H2, We found fixed 10:1 probe quality is better. and many suppliers use same way. you can buy one more probe. buying more tool, earning more money.
Meanwhile, I found this more often and there are clear advantages of pure 10:1 probes.
Nevertheless: my 10 years old (absolutely) beginners scope have two switchable ones, and for low frequency things I found it useful to take those probes for a universal pickup and put the signal to more than one device at the same time. They managed to built the probe up to 100 MHz (in 10:1, 1:1 only for some MHz). I will use one of them with the MicSig in future. Everything's fine ...
H3, many android device shut down by pop up menu. so we are same.
Almost all do so. But in scope mode, there's no Android anymore. The STOs can be operated only by means of the knobs, why not switch 'em off this way? You put the "shoot off" feature on a (rather short) long power button pressure. Most PCs you can "kill" by a 4 seconds power button pressure, most Android devices can be hard resetted by a 10s pressure or so.
As long as it will cause no problems, the long power shoot off will be a workaround, but as I understood (saving scope's settings and so on) it's not healthy to do so.
Take it as a suggestion: Make the hardware shoot off longer (>4s) and take a 1 s button press for a command AND ack to make a normal shutdown.
This leads to another point: My smartphone is switched off once a month, maybe, but I use the power button to put it in STANDBY, from which it comes up in half a second. Comparing to other scopes, they all have no standby feature and boot times of 1 min or more. But here, we may have a chance to get a real standby, with switched off display and stopped fan and a fast coming up? As far as I understood, when pressing the home button, leading to the android desktop, the scope's hardware stay powered (only wfm aquisition is stopped, thus the scope app is back in a second). This will not work for a standby here, as I think the scope's hardware has no sleep mode, but then shut down the scope app and put the rest of the system to a kind of sleep condition (just as a S3 on PC), so the system is back in 1 second and users have to wait only for the scope app restart and hardware initialization, which seems do be done in seconds (like my old UNI-T, which has a cold boot time of 4 seconds).
If not for my, maybe for further scopes?
Using the scope is simple like to use a cell phone.
For all who are familiar to use a (android) phone.
I hope i can become a member of this scope community.
I would extremely welcome your comments on all the questions and points here and wish you to read and consider everything.
And yeah, this could be the thread to communicate wishes and bugs, too.
So, what do MicSig think about an automated data synchronisation in background to a ftp server? (see my point A4).
