Author Topic: Thurlby Thandar Instruments PL330DP service manual  (Read 1060 times)
Offline jwrodgersTopic starter
« on: January 11, 2023, 04:53:52 pm »
I have managed to get a few PL330DP power supplies, some in better condition than others. I would love to have a look at the service manual for these, but I can't seem to find it anywhere. I've had a good search, and come across the PL Series manual (Book Part Number 48511-0150), which has the following tid-bit:
"This Service Manual is for the revised PL models introduced from mid-1991, with the exception of the PL-P 3Amp programmable models which are covered by a separate manual."
Any pointers would be greatly appreciated  :)
[[EDIT]] - See below for service and instruction manuals :)
« Last Edit: January 13, 2023, 05:28:02 pm by jwrodgers »
Re: Thurlby Thandar Instruments PL330DP service manual
« Reply #1 on: January 11, 2023, 05:54:00 pm »
You might try an email to TTi technical support. They're usually pretty helpful, even with legacy stuff.
« Reply #2 on: January 13, 2023, 05:26:21 pm »
Thanks for the suggestion AVGresponding. That is exactly what I did, and they were very helpful. To help others that this way may come, here are the service manuals and instruction manual for these units.
The following users thanked this post: bingo600
« Reply #3 on: January 13, 2023, 05:27:14 pm »
And the operators instructions, along with the RS232 and ARC information.
Offline HalFoster
« Reply #4 on: January 14, 2023, 11:06:00 am »
Thank you for the post - I have been on the lookout for that for quite a while for my PL320.
Hal
--- If it isn't broken... Fix it until it is ---
