Author Topic: Thurlby Thandar QL355 Power Supply - Pt. 2; the innards  (Read 14681 times)
Offline iconTopic starter
« on: July 29, 2012, 04:47:57 pm »
Since there was modest interest in the other thread, I thought I'd post a few photos of the innards of the machine. Hopefully with the aid of the general overview photos at the beginning, you'll be able to work out which bits are where.
[Edit to add] I meant to mention that the power supply weighs 12lb on the dot (5.5kg-ish). I know how interested some of you are in how much things weigh.
Cheers
John
« Last Edit: July 29, 2012, 07:27:35 pm by icon »
The following users thanked this post: arvidb
Offline T4P
  • Country: sg
    • T4P
Re: Thurlby Thandar QL355 Power Supply - Pt. 2; the innards
« Reply #1 on: July 29, 2012, 05:05:16 pm »
Clipped on heatsinks  :(
Samwha caps  :(
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #2 on: July 29, 2012, 06:09:17 pm »
Nice photos.  If those heatsinks are true Avvids maxclips, those are top notch if not proprietary heat sink designs.  Most everything seems to look A#1.
Given they could easily get the reputable Japanese Panasonic, Rubycon etc., brands that have been around for decades, I would guess they did their homework for choosing the Korean maker Samwha, I don't know much about them except they have good spec sheets but Digikey doesn't carry them  ::).
Best Wishes,
 Saturation
Offline tom66
« Reply #3 on: July 29, 2012, 10:19:33 pm »
Jamicons too. :( Samwha are a very new company without proven reliability - they were formed from the old Samsung capacitor business, and Samsung still use them a lot. (I'm not sure if there's a partnership or ownership by Samsung though.)
It's clearly had some cost savings applied in the cap area, so maybe there are other savings too? I would prefer passive cooled huge metal heatsink without fan (like my old PS does 35V, 3A continuous without a fan, only gets a bit warm), does fan speed vary with temperature?
« Last Edit: July 29, 2012, 10:21:20 pm by tom66 »
Offline T4P
  • Country: sg
    • T4P
« Reply #4 on: July 29, 2012, 10:29:38 pm »
Huge would be huge ...
30V 5amps x2 no problem ...
Offline Salas
  • Country: gr
« Reply #5 on: July 30, 2012, 10:27:25 am »
I have seen those exact pictured Samwha in linear PSU hi-fi and pro amps giving no problems in a long time span.
Offline Short Circuit
« Reply #6 on: July 30, 2012, 11:23:29 am »
... (like my old PS does 35V, 3A continuous without a fan, only gets a bit warm)
Of course they do. Now try 1V at max current.
Should not be a problem still, but they'll get seriously warm.
Offline tom66
« Reply #7 on: July 30, 2012, 11:26:58 am »
Same thing, gets warm, but no issue. Shorted output is fine took. Max I drew from it once was full 35V at 2.2A when driving an induction motor. It has a multi tap transformer, max power dissipation is 10V drop * 3A = 30W, which is doable using decent heatsinks, and dissipated over three TO-3 power transistors. I have pictures of it somewhere, I'll see if I can find some.
Offline tom66
« Reply #8 on: July 30, 2012, 11:39:36 am »
Pics...
Offline T4P
  • Country: sg
    • T4P
« Reply #9 on: July 30, 2012, 12:25:47 pm »
I'm just saying, this PSU was intended for 3amps but clearly i went all the way to 5amps...
1V at 5amps? Not a problem, this psu has 3 taps, 8V tap for the 1-8V range, 16V tap and a 16-30
Offline tom66
« Reply #10 on: August 04, 2012, 09:31:52 am »
Oh dear, more bulged Samwhas! Just pulled these from a 40" Samsung LCD. Actually, although there were three bulged (two 1000µF 25V pictured, one 470µF 10V not pictured), only one of them tested really bad (~4 ohm ESR.)  The others tested 0.2 - 0.5 ohms or so each, which is still failed but not as bad. So, I suspect the 4 ohm one went out first, and took out the other two. That would point to a QC issue, which makes me suspicious of Samwha caps.
After replacing them (with Panasonic and Nichicon), TV works fine now. (Before, it had difficulty powering up from standby, stuck with flashing LED.) Oh, and TV is about 18 months old, and really nice with 1080p, USB and 100 Hz, so Samsung cheap out on even their nice TVs. My main TV now. :)
This brings the number of Samwhas I have replaced to 22.
« Last Edit: August 04, 2012, 09:48:45 am by tom66 »
Offline FenderBender
    • The Solid State Workshop
« Reply #11 on: August 04, 2012, 06:16:45 pm »
Yeah seriously!
I feel like we are back in '02 during the electrolytic capacitor crisis! Do these manufacturers really not understand that there is a difference between good and bad quality electrolytics?
If they had only put in good caps I would actually have been very happy with the power supply's build, but it's just getting old. Spend $2 more bucks on good caps and you'll have a better and more reliable piece of equipment which means people will actually buy them.
Offline tom66
« Reply #12 on: August 04, 2012, 07:28:29 pm »
In my old PS all the electrolytics are Chemicons, except the main bulk one (10000µF 63V) is a Matsushita (old Panasonic.)
« Reply #13 on: August 04, 2012, 08:18:38 pm »
Depends on the manufacturer. Mine also. I had a Dell from '01. Chemicon, Rubycon, Nichicon.
But motherboards/graphics/PCI cards were notorious for crap caps for whatever dumb reason.
Offline tom66
« Reply #14 on: August 04, 2012, 10:13:33 pm »
In this case, I'm referring to my massive 35V, 3A linear supply.
But while I have had several power supplies with good caps, I keep encountering ones with poor capacitors. CapXon is my second most common replacement.
Offline madires
  • A qualified hobbyist ;)
« Reply #15 on: August 04, 2012, 10:32:41 pm »
We think that way, but not the MBAs. If products can be designed to fail after a specific time it's done to increase sales. New sales create revenue, long lasting products don't. Welcome to the wonderful world of consumer electronics :-)
Offline tom66
« Reply #16 on: August 04, 2012, 11:38:57 pm »
Designed to fail, sure, that's what you get with LG! This has to be the record for the most caps I've replaced on any TV. All Samwha. I must emphasise - these capacitors -do not- have a good reliable track record. Due to their usage, TTi will not be among my choices for a power supply if I were to order one.
Not shown: Three Samwhas which did not bulge but still had high ESR.
« Last Edit: August 04, 2012, 11:42:11 pm by tom66 »
Offline ju1ce
« Reply #17 on: August 05, 2012, 04:32:12 pm »
I guess the capacitors in a linear bench supply have a much easier life than those in the SMPS of a TV. Television sets are usually in standby 24/7 whereas decent bench supplies have a mains switch in the front panel.
Offline tom66
« Reply #18 on: August 05, 2012, 04:51:02 pm »
Maybe. But the Samyoung caps survived fine (they were mixed in parallel with the Samwha.) All tested good. Even the Samwha caps after the inductors failed - their ripple current is on the order of a few hundred mA! If they can't handle that, then they are suitable for no task. In standby, a TV should be using less than a watt (legal requirement now anyway.)
Offline T4P
  • Country: sg
    • T4P
« Reply #19 on: August 05, 2012, 05:20:42 pm »
5 years lifetime or 10 years lifetime pick your choice
Well for one, it's clear, dodgy caps will shorten the lifespan of a equipment whether TTi Bench Supplies or a TV
Offline Soertier
« Reply #20 on: October 31, 2012, 09:37:41 am »
Anyone know the difference between this QL355 (Not P, T, or TP) and the new Series II? Difference capacitors maybe?
Offline nukie
« Reply #21 on: October 31, 2012, 10:22:23 am »
Colourful wires I like! Thanks for the pictures. Hey guys capacitor lives inside flat panels displays are cooked to death, they don't get adequate air flow thus heat up quickly and reduce lifespan of those already crap brands.
« Reply #22 on: October 31, 2012, 03:28:16 pm »
New features! Great new recipe! Best ever taste! Beats as it sweeps as it cleans! Actually, I couldn't discern any difference - I'm the one who started the thread, and I looked on Thurlby Thandar's website, but couldn't see what made a series II different.
On a positive note, it still works, all these weeks later...
Regards
John
Offline Soertier
« Reply #23 on: October 31, 2012, 03:53:40 pm »
Regards
John
In the mean time I have found this, it should explain the differences:
http://tti2.com/pr-text/QL-SeriesII-PR.html
Even if the would use different capacitors, they would not mention it. I doubt most people doubt about TTI products and checks much.
Offline Baliszoft
  • Country: hu
