Author Topic: Test equipment is a disease...  (Read 4364 times)
Online tggzzz
Re: Test equipment is a disease...
« Reply #25 on: July 17, 2024, 02:22:31 pm »
I have at my disposal no less than 4 wonderful pro-level bench power supplies.
Only 4?  ::)
You need 4 before you can get 5 :)
The same is true for oscilloscopes.
The following users thanked this post: egonotto, ballsystemlord
Online tggzzz
« Reply #26 on: July 17, 2024, 02:23:22 pm »
Help me!
The first step in self-help is to realise an addiction is not a disease.
Offline TomKatt
« Reply #27 on: July 17, 2024, 02:26:31 pm »
It's not mine - I'm just testing it for a friend!
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PICt
The following users thanked this post: pdenisowski
Offline BillyOTopic starter
« Reply #28 on: July 17, 2024, 02:38:34 pm »
Oh heck, I have 10 11 of those...
Offline TomKatt
« Reply #29 on: July 17, 2024, 02:42:01 pm »
The only thing keeping my house looking like Mr. Carlson's lab or Curious Marc is my home isn't large enough.
And the wife claims she needs to eat.  :P
The following users thanked this post: egonotto, pdenisowski
Offline exe
  • self-educated hobbyist
« Reply #30 on: July 17, 2024, 02:57:51 pm »
Could somebody explain the dangers of connecting power supplies in series? Apart from lethal output voltage.
Afaik, some measurement equipment mentions that isolated outputs can only float above ground up to some voltage (e.g., 240V). Can this be a problem with this setup?
Online tggzzz
« Reply #31 on: July 17, 2024, 03:03:40 pm »
Potentially, yes. That will be clearly stated in TFM (which you will have read, of course) and possibly on the front or back panel.
« Reply #32 on: July 17, 2024, 04:04:09 pm »
But have you connected all the ports in series yet? :)
There's some great potential there! :-DD
 :palm:   :-+
Offline armandine2
« Reply #33 on: July 17, 2024, 05:46:19 pm »
connecting in series - from the manual
In a closed society where everybody's guilty, the only crime is getting caught - Hunter S Thompson
The following users thanked this post: exe
Offline Njk
  • Country: ru
« Reply #34 on: July 17, 2024, 06:48:54 pm »
IMHO, now the situation is that each new model is less useful than the previous. Because one thing that makes the instrumentation equipment special is that a good knowledge about how the instrument works is required to use it successfully. Indeed, how I can trust the number if I don't know how it's obtained.
That's very obvious and in the past every instrument was accompanied by a large documentation volume, that explained not only how to operate the instrument but also provided great details about what's inside, up to the wiring diagram and BOM. Because it's all necessary for customer. Now it's considered a secret information and only the magic box is provided. That's ridiculous. After all, the illegal taxi drivers at the airport are also fiercely competing each other but they're typically smart enough to don't load the customer with their problems. If it's so confidential, the best thing the vendor shall do is to don't sell the instrument. Just keep it for himself and be happy.
Moreover, the fact that there is no widespread rebellion against this trend in the professional community suggests that now few EEs are actually interested in knowing what exactly they're doing. The majority are within a hierarchy and are doing just what they told to do. Perhaps that's OK but that makes their products not trustworthy as well.
The following users thanked this post: egonotto, moerm
« Reply #35 on: July 17, 2024, 08:40:32 pm »
And your nowt but a super spreader
Much prefer enabler.   :)
« Reply #36 on: July 17, 2024, 08:49:00 pm »
Internal breakdown/flashover clearances and component ratings determine how many units can be placed in series.
Ratings such as follows give indications of how high you can push series connections:
Insulation
Case to Terminal ≥ 20 MΩ (DC 500 V)
Case to AC line ≥ 30 MΩ (DC 500 V)
Offline Martin72
  • Testfield Technician
« Reply #37 on: July 17, 2024, 11:33:08 pm »
That was not the idea behind it, the aim is to reliably separate input and output potentials.
Insulation
These are insulation values against the housing(GND), which has nothing to do with how far you can push the series connection.
The 500V is the test voltage.
On the one hand, it is about the sufficient insulation of active circuits against the housing (contact), and on the other hand about the leakage current that results from the EMC capacitors at the input/output against the housing.
Offline CatalinaWOW
« Reply #38 on: July 18, 2024, 12:08:37 am »
In theory connecting isolated outputs from multiple supplies in series doesn't cause any issues.  But in the real world there is often a sneak circuit connecting something you are powering with that series question to ground, and then the mischief happens.  Some people are more careful than others.  Those of us who slip up once in a while like to put an extra layer of protection to cover our occasional lapses.  And thus tend to avoid this type of series connection.
« Reply #39 on: July 18, 2024, 01:10:35 am »
And how does the highlighted above not do that ?  :popcorn:
Insulation
So, just the same as any other device we use and you push near it at your own risk.  :scared:
If we are discuss what can be done with specific models, sure let's do that.
FYI series connections of multiple SPD3303X when in Series mode is a HQ endorsed use type.
A few years back from the HQ App engineer:
Offline 44kgk1lkf6u
« Reply #40 on: July 18, 2024, 02:12:03 am »
Whoever spends too much on test equipment should learn from the guy at Siglent.  He does not even want to waste money on proper cables.  Not even when it may give the customer a bad impression.
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #41 on: July 18, 2024, 08:25:13 am »
Yes, that's exactly the issue - max voltage to ground.  I talk about this in my video
https://youtu.be/o7uxeRjJsMk?t=110
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Offline pdenisowski
« Reply #42 on: July 18, 2024, 08:26:48 am »
Shocking!  :-DD
Online Smokey
  • Not An Expert
« Reply #43 on: July 18, 2024, 09:05:09 am »
I have no immediate need for the Advantest SMU I just picked up.
Only 4?  ::)
If you count that as a power supply, I'm up to 12ish power supplies throughout the whole lab :)
Offline m k
« Reply #44 on: July 18, 2024, 09:36:28 am »
I have at my disposal no less than 4 wonderful pro-level bench power supplies.  A pretty good low end unit and a fairly nice DIY one I just finished building.
Guess what I spent all day on today?  Yup, designing an even better DIY bench power supply!!!
Help me!
[secret four knee trochee mumbling]
That's a spell of help.
It works just like usual helping spells do.
BTW,
how many noble gas filled glass tubes it has?
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
Offline shakalnokturn
« Reply #45 on: July 18, 2024, 11:45:50 am »
Depending on current capabilities / adjustments of protagonists and user abuse there's also the risk of killing the reverse polarity protection diode in the weaker supply.
(Don't ask... I'm an abusive user with about a dozen power supplies, lack of bench causes me to use the most basic 2.5A 30V model most of the time though.)
« Reply #46 on: July 18, 2024, 02:36:05 pm »
BTW,
None yet...
Offline voltsandjolts
« Reply #47 on: July 18, 2024, 04:38:38 pm »
I might be into the second stage of TE syndrome.
I seem to only buy broken gear, even when the backlog of repairs I already have would keep me busy for the next few months.
Why is this happening to me?
Offline TomKatt
« Reply #48 on: July 18, 2024, 04:44:56 pm »
Where's the fun if something just works ???
« Reply #49 on: July 19, 2024, 02:30:20 am »
Can't even imagine what that'd be like!   :-DD
