Author Topic: Rigol RSA5000 series real-time spectrum analyzers  (Read 1202 times)
Offline TheUnnamedNewbie
  • mmwave RFIC/antenna designer
« on: January 19, 2018, 04:19:07 pm »
So, this popped up on reddit this afternoon:
https://www.reddit.com/r/rfelectronics/comments/7raa3k/new_from_rigol_rsa5000_series_realtime_spectrum/
Thoughts?
From http://www.saelig.com/pr/rsa5000.html
  • 9kHz to 3.2 or 6.5GHz with a maximum sample rate of 51.2MS/s
  • 1ms full span sweep
  • Vertical range to +30dBm
  • -108dBc/Hz (which is a useless number without the offset but it's "better" than their other SAs)
  • 1 Hz RBW
  • Reduced noise floor (DANL) to -165dBm
  • Can also be used in a traditional swept scan mode
  • Up to 40MHz Real-Time Bandwidth
  • >146,000 FFTs/sec
  • Delivering down to 7.45us for a 100% Probability of Intercept
  • Seven display modes (Normal, Density, Spectogram, Power v. Time, Density & Spectogram, PVT & Spectrum, PVT & Spectrogram)
  • Include a Frequency Mask Trigger.  The Frequency Mask Trigger is especially useful for triggering measurements of sporadic or transient events. (or so they say)
  • Tracking generator option:  100kHz – 3.2/6.5GHz with an output range of -40dBm to 0dBm
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
Offline Mr. Scram
  • Display aficionado
Re: Rigol RSA5000 series real-time spectrum analyzers
« Reply #2 on: January 19, 2018, 04:25:27 pm »
My bad, I thought I had gone back far enough. Mods, please delete!
