Products => Test Equipment => Topic started by: jamessawle on April 03, 2015, 10:44:12 pm
Title: Third Party Software for Rigol DSA815-TG and DS1054Z
Post by: jamessawle on April 03, 2015, 10:44:12 pm
Does anyone know where I can find some third party software for the Rigol Kit? Basically looking for anything better than what they supply which is pretty useless.
James
Title: Re: Third Party Software for Rigol DSA815-TG and DS1054Z
Post by: HighVoltage on April 05, 2015, 11:45:47 am
I also made the screen capture program.
http://peter.dreisiebner.at/rigol-bildschirmkopie-lan/ (http://peter.dreisiebner.at/rigol-bildschirmkopie-lan/)
Peter
Thanks for a great screen capturing software for my Rigol DSA815
Post by: videobruce on May 30, 2015, 12:00:22 pm
I was able to install the USB driver, but the .exe doesn't run under Windows even thou it's listed that it should. It's what I call a DOS program, a command window pops up for a split second, then closes.
What's wrong??
Post by: donkey77 on May 30, 2015, 06:27:52 pm
I found the latest version, 0.6.9, worked fine for me with Windows 7 but I didn't use the drivers as connected via lan instead of usb. I did find Norton didn't like it and automatically deleted it to start with and it needs to have they other two folders with the library and dll's below the exe.
Post by: donkey77 on May 30, 2015, 06:29:10 pm
Must also say thank you to Peter. Great work and thanks for sharing. Danke.
Post by: videobruce on May 31, 2015, 01:34:42 pm
I contacted the author. He responded and corrected the link with a update and added a screen shot of the unpacked software. All looks good, the executable now opens.  :-+
