.
I can't find figures for long term stability for any of these materials that are useful for objective comparison, they're all "n out of 10" type comparative scores and I'm suspicious whether those amount to anything more than pure hand-waving.
Just to put those into perspective, typical properties for more familiar materials:
MaterialUTS (MPa)Tensile Modulus (GPa)
Nylon 66 (average, unreinforced)61.62.3
Aluminium (1050-H14)10570
Low Carbon Steel (EN1A)480207
Both the metals are selected for being the 'weakest' of their elemental ilk in everyday commercial use.
I'd have preferred to quote tensile yield strengths (or proof strength) rather than UTS, generally that's a much more useful parameter to design around, but the 3PD type folks only seem (in general) to list UTS for their materials.
All good solid points.
There are now more materials available than when I printed my handles 4 years ago. All I can say is that I got them at https://dirtypcbs.com/store/print3d because it was stunningly cheap. It would not surprise me if the material had changed since then, possibly for the better.
Online tggzzz
« Reply #65283 on: August 03, 2020, 06:59:22 am »
Nonetheless snipping context is liable to mislead and is unnecessary; this isn't stackexchange or edaboard, thank deity.
We've been over the snipping matter a couple of times before. It hasn't caused any confusion. The full contect is preserved in the original post and the reply for everyone to see. It prevents inane repetition and visual clutter. I'm sorry to hear it upsets you but I don't feel that responsibility is on my end. Here too repetition is outliving its usefulness.
Confusion, no - but I haven't claimed that.
"Context is preserved" always makes me think of leopards, as in https://www.goodreads.com/quotes/40705-but-the-plans-were-on-display-on-display-i-eventually
There is, of course, good taste involved in the decision as to how much to snip and how much to preserve. Too often I've seen people snipping so much it makes life more difficult for a reader, or worse.
« Last Edit: August 03, 2020, 07:04:41 am by tggzzz »
« Reply #65284 on: August 03, 2020, 07:10:07 am »
I'd suggest D6 (Dice, six-sided). They are very common and the standard size of them is 16x16x16mm³
« Reply #65285 on: August 03, 2020, 07:15:39 am »
Had to google first, what a "pocket protector" is.  :-DD
The following users thanked this post: 0culus, tonyalbus
« Reply #65286 on: August 03, 2020, 07:19:51 am »
On other notes:
Dave is re-stocking his HV differential probes in August.
https://www.eevblog.com/forum/testgear/eevblog-hvp70-differential-probe/msg3170321/?topicseen#new
Quote:
"FYI, I have more stock coming mid August.
No word on the other design yet."
Online Robert763
« Reply #65287 on: August 03, 2020, 07:30:23 am »
Let me guess, you live near Bristol
Online tggzzz
« Reply #65288 on: August 03, 2020, 07:36:38 am »
Brizzle, please :)
Online Robert763
« Reply #65289 on: August 03, 2020, 09:22:27 am »
I studied in Brizzle in the early 80's
« Reply #65290 on: August 03, 2020, 09:50:57 am »
Not to sure about worldwide but certainly UK wide, a £1 coin. Playing cards don't hack it for me because you certainly can get different sized packs of playing cards, for instance, you can get tiny ones in Xmas crackers for a start  >:D
Brymen-Fluke-Solartron-HP-Thurlby-Heathkit-Thander-Tek-Extech-Black Star-GW-Advance-Avo-Kyoritsu-Amprobe-ITT-Robin-TTi
« Reply #65291 on: August 03, 2020, 09:53:49 am »
OK, I'll ask the question, that everyone else is scared of asking, why does living near to Bristol or Brizzle :-//
« Reply #65292 on: August 03, 2020, 10:05:26 am »
Happy happy joy joy. Both 3478A and TG320 are out for delivery today. Fingers crossed
The following users thanked this post: xrunner, BU508A, mnementh, Specmaster, Kosmic, TorinoFermic, tonyalbus
« Reply #65293 on: August 03, 2020, 10:18:47 am »
When I google for Bristol, I'm getting a nice picture of one of the inhabitants there.   :-DD
[attach=1]
Online Robert763
« Reply #65294 on: August 03, 2020, 10:52:45 am »
Bristol is home of Cameron Balloons and holds a large hot air balloon festival.
Online tonyalbus
    • My Channel
« Reply #65295 on: August 03, 2020, 10:53:43 am »
5315B coming my way.... 8)
seems a professional seller.....putting it on a soft bed.
[attachimg=2]
and i get some extra's
[attachimg=1]
a home made something...
Marconi 2955/2432A/2414A - TTi TF930/TF600/TG102 - HP5302/5315/5323/5385/3478 - Fluke 8000/8010/8125 - SDS1202X-E -XDM2041 - TEK 475 - Anritsu MS610/MF1603 - Keitley 199 - PM2521/2522/2527
https://www.youtube.com/channel/UCwLPcv2xiA3D9lfGArF58ww
The following users thanked this post: med6753, mnementh, wolfy007
« Reply #65296 on: August 03, 2020, 10:54:30 am »
A soft bed of fox urine  :-DD
The following users thanked this post: mnementh, Specmaster, tonyalbus
Online tggzzz
« Reply #65297 on: August 03, 2020, 11:03:19 am »
Fish.
Online tggzzz
« Reply #65298 on: August 03, 2020, 11:06:35 am »
[attach=1]
I wouldn't call my ex famous :)
Online med6753
« Reply #65299 on: August 03, 2020, 11:14:11 am »
Over here could be that and more. Coyote, turkey, woodchuck (ground hog), feral cat, raccoon, possum, even bear.
"Does the bear shit in the woods"? Don't bet on it.  :-DD
