Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 27848015 times)
wkb, Jouko and 1697 Guests are viewing this topic.
« Reply #115975 on: March 20, 2022, 04:48:31 pm »
Yeah, that was what I searched for as well, but the only one I could find that had legible schizzmatics was the one for the SC110A. If you find one for the SC110 that's legible, you should send it to Ed/BAMA too.
 :-BROKE
Offline Saskia
« Reply #115976 on: March 20, 2022, 05:57:09 pm »
@Robert
finally managed to open the box, very well packaged, thank you for that.
Those 4 little green gizmos appear to be specialized radiation dosimeters.
Do you happen to know if they still work ?
Would you have a manual for those ? I do not want to attract too much attention by sniffing around ...
« Reply #115977 on: March 20, 2022, 06:45:38 pm »
Maybe a wee bit of Kapton tape on probe pin and around ground ring?
 :-/O
Correct, that was what I was referring to when I mentioned caftan tape, I got the name wrong, my bad.
Kaftan tape was what you used to have to put over Demis Roussos' mouth to stop him from singing.  :)
The following users thanked this post: BU508A, Specmaster, mansaxel, Neper
« Reply #115978 on: March 20, 2022, 06:50:20 pm »
Were they drawn by the Judean Popular People's Front?  :)
« Reply #115979 on: March 20, 2022, 07:03:04 pm »
 :o  :-DD  :-DD  :-DD  :-DD
Demis Roussos, the singing whiner on duty.
(Demis Roussos, der singende Jammerlappen vom Dienst.)
« Last Edit: March 20, 2022, 07:24:49 pm by BU508A »
« Reply #115980 on: March 20, 2022, 07:18:06 pm »
I watched about 30 seconds of a video from TOP POP... ghahhh.
There's 2 minutes of my life I'll never get back... :palm:
« Reply #115981 on: March 20, 2022, 07:19:27 pm »
Since we are having here some vehicle crazy people, The Tim Traveller is presenting the world's most bonkers bus:
« Reply #115982 on: March 20, 2022, 07:20:17 pm »
Harr harr harr.  >:D  :-DD
« Reply #115983 on: March 20, 2022, 07:20:35 pm »
That would suggest that one of them actually did something rather than whinge about how bad it was that nobody was doing anything aboot it...  :o
Oh, wait... there was that one... ???
Offline factory
« Reply #115984 on: March 20, 2022, 07:27:55 pm »
Wow, I tried to look for a Sinclair SC110 and found the service manual for that model, not the A variant. Now to see what if any are the differences between the two?
Strange though as mine has Thandar on the enclosure but Sinclair on the main PCB but the control panel is nameless??
The SC110 manuals that are on Bama have both thander & Sinclair on the cover page.
I've had a quick look at both the non A & A version manuals.
Comparing the parts list with the later A version, I see some resistor values have changed and it has at least one extra. Five of transistors are no longer labelled as matched and D17 is a different part no too.
« Last Edit: March 20, 2022, 07:30:47 pm by factory »
Offline Neper
« Reply #115985 on: March 20, 2022, 07:29:47 pm »
 :-DD :-DD :-DD :-DD :-DD
You made my day.
We used to call him Demis Eunuchos.
« Reply #115986 on: March 20, 2022, 07:29:59 pm »
Damn you, BU508A... :-DD
« Reply #115987 on: March 20, 2022, 07:40:01 pm »
@Robert
No idea if those ones work. They were a random handfull out of the untested box. Power is a CR2450 cell negative to the threaded ring and positive to a litte spring contact at the side. The cell covers are unobtanium at a sensible price. I've used  thin piece of steel spring strip or pcb material but easyist is to hot glue a 2x AAA holder on the back. The contacts on the front are for a passive high level gamma and neutron sensor that is independent of the main circuit which uses a PIN diode detector.
Manual attached
The following users thanked this post: Saskia
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #115988 on: March 20, 2022, 07:40:30 pm »
I'm thinking "recent cal".
The following users thanked this post: mnementh, ch_scr, Andrew_Debbie, cyclin_al
« Reply #115989 on: March 20, 2022, 07:43:29 pm »
TE budget in the red for a while.
The following users thanked this post: Vince, BU508A, mnementh, Specmaster, ch_scr, Kosmic, cyclin_al
« Reply #115990 on: March 20, 2022, 08:22:42 pm »
Been there to Mount Pleasant Sorting office in one of my earlier jobs, they used to be customers and been down to that train station doing some work, also there was simply miles upon miles of conveyors within the main building itself moving mail from A to B, C etc with a maze of passage ways weaving their way over, under and through those conveyors and walls etc to get to various depts within the system itself. Of course back then I was a lanky beanpole and able to navigate those routes, now I'd simply get wedged in some locations seeing as I've turned into a large unit with old age  :-DD :-DD
« Last Edit: March 20, 2022, 09:03:28 pm by Specmaster »
Offline Saskia
« Reply #115991 on: March 20, 2022, 08:25:06 pm »
@Mike enjoy  the conditioned climate
« Reply #115992 on: March 20, 2022, 08:40:49 pm »
I certainly will but my wallet won't.  :-DD
« Reply #115993 on: March 20, 2022, 08:46:00 pm »
How did you get this thing upstairs? Had some help (I hope)?
« Reply #115994 on: March 20, 2022, 08:48:12 pm »
Nope, it's still in the CR-V and will remain there until my Son comes over to help me install it. No way will I risk it myself.  :scared:
The following users thanked this post: Brumby, BU508A, Specmaster, ch_scr, cyclin_al
« Reply #115995 on: March 20, 2022, 09:00:19 pm »
I'd seen photos of those buses before, but never knew anything else about them. When I started my apprenticeship with the National Bus Company in 1964, we used to have Midland Red coaches stop at our station on route to London from Birmingham. The reason for mentioning this is that they actually build their own buses and the most famous of them was the CM5 as shown in this video. Built in 1959 for use on the UK's first motorway, the M1. Apart from being (to my mind at the time) ugly with that bulging windscreen, they were actually capable of speeds of 85MPH, which at that time was unheard of before as buses and coaches were limited to just 30MPH, but seeing as they were designed to offer high speed travel on the M1 between Birmingham and London to rival trains, they were given a higher speed limit of 70MPH.
« Reply #115996 on: March 20, 2022, 09:11:20 pm »
Made some progress today with the Thandar SC110 mini portable scope, stripped it down for fault-finding and after a good long coat of looking at under magnification I have so far failed to find a smoking gun, it really all looks pretty good to me. All the solder joints that are visible without further stripping seem to be in good condition, maybe I might find something lurking beneath the vertical and horizontal board once I remove it, who knows.
I find a few caps with small holes in them, but they exhibit zero outward signs of suffering, the holes appear to have been there from new  :-//.
Here a few pics so far, I doubt that I shall be working on it tomorrow as I shall be over at Hangar 11 collection, working on that Ferguson TE20 tractor restoration.
I guess you have tried an external X input, as the "Trig sweep/Ext X" switch seems to be set to the Ext X input, that will disable the sweep. Those push button switches are often found with very dirty contacts, in the older HP scopes I've been bought, often nothing happens until they have all been exercised many times.
Those through-pins, that join that tracks on the top & bottom of the boards were often a nightmare at work, we would get intermittent faults that were usually one of more of those crappy things, the only solution for us was to replace them all to avoid warranty claims, they were often too tarnished to resolder.
I haven't yet tried an external signal, mainly because I don't have a sig gen handy on the bench at the moment, but I'm thinking about tracking one out and doing just that, what sort of input would it require, sine, square, or triangle?
Offline factory
« Reply #115997 on: March 20, 2022, 09:18:02 pm »
Anything you like from DC up to 2MHz, max voltage 2.5V according to the book, it's the external X input for use in X/Y mode, just with some limitations.
With DC you should be able to get full deflection of the dot either way, with positive one way, negative the other, center the dot with the X position first. Hopefully this will confirm if the X output amp is working.
P.S. Oh I was wrong yesterday about the switch position, the labelling is in for normal sweep & out for external X input.
« Last Edit: March 20, 2022, 09:54:49 pm by factory »
Offline dl6lr
« Reply #115998 on: March 20, 2022, 10:01:38 pm »
Found some small capacitors. In fact, eight of them.:
Those are 65mm diameter and 150mm height, screw terminals.
Charged them slowly to 32V for a test, measured 30V after 8h being disconnected.
In the same box: 20 of these Siemens caps:
very small footprint: 35mm diameter and 85mm height.
« Last Edit: March 20, 2022, 10:13:23 pm by dl6lr »
The following users thanked this post: mnementh, ch_scr, cyclin_al, DH7DN
Offline Saskia
« Reply #115999 on: March 20, 2022, 10:18:04 pm »
where ? I need some of those for experiments with 2 adjacent rails ....
