Author Topic: The Siglent SDG2042X Thread  (Read 334839 times)
Offline billfernandez
Re: The Siglent SDG2042X Thread
« Reply #575 on: November 23, 2016, 04:53:31 pm »
We are trying to post more and more helpful application notes and FAQs to our website.
We hope that you find these useful.
Thank you for this.  I look forward to more.  In the months after I bought my SDG2042X  I spent many hours trying by trial and error to figure out this kind of thing.
Offline FluentsAndFluxions
« Reply #576 on: November 23, 2016, 07:39:18 pm »
Guy stick around for a week and there might be some new products on the market in this space! wink wink
Evan
Tequipment.NET
Is this in reference to the Rigol DG1022Z or adding distribution for Siglent function generators?
« Last Edit: November 23, 2016, 07:42:24 pm by FluentsAndFluxions »
Offline tautech
« Reply #577 on: November 24, 2016, 08:03:24 am »
Evan
Tequipment.NET
Welcome to the forum F And F
Who knows  :-//
Evan hasn't been back to share any news with us.....yet.
It isn't Siglent distribution, Saelig look after that now and offer similar discounts.
https://www.eevblog.com/forum/testgear/equipment-discounts-from-saelig/
Avid Rabid Hobbyist
Offline Dwaine
« Reply #578 on: November 25, 2016, 10:59:28 pm »
Evan
Tequipment.NET
Those new Rigol generators are still no match spec wise to the Siglent SDG2024X.   The Rigols have a better frontend display that looks better.  Again, based on specs.   Siglent wins all around.
Dwaine
Offline pascal_sweden
  • Country: no
« Reply #579 on: November 26, 2016, 12:19:46 am »
Fully agree!
Siglent is so much better here. They are doing great things lately!
Signal generators, spectrum analyzers, and even their scopes are getting better.
Rigol better get their act together in the long run :)
Offline Lunasix
« Reply #580 on: November 26, 2016, 09:23:51 am »
The SDG2042X is a great generator, with or without 120MHz upgrade. I first bought one, and this first generator triggered two other purchase. Not so bad !
Offline Lunasix
« Reply #581 on: November 29, 2016, 04:16:56 pm »
A trap, for which I lost many hours. I was creating arbitrary waveforms with Scilab, and had a strange problem. If the waveform was quite simple, like 2 or 3 ramps, the ouptut was nice without any visible step. But if it was different, I could see samples and steps, and I had 9us between 2 samples instead of the expected 2us value. I finally found that this was due to the arbitrary mode selected (Arb Mode). The right mode is TrueArb mode, and not DDS mode !
« Last Edit: November 29, 2016, 07:31:06 pm by Lunasix »
The following users thanked this post: billfernandez
Offline MrWolf
  • Country: ee
« Reply #582 on: November 30, 2016, 02:58:21 pm »
Received second unit. Happy to report that Siglent has really gone to town with this puppy hardware-wise.
Clock locking via 10MHz in/out works without any noticeable jitter.
However there is sort of a bug with software...
Naturally 10MHz in/out achieves only clock lock and for getting phases right one must compensate channels on second unit for phase shift. Which brings about serious usability issue:
- turned on unit A, clock set to Internal
- turned on unit B, clock set to External
- switched ON B-ch1, phase compensated B-ch1 in relation to unit A
- switched ON B-ch2 => phase compensation lost on B-ch1!
- compensated again
- switched OFF/ON B-ch1 => phase compensation lost!
Compensation also gets lost when one changes amplitude by substantial amount (relays click).
Interesting is that phase gets thrown around by discrete amount to discrete positions - they seem to be ~3.3 nanoseconds apart.
So for example at 100MHz one could get stuff right again when poking channel ON/OFF long enough because there are 3 discrete variants for "phase dice".
Proposals how to fix this:
If possible, preserve phase between ON/OFF and range change cycles... However it may act funny with low frequencies
and automated interface operations.
Alternative: Implement soft "Pause" functionality that would just drop output to 0 but keep "internals running".
For example currently 6th "soft button" is not used in "Parameter" screen. It could be "Pause".
Also single push on Output-X button could pause (button backlight starts blinking), and two pushes in a row switch off. But latter should be configurable option as most users would not see the point to this.
In either case switching ON/OFF second channel must not throw off phase on first channel and vice versa.
If any of the above is not possible maybe there's some other way because currently one would have to keep both channels  ON all the time and hot-swap signal receivers... A bit hardcore when dealing with sensitive stuff.
« Last Edit: November 30, 2016, 04:38:39 pm by MrWolf »
Offline MrWolf
  • Country: ee
« Reply #583 on: November 30, 2016, 03:13:18 pm »
Interesting is that phase gets thrown around by discrete amount which seems to be ~3.3 nanoseconds.
There's more to these ~3.3ns. Unit has built in counter. When measured signal period's modulo operation with ~3.3ns is not zero counter will display Pwidth, Nwidth and duty values that are off by (at least?) ~3.3ns.
Example: 100MHz "bang on" sine will have Pwidth=13.3ns, Nwidth=-3.3ns and duty=133,3%.
If it is not possible to display correct values on on high frequencies - it should be possible to turn off these readings. Or maybe have alternative screen with nice big frequency/period readout without all the stats clutter - similar to what you have on multimeters.
« Last Edit: November 30, 2016, 03:16:28 pm by MrWolf »
Offline tautech
« Reply #584 on: November 30, 2016, 06:59:03 pm »
Thanks for your constructive feedback.
Reply #582 reported to Siglent.
« Last Edit: November 30, 2016, 09:37:03 pm by tautech »
Avid Rabid Hobbyist
The following users thanked this post: MrWolf
Offline Siglent America
« Reply #585 on: December 01, 2016, 03:46:12 pm »
Greetings.
Regarding your issues when synchronizing two Siglent SDG2000X's together, we have brought this to the attention of the engineering head of that group. He reports that it has been entered into our database of issues to look into. I am told it is not a quick and simple fix, but it is now on their list.
Thank you for your comments.
In the meantime you might look at a video we made in this office where we achieved 4 calibrated phase, with no offset, using Unit #1 to trigger a single count (N) burst on Unit 2. We only did this at a low (60 Hz) frequency so, depending on how high your frequency is, there might be a delay at higher frequencies.
The video can be seen at
Another thing we did here in the USA last year is we locked two SDG5000s together and triggered / started them together so they would be phase synchronized. We have not tried this technique using two SDG2000Xs but I believe it should be the same.
You might look at Method #2.
The application note can be found at
http://www.siglentamerica.com/USA_website_2014/FAQ/SDG/Generating_Multi-Phase_Waveforms.pdf
Hopefully, one of these techniques will give you a better result than you have had. Otherwise, you might check our FW updates on the SDG2000X periodically.
Thanks again for bringing it to our attention.
Offline MrWolf
  • Country: ee
« Reply #586 on: December 01, 2016, 09:27:40 pm »
Thanks for info, 1st class service  :-+
To solve situation I developed Method #3, settled 99.99% of the problem:
Method #2 does not work "out of the box" at VHF because there is substantial jitter which makes finetuning impossible. Solution: Use Methods #1&2 together. Clocks must be synced.
Second problem is with burst mode. There will be ~1us "rearming" delay after burst which makes VHF impossible to implement on 1 cycle basis. 99.99% solution for 100MHz: Use 1000000 cycles burst length, if your DUT can live with 1us signal gap between bursts. Mine can.
Screenshot of tested 100MHz, 4 phase sine signal attached.
Detailed procedure:
A=SIGLENT SDG2122X
B=SIGLENT SDG2122X
C=RIGOL DS1104Z
Connected with 50Ohm cables:
A-10MHz + 0.5m + B-10MHz
A-Aux + 0.5m + B-Aux
A-CH1 + 1m + PassThruTerm + C-CH3
A-CH2 + 1m + PassThruTerm + C-CH4
B-CH1 + 0.5m + PassThruTerm + C-CH1
B-CH2 + 0.5m + PassThruTerm + C-CH2
Unit A configuration:
[Utility]
(OutputSetup) => (Load) => (50Ohm) => (Return)
(CHCopyCoupling) => Track=On; PhaseDev=-90' => (Return)
(Page1/2) => (Clock) => Source=Internal => (Return)
(Mode) => (PhaseLocked)
[Parameter]
Frequency=100MHz
Amplitude=10dBm
[Burst]
StartPhase=0'
Cycles=1000000
BurstPeriod=10.000990ms
Source=Internal
(Page1/2) => TrigDelay=543ns; TrigOut=Up
Unit B configuration:
[Utility]
(Page1/2) => (Clock) => Source=External => (Return)
[Parameter]
Frequency=100MHz
Amplitude=10dBm
[Burst]
StartPhase=225'
Cycles=1000000
Source=External
(Page1/2) => TrigDelay=617ns; Edge=Up
« Last Edit: December 01, 2016, 09:31:38 pm by MrWolf »
The following users thanked this post: Siglent America
Offline flash2b
« Reply #587 on: December 02, 2016, 05:31:57 pm »
Is there any simple way that I can make a screen copy on internal or USB memory for my Siglent SDG2042X ? On my Siglent SDM3055 there is an option to do a screen copy to a USB stick but this is missing on the SDG2042X. My Rigol DS2102A and DP832A also support making screen copy to USB stick.
« Reply #588 on: December 02, 2016, 08:07:00 pm »
PM sent
Offline sdouble
« Reply #589 on: December 24, 2016, 07:22:13 am »
i do think that we would all be interested in such a feature
Offline Break42
« Reply #590 on: December 31, 2016, 11:28:49 am »
Log Sweep issue in the 22R5 firmware
Hi all. The sdg2042 generator is one of the best tools I have. Unfortunatelly there is a bug in the newest 22R5 firmware. If the log sweep is used as follows:
- Sweep time 1sec
- Start freq    100Hz
- Stop freq    10MHz
- Direction: up
- Offset: 0 Vdc
Then the first 270ms of the 1sec period is just one frequency generated (around 90Hz), after this period till one second the sweep works as expected.
I tested this also with other freq. and after power on/off. The failure picture always the same. The linear sweep works correctly as expected.
Do you see also this phenomenon?
« Last Edit: December 31, 2016, 11:56:31 am by Break42 »
Online nctnico
« Reply #591 on: December 31, 2016, 01:50:14 pm »
That looks similar to my SDG1010 on which log sweep is also broken! If you look more carefully (zoom in on the signal) you'll see the log sweep isn't a sweep at all but short pieces of fixed frequencies which go up on a logarithmic scale.
« Last Edit: December 31, 2016, 01:52:12 pm by nctnico »
Offline MasterTech
« Reply #592 on: December 31, 2016, 10:50:40 pm »
Its a different problem. The log sweep works without any problem from 100Hz to 500khz for example. But for higher freqeucues it seems to start after a delay. To me it seems a numerical problem where the the logarithm function that controls the instantaneus frequency is too small during that time and is rounded to 0.
Offline seahood
« Reply #593 on: January 04, 2017, 08:00:10 am »
Hello,
there is an hack for the Siglent SDG2042X which make the device from 40MHz to 120MHz.
What is the difference between the hacked 120MHz SDG2042 and the 120MHz model SDG2122X ???
Offline rf-loop
  • Country: cn
  • Born with DLL21 in hand
« Reply #594 on: January 04, 2017, 08:03:53 am »
Hello,
Least front panel label.
If used in place where need valid calibration certificate. No way.
If practice and theory is not equal it tells that used application of theory is wrong or the theory itself is wrong.
Harmony OS
Offline seahood
« Reply #595 on: January 04, 2017, 08:17:52 am »
hmm, this means the hacked SDG2042X has ALL THE FEATURES from the SDG2122X, ALL?
Offline seahood
« Reply #596 on: January 04, 2017, 08:20:43 am »
Ok, i understand, it has really al features, unbelievable :-)
Offline RoadRunner
« Reply #597 on: January 11, 2017, 04:02:10 pm »
updated my hacked SDG2042x to latest version firmware.
With update to Firmware Version 22R5 , i think telnet asks for user name and password.
does anybody else experienced same?
it is still hackable to 120Mhz though  >:D
Offline texomobile
« Reply #598 on: January 11, 2017, 11:08:26 pm »
I was about to order one, but if the hack is not working any more it doesn't make sense. to me to get one. I have a wavetek 80 I guess it will have to do until the next great thing comes along. Is the version 22r5 sdg2042x currently shipping now, or are there still hackable units in the channel now for sale? has anyone received a unhackable unit recently?
Offline flash2b
« Reply #599 on: January 12, 2017, 08:21:10 am »
You can downgrade to hackable version 17R5, do the hack, and upgrade to 22R5.
