I am going to be working on a new project revolving around the development of a 2 quadrent brushless drive for a customer, (aprox 10,000 per year)
We already have a suitable, Lecroy scope (400MHz, 4 channel)
however we are rather inequipped with other gear.
I have been looking through gear that I think will be needed, I would like a second opinion, as this is a small company I work for we have a limited budget.
For a bench power supply, I was thinking of one of these:
http://www.rigol-uk.co.uk/Rigol-DP831-DC-Power-Supply-p/dp831.htmAs this drive will be around 12V at higher currents (15-25A) would a high current PSU be required or could I make do with a variac power supply?
http://uk.farnell.com/ea-elektro-automatik/ea-ps-5040-40-a/power-supply-1ch-40v-40a-prog/dp/2418749I suspect that it would not do well due to mains noise and regulation however.
I am unsure how essential a function generator will be for this job, however I was thinking of this one here possibly:
http://www.rigol-uk.co.uk/Rigol-DG1062Z-Waveform-Generator-p/dg1062z.htm#.VlhKbL-vyU0I imagine I will also need some Oscilliscope current probes, any recommendations?
I don't think a differential probe will be needed due to the low voltage for now.
What other equipment would be recommended?
I am also trying to futureproof thing for future projects, I am a HNC electrical engineering student so I am very much still in the process of learning.
However I have been told I have a better grip then many of my classmates due to several years of hobbiest experementing and learning / reading.
One of my main aim is trying to compile a cost-justified list of test equipment to present to my manager and be able to actually explain why I need each peice and at that specification.
Thanks in advance, any advice and tips would be greatly appreciated.
