Working a bit on my Metrix 920 RF gen this afternoon.
Thinking of selling it to downsize.
Bought it 15 months ago, back then fixed a failed filter cap in the PSU and then it worked fine.
But of course I wanted to try it again to make sure it still worked, because I am that nice.
Well I am glad I did that because for sure it didn't work any more !
Looks like sitting for a year in heated house does damage...
1) For the life of me I can't put my hands on the power cord ! Uses an obsolete plug of course, so it was vital
So had to resort to a sketchy montage to power it up. Don't try this at home.
2) Had no output at all... eventually found out that inside the attenuator assembly (that big aluminium cylinder in the inside pic), the wire that goes to the center pin of the coax connector on the front panel... somehow came off. Solder joint broke.
So I soldered it back but... after only a couple seconds of me heating up the pin, said pin would move around ! Yes, the dielectric in the coax connector was softening so bad, like butter !
Yes, I was using a soldering iron not an oxyacetylene torch...
Could not believe my eyes. I guess that's the final nail in the coffin for this connector, which has been the subject of a much heated debate here on TEA at the time, I remember vividly...
I could not buy anywhere a BNC adapter that would fit. I could find an adapter, but the belling-lee side of it was not split/slotted, so it had no springiness to it, keeping it from mating with the socket. So Specmaster suggested to replace the connector with a panel mount BNC connector... tempted now, or not. If I am selling it, no need to bother.
Anyway, this fixed it ... or part of it. I now get a signal on the front panel.. but only the LF / 400Hz modulation frequency.
2) HF doesn't work, yes two problems at once, my luck.
There are only two tubes in this thing (other than rectifier tube). Both are 6J6, dual triode.
One of them makes the oscillator for the HF. The other has one triode doing the LF oscillator, and the other triode mixes the LF and HF to produce the final signal that goes to the front panel.
So I swapped the two tubes, and hey presto I now have HF !
So I have a dead 6J6 tube.
10 Euros NOS warranted from my local shop. Was already planning on ordering a couple things from them in the coming days, so I can just add that to the list.
3) A year back this instrument was starting to try to zap me when I was touching the case.
The Y caps were failing I guess, classical.
Well today they failed for good. After a few minutes working on the thing, the differential breaker tripped.
So I removed those caps, and I am back in business.
So.... a bit of a tough ride.
I think I will invest 10 Euros to replace the tube and have a working unit, will help in selling it I guess, and balance the fact that it's now lacking its exotic/obsolete power cord. It's in great condition cosmetically so it could appeal to "deco" fans as well, quite trendy these days over here.
Hopefully one day I will eventually stumble upon that bloody cord....
Might fit a modern day earthed IEC socket at the back, for safety, but not sure it would appeal to vintage TE collectors who might see this as mutilation.
Same goes for fitting a BNC connector at the front.
So, first things first.... let's buy that 6J6 tube to bring that TE to operational status, then we will decide what to do. Hell I may even be glad to have it working again and decide to keep it... after all its goes up to 50MHz which is quite useful, and it's not a boat anchor, not that large nor very heavy.... hmmm... yeah I am hesitant now
I like the looks of it the quality look and feel of the engraved stainless steel dials...
Time will tell... maybe I will flog other stuff first, and then come back later to it to make a decision...
At any rate these are hardly rare over here, Metrix being local, lots were sold and they are found routinely for sale here. But that one is in excellent nick inside out, and I paid only 30 Euros for it so... it I were to buy another later, it would be easy to do I think, but it would not be as good value for money I think....
