BU508A, Saskia, 25 CPS, Kosmic, mansaxel, Zucca, bd139, Mortymore, Specmaster, Robert763, BILLPOD and 73 Guests are viewing this topic.
TBH Med, if you have a hot air rework station, I'd be inclined to select a small nozzle, low air flow, medium to high heat, cut of the excess cap legs flush with the solder, then apply heat slowly to each caps joints, alternating while trying to insert a screwdriver blade between the board and the cap to gently lever it out of the holes as the solder melts. Once out you'll be able to use the wick method to clean the holes ready for the new caps to go in.
Quote from: Specmaster on October 30, 2020, 11:08:28 amQuote from: med6753 on October 30, 2020, 10:17:54 amDefeated right from the get go. None of my soldering/desoldering equipment can generate enough heat to properly wick the solder off these capacitors. Even braid dipped in liquid flux. The mass of those capacitors acts like a giant heat sink. My suction bulb desoldering iron just sits there with very little melt. The pix shows about 20 minutes of freaking around just making a fucking mess. Obviously I need a heavy duty vacuum pump desoldering station. Recommendations? Hopefully something that will do the job without spending a fortune. I know Hakko has one but it's damn near $300 USD. I'm looking to spend less than that.Going to clean up this mess and reassemble everything and call it a day. Use a high power solder gun like the one in the photo? https://www.amazon.com/Weller-GT7A-Solder-Solid-State/dp/B0042T1G0I/Good lord... that thing dates back to Edison FFS. At least suggest something civilized with temp control like a GT7... mnem
It looks like an issue with freedesktop drm, not just Intel. Same thing will happen on that kernel on an AMD / Radeon machine.This is also a 4 watt TDP CPU with no active cooling which doesn't really exist in the AMD space.
Quote from: bd139 on October 30, 2020, 07:01:08 pmIt looks like an issue with freedesktop drm, not just Intel. Same thing will happen on that kernel on an AMD / Radeon machine.This is also a 4 watt TDP CPU with no active cooling which doesn't really exist in the AMD space.Similar thing with Geforce GPUs. If the cable is not plugged in during power on, getting a picture (at least on Win 7) is pure luck. At least that's my experience.
my translator is back in business after huge maintenance.translation speed in text box is almost instantaneous across the more than 3 dozen language pairs. Will have to tweak performance a bit for large batch jobs. Now let's see if I can grow my internal business to > 50k translations/day ...
A few days ago I posted some information about the Psion Revo Plus and ordered some replacement batteries for it. Today they arrived and I soldered the batteries up in the same fashion as the ones removed and refitted the thermal overload, refitted the cover, and man what a bastard that is to do as well, so little space for tools especially when you have extra large hands like I have and after a struggle I was able to get the spring that holds the clamshell closed fitted and it all works again now that the battery has been charged up. It certainly isn't a job for the faint-hearted but seeing as the current price for replacing the batteries is £75 plus carriage I thought I'd have ago, batteries were £13.85 including carriage, so a good saving was enjoyed, but loose that spring or break the clip and its game over
So I was going to slack off and play with some test gear this evening but now I just spent two hours tracking down a Linux kernel bug. Turns out if you pull an HDMI cable out of an Intel chipset after boot on some kernels it hammers the fuck out of the CPU. Total fail.
Quote from: URI on October 30, 2020, 06:23:53 amI orderer some Felder soldering tin wire Sn60Pb40 from Bürklin (a Munich distributor) the other day.Put it in my virtual basket, made the order only without any hassle. But then...Reaction I got on the invoice (only): Position set to zero, with an information that the manufacturer set a prohibitive note: This soldering tin wire is not available for private buyers any more, only for companies. Well, I can only look at classic soldering tin wire now in webshops but can't buy it?! !@#?§#!! All other parts I ordered were delivered flawlessly as always..I've ordered this at 30.06.2020 at Bürklin. Got delivered without any problems:Bestell-Nr. Artikelbezeichnung Menge Einzelpreis inkl. MwSt. Gesamtsumme inkl. MwSt.11L4370 Lötdraht, 0,5 mm, Sn62Pb36Ag2, 250 g 1 28,56 € 28,56 €11L4372 Lötdraht, 0,75 mm, Sn62Pb36Ag2, 250 g 1 24,276 € 24,276 €11L410 Lötdraht, 1 mm, Sn60Pb39Cu1, 500 g 2 21,063 € 42,126 €86F8918 Ø 4 mm Stecker stapelbar, rot 15 1,5708 € 23,562 €86F8897 Ø 4 mm Stecker stapelbar, schwarz 15 1,5589 € 23,3835 €11L395 Lötdraht, 0,5 mm, Sn60Pb39Cu1, 500 g 1 29,155 € 29,155 € @URILet me know if I can help out, e.g. ordering some stuff at Bürklin.
Solder wire, 0.5 mm, Sn62Pb36Ag2, 1.1.2.BOrder No.: 11L4370Manufacturer: FelderManufacturer No.: 18720520RA 0,5MM 250GOrdering information: not for sale to end-consumers
Quote from: BU508A on October 30, 2020, 09:35:02 amQuote from: URI on October 30, 2020, 06:23:53 amI orderer some Felder soldering tin wire Sn60Pb40 from Bürklin (a Munich distributor) the other day.Put it in my virtual basket, made the order only without any hassle. But then...Reaction I got on the invoice (only): Position set to zero, with an information that the manufacturer set a prohibitive note: This soldering tin wire is not available for private buyers any more, only for companies. Well, I can only look at classic soldering tin wire now in webshops but can't buy it?! !@#?§#!! All other parts I ordered were delivered flawlessly as always..I've ordered this at 30.06.2020 at Bürklin. Got delivered without any problems:Bestell-Nr. Artikelbezeichnung Menge Einzelpreis inkl. MwSt. Gesamtsumme inkl. MwSt.11L4370 Lötdraht, 0,5 mm, Sn62Pb36Ag2, 250 g 1 28,56 € 28,56 €11L4372 Lötdraht, 0,75 mm, Sn62Pb36Ag2, 250 g 1 24,276 € 24,276 €11L410 Lötdraht, 1 mm, Sn60Pb39Cu1, 500 g 2 21,063 € 42,126 €86F8918 Ø 4 mm Stecker stapelbar, rot 15 1,5708 € 23,562 €86F8897 Ø 4 mm Stecker stapelbar, schwarz 15 1,5589 € 23,3835 €11L395 Lötdraht, 0,5 mm, Sn60Pb39Cu1, 500 g 1 29,155 € 29,155 € @URILet me know if I can help out, e.g. ordering some stuff at Bürklin.You didn't order as a private person, did you?The Bürklin web shop says:Code: [Select]Solder wire, 0.5 mm, Sn62Pb36Ag2, 1.1.2.BOrder No.: 11L4370Manufacturer: FelderManufacturer No.: 18720520RA 0,5MM 250GOrdering information: not for sale to end-consumersThanks for your offer to help me. But I think I'll just look for other sources than Bürklin then..
Specmaster has a P.O.TEL. one, would that make it younger than the P.O. one on "richardsradios"?Edit: Specmaster will soon have...
Well it's a headless server so YMMV on that . Fixed. drm related. Add "nomodeset" and "i915.modeset=0" to the kernel parameters.Ffuuuuuuck all I wanted to do was program a sodding AVR.
This'd probably be able to hit both pins of each pair at once...-Pat
Quote from: shakalnokturn on October 31, 2020, 12:16:13 amSpecmaster has a P.O.TEL. one, would that make it younger than the P.O. one on "richardsradios"?Edit: Specmaster will soon have...Haha, no specmaster won’t soon have unless I can cut a deal and it works. These have a higher accuracy than the Avo 8’s with DC being down to 1%
Quote from: URI on October 30, 2020, 09:11:34 pmYou didn't order as a private person, did you?The Bürklin web shop says:Code: [Select]Solder wire, 0.5 mm, Sn62Pb36Ag2, 1.1.2.BOrder No.: 11L4370Manufacturer: FelderManufacturer No.: 18720520RA 0,5MM 250GOrdering information: not for sale to end-consumersThanks for your offer to help me. But I think I'll just look for other sources than Bürklin then.. No, I have here a "Kleingewerbe" and therefore I was able to order it.On a discord session, Neomys Sapiens gave me the tipp about Balver solder. It is Pb-free but the handling feels like the common Sn60Pb40.There is some in the ebay Kleinanzeigen in Germany available (NAWTS):https://www.ebay-kleinanzeigen.de/s-anzeige/2-5kg-balver-zinn-bleifrei-sn100c-sncu0-7ni/1452809623-168-1742
Quote from: Cubdriver on October 31, 2020, 05:37:27 amThis'd probably be able to hit both pins of each pair at once...-PatI have one like that too. 250W, IIRC. I've used it for a desoldering job, someone had made a distributor by soldering a 2,5mm2 wire across the tags of a barrier strip. Took ages to come to proper temperature, but oh did it melt things well! I second the recommendation for a Chinesium solder-sucker station. It's a life saver.
