i have ordered my SDG2042x from aliexpress in mid January , i have received software version 1.17R5 which is listed on silent website as latest firmware, i verify that it telnet is still working
. but the old hack just remove the license fill will not working any more
, silent has fixed it ( or broken it) ,currently you can not downgrade to lower version.
so if you have old version (<1.17R5) of firmware and you upgrade to 1.17R5 or later, it may switch to your original current license or not boot at all.
i have looked through telnet and NSP_system_info.xml file is not important any more , content is same as if get automatically by the app with serial number 0123456789 , application does not seem to care about it at all, i could not able to locate where they are storing the real license and serial now.
i deleted the NSP_system_info.xml when the siglent program was running, and it gets automatically created again.
but when i terminated siglent program , removed the file and restarted. it never get created and it does not matter if you have it or not program just run normal.
but good news is,I was able to hack it with one other method
Hi
Unless you bought the 120 MHz version, it seems to be an either / or sort of thing. You can have your original serial number and original bandwidth *or* you have 12345... and the full bandwidth. Several people have suggested putting your original file back before the upgrade and then reversing the process (save the file, delete the file) after the upgrade. If anybody has spotted a change in the file from the upgrade, I missed them reporting that.
Bob
and you can still retain original serial number,i really want to share new hack but don't know if i should share into public domain
,because if silent get to know about this, they are going to fix this in next update.
