Author Topic: what is the difference between the HP3478A and the HP 34401A ?  (Read 2075 times)
Offline eevblogfanTopic starter
hey
I bought the 3478A and I am very happy with it , at the work we had to measure the AC ripple of the E3610A under load , so I set up the whole setup and red 0.6XXmVRMS , and wrote the numbers ,
in my home I tried that with my own E3610A and 3478A and the readings was 450uVRMS , BUT i've noticed that even when shorting the leads I get reading of 45XXuVRMS ! , and on the HP 34401A I got 0uV when leads shorted 0_0
please tell me what's the deal wit that , thank you :)
Offline robrenz
  • Real Machinist, Wannabe EE
Re: what is the difference between the HP3478A and the HP 34401A ?
« Reply #1 on: April 29, 2013, 08:16:39 pm »
this thread discusses very low level RMS shortcomings of even high end bench meters
Download the HP links on this post. and read about proper ripple/spike measurement.
This post also shows a low level ripple measurement setup with a classic differential amplifier.
