Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 4042512 times)
mnementh, Neomys Sapiens, Gromitt, Specmaster, Saskia, Kosmic, ch_scr, BILLPOD, SingleBitError, faraday, med6753, bd139 and 41 Guests are viewing this topic.
Online Kosmic
« Reply #65725 on: August 06, 2020, 01:00:00 am »
Hirez pictures can be found here: https://1drv.ms/u/s!AjGAejk8r_C1kal4yyA4VkCAooa7Mw?e=xGoDhc
Thanks for those. I'm not familiar with that kind of designing. What do the isolated pads function as? Are they some sort of RF load, or a capacitive-coupled path or ... ?  :-//
I'm wondering the same thing. I think they reuse the same boards and wire bound the pad they need base on the amplifier they are building. So if it's not wire bounded I would guess it's not really participating to the circuit.
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #65726 on: August 06, 2020, 01:08:50 am »
Today my EPROM Eraser showed up which I've bought here (NAWTS).
I've ordered it in France, because I didn't want to wait for the nine-Euro-version from China.
I've tested it with some 27C1001 EPROMs and it is doing its job. That's all I wanted. But I'm convinced, it will for sure not meet the VDE safety standards or the CE standards (EMI).
Thanks for watching.
Line the rest of the box with foil and tie it to earth, EMC (kind of) solved. :D
Any circuit design must contain at least one part which is obsolete, two parts which are unobtainable, and three parts which are still under development.
https://www.youtube.com/user/NearFarMedia/
Offline Mr. Scram
  • Display aficionado
« Reply #65727 on: August 06, 2020, 01:13:20 am »
I participated once. Didn't really knew about those threads at the time. I had a useless exchange about peek detect mode and memory size. Never again.
That's the problem. Sensible people run away and newcomers are left with the vultures.
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #65728 on: August 06, 2020, 01:24:21 am »
When you look closely the whole circuit is full of capacitive "islands" that can be bonded or left out, or parallel circuit paths that are bonded into the circuit, and so on. These are
the microwave equivalent of C and L trimming in classical circuits. The sheer number of these tunable elements is astonishing; Making this part is certainly a low-automation job with a lot of bond/measure/repeat cycles until everything is in spec. Today a MMIC probably does everything with no adjustments needed.
The following users thanked this post: xrunner, Mr. Scram, Kosmic
Online mnementh
  • *Escaping The Suck*
« Reply #65729 on: August 06, 2020, 02:34:52 am »
Thanks for taking the time, K... I've been hoping you would ever since I saw them in the trunk of your car.  :-DD
 :popcorn:
Offline 0culus
« Reply #65730 on: August 06, 2020, 04:06:15 am »
The seller of those P6008 probes is trying to tell me that the Type 82 plugin with it's 15 pf inputs won't work with them and yada yada vacuum tube scopes something or other and he needs it back to twiddle with it.  ::) Uhhhh, the Type 82 plugin came with two of them when it was new. I asked for a partial refund or another unit. We'll see.  :popcorn:
Offline Ero-Shan
« Reply #65731 on: August 06, 2020, 05:27:23 am »
@BU508A: from here, I would look for the Belzer variant. They are sometimes to be had rather cheap on Ebay, as most people don't seem to understand what they are. They are 100% compatible with the blades from Ideal. Its the 3418 in this case.
With "Ideal" you are meaning the guys from Ideal-Tek in Switzerland?
Checked their website but I didn't find the blades for the Belzer wire stripper.
Currently, there are some Belzer wire strippers offered in the bay of evil. Some of them are used ones from the Bundewswehr but I'm a bit hesitating about them. The 3418-C is looking interesting.
I've just ordered one of those, AWG16..26 (from the picture), just hoping it's still usable.
« Reply #65732 on: August 06, 2020, 06:29:51 am »
<snip>
After or before you've enhanced it?  :-DD :-DD
Seriously, the major problem with self-certification along the CE marking model is that it lacks "nuke'm from orbit, land, plow the land and spread salt over the fields" termination clauses in the legislation. It is largely painless and cheap to get caught peddling broken stuff, so people take their chances, especially if they're only one step in the value chain. There is always someone else to blame.
The old SEMKO / DEMKO / VDE / UL / CSA model was hampering innovation and was a market blocker; we do not want that again. What we need is a way for manufacturers and vendors to feel the pain.
Offline psykok
« Reply #65733 on: August 06, 2020, 07:00:18 am »
hi,
yesterday I got another  really interesting piece of equipment : Panasonic Vp7722A
[attach=1]
Unfortunately this one is faulty and need a repair .
Apparently it get suck at the boot/init procedure, all the leds are on and no keys are responding.
The following users thanked this post: Zucca, mnementh, tonyalbus
Offline tonyalbus
    • My Channel
« Reply #65734 on: August 06, 2020, 07:10:51 am »
hi,
[attach=1]
looks cool!    allmost as Anritsu did that design...:)
Marconi  - TTi - Thandar - Thurmbly - HP - Fluke - Philips - Siglent - Owon - TEK - Anritsu - Keitley - AVO - BG7TBL
Online BU508A
« Reply #65735 on: August 06, 2020, 07:27:56 am »
hi,
[attach=1]
I've thought the very same thing. ;D
Offline psykok
« Reply #65736 on: August 06, 2020, 07:40:28 am »
These Panasonic  Matsushita instrument can often  be found under other brand in Japan.
Offline tonyalbus
    • My Channel
« Reply #65737 on: August 06, 2020, 07:44:03 am »
i hope you get it running again!
Online bd139
« Reply #65738 on: August 06, 2020, 08:02:03 am »
Yea, every few days another newb asks for advice as to what scope to buy and the usual suspects jump in and it quickly becomes a bitch-fest and a circle jerk. I never participate in those threads, waste of time.
That's the first thing many newcomers encounter, shit advice and bad attitudes. I don't think it's a good look for the forum and I don't think it's fair to the people asking for help. If these idiots just kept each other busy it'd be fine but people are spending real money on the FUD spouted in those threads. It's just a handful of regulars running amok so getting them in line or giving them the boot should be doable.
That’s about right. I had another account on here and was put off contributing a few years back by such folk. I came back with a “fuck you” attitude in the end.
My favourite is the: ”What scope should I buy to help trace problems in audio amps. My budget is $50”
The solution is clearly: “Oh you need a DS1054Z. No can’t buy Chinese crap you need a Keysight. No Lecroy only. Ooh to check that signal integrity you need a Keysight UXA.”
Now I spent a good few years of my life with a 5 MHz single trace analogue from a car boot sale and that’s and a brain is enough for that task. So I throw in the “any old 20mhz shit box analogue that is sold working”. Unfortunately the next thing I get is a lecture on signal integrity which is irrelevant for the purposes of ”visual signal tracing” which is what the original poster really needs to do.
Occasionally I like to throw in a comment to piss the sensitive people off now which is that I rewired my house with a UT61. Also owning and liking a TDS210 seems to inflame some  :-DD
« Last Edit: August 06, 2020, 08:05:37 am by bd139 »
The following users thanked this post: Mr. Scram
Online BU508A
« Reply #65739 on: August 06, 2020, 08:10:17 am »
Sad, but true.  |O
Offline tonyalbus
    • My Channel
« Reply #65740 on: August 06, 2020, 08:28:44 am »
i am only in this endless thread, no problem here ;)
Offline tonyalbus
    • My Channel
« Reply #65741 on: August 06, 2020, 08:29:23 am »
300!! just wanted to say that  :-DD
Online BU508A
« Reply #65742 on: August 06, 2020, 08:48:59 am »
That's the charme of this thread. Whenever you are visiting it, one can watch
- med painting something blue, except it is his bedroom
- Saskia playing with 50g of ceefour
- bd139 is buying / selling something
- tony is buying a counter.
- nixiefreqq is ranting about RPN calulators
- the Dwagon is lamenting on <insert topic of your choice here>
- tautech is playing with Siglent stuff
- BU508A is trying to find strange R&S gear
- Zucca has this ongoing marriage-project
- bitseeker is trying to catch-up
- 0culus buying another RPN calculator 1
- cubdriver is frolicing around with his cats 1
- not sure what Cerebus is doing but I think it has something to do with magic smoke and syringes 2
- Neomys Sapiens explaining the MIL-Standards of cables and connectors and showing us toolsets for assembling them 3
please feel free to add any thoughts to this list.    :-DD
1 Edit 1
2 Edit 2
3 Edit 3
« Last Edit: August 24, 2020, 08:30:54 pm by BU508A »
The following users thanked this post: tautech, Zucca, bitseeker, med6753, bd139, FransW, nixiefreqq, Saskia, tonyalbus
Offline psykok
« Reply #65743 on: August 06, 2020, 09:03:40 am »
I hope so but I'm not so sure I will be successful.
The SM is not that great and you cannot found a lot of information about this unit anyway.
I just hope I do not have some corrupt ROM or something like that because it will hard to solve.
Online Saskia
« Reply #65744 on: August 06, 2020, 09:05:57 am »
look what I found in the mail.
Guess what it is.
Offline tonyalbus
    • My Channel
« Reply #65745 on: August 06, 2020, 09:10:01 am »
[attachimg=1]
Offline tonyalbus
    • My Channel
« Reply #65746 on: August 06, 2020, 09:11:46 am »
looks like its missing some parts, but thats my unprofessional opinion... (un asked)  :-DD
Online Saskia
« Reply #65747 on: August 06, 2020, 09:13:53 am »
yarp. I will need to slaughter a couple of donor boards
Online bd139
« Reply #65748 on: August 06, 2020, 09:16:43 am »
Guess what it is.
Ugh it's a VIC20  :-DD
Online Saskia
« Reply #65749 on: August 06, 2020, 09:24:58 am »
 :P
