Really, unless you need more bandwidth, you can stand pat with the 2246 (or sell it/trade up for the 2247A). For about the price of a second vintage Tek analog scope you can buy a pretty nice digital scope (if you don't already have one). I love the Tek analog scopes but if you told me I could either have a 2467B plus the the 2247A or a Siglent SDS2104X Plus, I'd probably have to go with the Siglent SDS2104X. For the price of a 2445 it would make more sense to go with a Siglent or Rigol oscilloscope, especially since you already have a Tek analog scope. The only reason to do otherwise is if you are a Tek vintage collector, in which case there is a thread to help with that...
https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/
I do not "need" the extra 50 Mhz. My application is more for learning as a hobbyist. I have a Keysight EDUX1052 2 channel 50Mhz which is pretty decent for digital, serial etc signals. But I do enjoy using the older analog scopes. I tend to use the Tek much more often than I use the Keysight. Not sure there is a reason for it, I just like it better.
Maybe I just do have a small (emphasis on small) problem with testing equipment. I do get some buzz from taking an old/new equipment and testing it. Perhaps I should join the TEA group.
I would double check that. I think both the 2246 and 2247A/2252 support dual b-sweeps through an obscure control setting. But maybe it is only the 2247A/2252? My 2246 is in storage at the moment so I cannot check.
Good Lord! I was not aware of that, you are 100% correct! It is, indeed, kind of hidden in crazy menu combinations. OMG that made my day! Thank you sir!
In fact you can not only have two sweeps but you can have one sweep on each channel!!!
In case someone else want to know how: In the 2246, you just do the B-Sweep setup as you normally would, then click the Time menu, select |-Time -| option then when you turn the delay you move the fist sweep, when you turn the time position button you increase or decrease the delay between the sweeps, thus creating a second line. Below a picture of what it looks like.
Instructions are in the section 6-17.
