Here is how the Harrison 6209A power supply behaves with a 40W lamp limiter, oddly if you turn the voltage control up to maximum it stops oscillating.
Shortly after that video things went a bit wrong, I turned the voltage control back down and it locked up.
Thankfully I had something suitable in my spares to replace the 100k multi-turn pot, which I suspect has been replaced previously as it's 4 years younger than most parts & was badly soldered.
-group-therapy-thread/?action=dlattach;attach=2418003)
I've also given the capacitors a quick check, only one is in really poor condition (ESR above 20 ohms), it's C34, I've noticed the later B model doesn't have this many capacitors, they stopped at C24.
A few extra pictures, as I had to remove the panel meter again to get to the pots.
-group-therapy-thread/?action=dlattach;attach=2417999)
Wonder how many of these were made, before the B model was created?
-group-therapy-thread/?action=dlattach;attach=2418007)
And I've been over to the storage unit, to see if any of the Cinch terminal bars used #5 UNC screws, of course I only have those with M3 or #6 UNC. Not too much of a problem, the 15A ones are still made, along with the jumpers & solder links. Note: the terminal bars on these old Harrison/HP PSUs are not actually made by Cinch, but the jumpers were according to the manuals.
