Author Topic: Thoughts on RG-316 coaxial cable?  (Read 728 times)
Offline matthuszaghTopic starter
« on: November 23, 2024, 08:08:54 pm »
I'm thinking about using RG-316 (RG316) SMA cable assemblies for non-performance-critical applications where I primarily want flexibility and ease of use. Any particular thoughts on this? Any alternatives that people prefer in this flexibility class?
Online Someone
    • send complaints here
Re: Thoughts on RG-316 coaxial cable?
« Reply #1 on: November 23, 2024, 10:03:43 pm »
One of the reasons to choose RG-316 is the PTFE dielectric insulation makes it stiffer and less flexible than alternatives (that aren't hard line).
Perhaps RG-174 or if going to manufacturer specific L -3D2W, L-2.5CHWS, L-1.5C2VS ?
« Reply #2 on: November 23, 2024, 10:28:08 pm »
Ah ok that's good to know. Although I've dealt with flexible versions of RG405 cable with a PTFE dielectric and it's flexible enough for my needs - I don't need it to be as flexible as possible.
Offline jonpaul
    • IEEE Spectrum
« Reply #3 on: November 24, 2024, 05:52:57 am »
see mfg app notes eg at Belden.com  eg Blog and notes of app eng Steve Lampen
Jon
An Internet Dinosaur...
Offline nctnico
« Reply #4 on: November 24, 2024, 11:57:36 am »
RG316 is just fine. I use mostly RG316 myself. RG174 is also an option but tends to get tangled up quicker compared to RG316. I use RG174 mostly when I want to solder coax to a board. Just be aware that these types of coax don't have stellar HF performance (say over 500MHz) so for critical measurements where cable dampening is a problem, you want to use a different type of coax.
« Last Edit: November 24, 2024, 12:00:26 pm by nctnico »
Offline tooki
« Reply #5 on: November 24, 2024, 12:35:28 pm »
Without knowing your application it’s impossible to conclusively say whether it’s suitable or not. But it’s one of the most common cable types.
RG316 and the thinner RG178 are both PTFE dielectric and FEP jacket. Most of the stiffness comes from the FEP jacket, by the way. In pure theory, you could strip off the jacket and insulate it with something else to get a more flexible cable.
RG174 is cheaper (polyethylene dielectric, PVC jacket) and is usually more flexible, but the flexibility varies wildly by manufacturer. Some cheaper manufacturers use PVC that is WAAAY stiffer than others. :( I recommend buying a smaller sample of a given brand before buying a bunch. I can say that Huber+Suhner’s is quite flexible, while the one from Tasker is really stiff.
RG58 is also polyethylene dielectric and PVC jacket, but thicker. So usually stiffer than RG174. (Note that technically, RG58 has a solid conductor, while RG58A/U has a stranded conductor, but many RG58 without suffix are stranded anyway.) RG58A/U is what is most commonly used as the “default” cable for BNC assembles. Since it’s fatter it has generally better performance than the thinner cables.
I use all of these (and RG196, which is RG178 but with a PFA or PTFE jacket, which has superior chemical resistance, temperature range, and high-vacuum performance than FEP) at work, as well as a few others. Really depends on what your needs are.
There is also RG188, which is very similar to RG174 and RG316, but with PTFE dielectric and PTFE or PFA jacket, so the same mechanical/environmental advantages as RG196.
There exist extra-flexible coax cables like Stäubli’s SILISHIELD cable which is basically RG58, but uses silicone for both the dielectric and jacket and extraordinarily finely stranded wire, but at the cost of the impedance being 45 ohms instead of 50. Stäubli also makes a regular PE/PVC RG58 with a fairly fine stranded conductor and soft PVC jacket. I haven’t used either of these, but want to try them out.
