Author Topic: Thinging of building Power Supply. Lightweight advice requested.  (Read 328 times)
Offline argile_tileTopic starter
« on: February 23, 2023, 05:20:26 pm »
It is a Tektronix 420a ps failed.  Threw it away: transformer costs more than a news Silgent 2000X ;)  it WAS a high tech switching powersupply with like 4 voltages out (6 or 8 if +- included).
I realize this project might "be back shelf" (not the easiest project for a hobbiest to finish in near term).
I have a used Tek 420a with working PS (dead acquisition board) to work with.
Can I just disconnect and measure the PS with a 50Mhz scope and mimic the results?  With a few drawdown tests?
Can I just buy four chinese switching modules (one for each V needed) ($12 ea, say) then "make my build all about cleaning up the signal" so it "looks as good as the other" on the 50Mhz scope?  (all four would fit in the 420a easily I think)
Not asking for total instructions.  just broad warnings to save me allot of time, if such advice is possible.  If my thinking is way out of the ball field.
I'm a little familiar with power supply jargon - but totally unfamiliar with "what is sufficient to prevent frying IC". (signal smoothness, maximum drawdown allowed).  I've tried to find lessons on the internet about "what signal clean-ness is required" and "what drawdown is acceptable" for IC chips.  I can't find any after long google searches.  Obviously it would be too big a job to chart every chip's requirements with no schematics ever released.  I need something "more in general".
(tek 420a  mess of a board that "supported all voltages on one 5 layer board not separately but intertwined" (making repair quite awful.  i guess that's high tech!)
« Last Edit: February 23, 2023, 06:03:11 pm by argile_tile »
Re: Thinging of building Power Supply. Lightweight advice requested.
« Reply #1 on: February 23, 2023, 06:18:53 pm »
(I could put the working PS in the 420a and sell it.  Look for an easier project.  I'm unsure of how hard a project this is.)
